Airing Down - Load Range C
Discussion in '3rd Gen. Tacomas (2016-2023)' started by charliehex, May 19, 2021.
  1. May 19, 2021 at 10:50 PM
    charliehex
    charliehex [OP] I belong in the dirt.
    Charlie
    Phoenix, AZ
    2021 Barcelona Red TRD OR DCSB
    285/70/17C BFG All Terrain TA KO2 Method 701 - Bronze 3”F/1"R Spacer Lift Sprint Booster MESO: Gasshole, Map Lights, Sequential Turn Signals Rough Country: Speedometer Calibrator, F/R Seat Covers R4T: Tail Gate Remote Rago: Center Console Molle Panel sPOD: Switch Controller Lamin-x: Amber Fog Light Covers ARB: Twin Compressor Slee Off Road: ARB Twin Compressor Mount Expedition Essentials: 3TPAM Accessory Mount RAM Mounts: Short, Long, Long arm, GoPro Mount
    Hello, frens. I’ve got a DCSB TRD Off Road with 287/70/17 LRC BFG KO2 and I run them at 40psi for city driving.
    I would like to air down for some light Northern AZ (Prescott) trails. I’m not going to push my rig through torquey crawls until I have good recovery gear but I want to soften the ride on washboard roads.
    TLDR: What is a safe pressure window to run in my tires? I know the LRC sidewalls aren’t great for fighting off jagged rocks and thorns but I’m running those until they’re worn out.
  2. May 19, 2021 at 10:55 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    For easy trails and washboards 25 is about how low I go since I’m still at speed a lot.
    Do some reading and testing out what you like best for your specific trails and uses.
    I don’t always carry a compressor so I’m not going down to 15 or less if I have to drive a long way to air back up. If you have one you can go a lot lower.
    ORtoCOTaco and charliehex[OP] like this.
  3. May 19, 2021 at 10:57 PM
    charliehex
    Charlie
    Phoenix, AZ
    I’ll try 25 psi when I leave the pavement and adjust downward front there.
  4. May 19, 2021 at 11:00 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    I'm always around 23-25psi off road, I rarely dropped down to 15-20s, just don't forget an air compressor!
  5. Jun 3, 2021 at 7:35 AM
    Waynebarkr
    Waynebarkr Well-Known Member
    Wayne
    Phoenix
    2020 Cement DCLB TRD-OR AT
    I mostly use 18 psi when I am off-roading in the desert. I used the same psi when I ran Rim Road (FR 300) for about 40 miles along the Mogollon Rim. I have the the stock Goodyear Wranglers w/kevlar (size 265/70/16) on my 2020 OR DCLB. After an hour or so, I note that they are up to around 20psi due to the heat from both the flexing of the tire and the heat we get in the desert. Most of the time I am below 10mph but have gone as high as 30mph for 10 to 15 mins with no problems. I do have a compressor though to air up before I get back on the pavement.
    charliehex[OP] likes this.
  6. Jun 3, 2021 at 9:44 AM
    charliehex
    Charlie
    Phoenix, AZ
    I got my ARB Twin installed.
    I tested psi on a few-mile washboard run in the midday New Mexico heat (80-90) at 10 and 20 mph. 20 mph was probably the best speed because the road is two-lane, mostly straight and visibility is great. Not a lot of animal movement at that time of day so there’s a low chance of hitting anything.
    40-42 psi rattled all my bolts loose at 10 and 20 mph (not literally but I wanted a baseline for comparison.)
    25-27 psi felt better at 20 mph but I could still feel the “skip” when I would get momentum at 20 mph.
    19-21 psi seems to be the magic number for washboard. It felt sluggish during acceleration but I glided over the road after that.
    For fun, I moved to lesser traveled wood-cutting trail and tried 4L and Crawl Control at 19-21 psi. It’s mostly an incline (15-20 degrees) with lots of wash outs and ruts so I got all the flex my dinky 4WP spacer lift and stock Bilsteins could handle. I hadn’t tried it at higher pressures so I only have one data point but the truck climbed without issue.
    I’m now pretty confident in my tires’ ability at 19-20 psi to drive a mix of rough trail and washboard. I’m still going to avoid thorny/jagged trails for a bit until I’ve got more recovery gear though.
  7. Jun 3, 2021 at 9:59 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    I run 20-22 psi on those exact same tires.
    Most of the time I drive home on the highway at that same PSI and they "heat up" to 24-25. Air them up when I get home. Usually only a 40 min ride to get back.
  8. Jun 3, 2021 at 12:47 PM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    On tougher slow trails I run 14-16. On less technical stuff I will run in the low to mid 20s.
  9. Jun 3, 2021 at 12:56 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    If you AZ guys get good beta on some spots, lemme know!
    OP fwiw, Matt, from Matt's off-road recovery runs 8psi year round in his Jeep.
  10. Jun 3, 2021 at 6:05 PM
    charliehex
    Charlie
    Phoenix, AZ
    Does he have bead locks? I have Method 701 with “bead lock technology” but I don’t want to test anything under 15 psi for fear of a sidewall slice or thorns
    AmateurTaco1313 likes this.
  11. Jun 3, 2021 at 6:08 PM
    Bishop84
    Bishop84 Well-Known Member
    20-25 for sure.
    If its just a washboard road, 25 is best simply due to re-inflation times. 5psi x 4 sucks with little compressors lol.
  12. Jun 3, 2021 at 6:16 PM
    charliehex
    Charlie
    Phoenix, AZ
    My ARB Twin handled all four from 19 to 41 in a handful of minutes. I’m gonna get a few runs with a stopwatch for a more official time and then I’m adding a 2 gal stainless tank along the frame to test the air-up times.
    Bishop84[QUOTED] likes this.
  13. Jun 3, 2021 at 6:19 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    You know what, I think he recently got some. But even previously I think he ran around there.
