Airing down for ice?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Boco10, Feb 18, 2022.
  1. Feb 18, 2022 at 5:05 AM
    Boco10
    Boco10 [OP] Well-Known Member
    ADK
    Heading out to go tap a few trees and repair some damage from today's sleet storm. Without bead locks and 33" Falcon At3s what Psi should I go down to. My friend also is coming, and he is running Nitto 34s without bead locks. Conditions are 2" of ice over 2" of powder. I added about 200 lbs to the bed. It is nasty out there, but it needs get done.
  2. Feb 18, 2022 at 5:14 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Without beadlocks I wouldn't go under 15-20lbs. Have some lighter fluid and matches handy just incase you pop a bead.
  3. Feb 18, 2022 at 5:17 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    When I was on 33s and 34s with no beadlocks I was regularly as low as 12 psi. You could comfortably go down to 15 with pretty much zero risk of blowing a bead.
    Edit: Airing down doesn't help much for traction on ice, but it will help with puncture resistance if you start breaking through the ice.
    BeeRadd and Mark77 like this.
  4. Feb 18, 2022 at 5:26 AM
    Boco10
    ADK
    I watch too many you tube videos. LOL. Normally I run 20 -22 (Too chicken to go lower). I am heading out in a few and will start off at 18 and see how it goes. Thanks
    EatSleepTacos likes this.
  5. Feb 18, 2022 at 5:31 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I should also add that the pressures ran above were on load E tires, so they're a bit stiffer and do well at those lower PSI. I wouldn't feel comfortable taking a SL rated tire below 18-20 since they're not quite as robust. Not sure what kind of tires you're running.
  6. Feb 18, 2022 at 5:33 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Ice is the great equalizer. Can you use tire chains there in your area? Airing down really doesn't matter with ice. Ice and snow, maybe.
    nd4spdbh, Michaelo and Mark77 like this.
  7. Feb 18, 2022 at 5:41 AM
    Boco10
    ADK
    Falken load E 10 ply.
  8. Feb 18, 2022 at 5:41 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh yeah, 15 psi all day babyyyy.
    Boco10[QUOTED][OP] likes this.
  9. Feb 18, 2022 at 5:50 AM
    Boco10
    ADK
    Unfortunately, my old chains will not fit my new tires. I hesitated to buy new ones due to clearance issues. It is tight back there and I am worried about doing damage.
    stevesnj[QUOTED] likes this.
  10. Feb 18, 2022 at 5:53 AM
    stevesnj
    The tires pre drilled for studs? My DuraTracs were. That is time consuming though..lol
  11. Feb 18, 2022 at 5:57 AM
    Boco10
    ADK
    No. Good idea though. I should be Ok. If we get jammed up. I am sure we could grab a tractor.
  12. Feb 18, 2022 at 5:58 AM
    stevesnj
    Or if you can get some MaXTrax or something. Good luck though!
  13. Feb 18, 2022 at 9:27 AM
    Boco10
    ADK
    still tons of snow in the woods. Just need to stay on the path. Lol
  14. Feb 18, 2022 at 9:35 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    If you have hills you may want to get out and walk them before going down or up. If it's icy you may not be able to stop once you start going down or make out all the way up, both situations leaving you sliding uncontrollably to the bottom
    SWPA Tacoma likes this.
  15. Feb 18, 2022 at 9:37 AM
    Boco10
    ADK
    g
  16. Feb 18, 2022 at 9:49 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    When you hit the ice get out and walk. If you fall down, don't drive there.
    JGO and Boco10[OP] like this.
  17. Feb 18, 2022 at 11:13 AM
    Boco10
    ADK
    Weird day. After2 days of 50-degree weather and 24 hours of wind and rain followed by 10-degree weather and sunshine. Nothing but 10 to 20 inches of slush. I have a video, but it won't upload. Basically, me going into ditch while trying to get the perfect camera angle. The photo is where I went off and was easily able to get out. 274333642_1107655683354426_4471113809887_4406c620e42cb8f4e4e1bc1d9c01a881fd30dc9b.jpg
  18. Feb 18, 2022 at 11:15 AM
    Boco10
    ADK
    Sorry. I am a dummy. The car is about 10 mins away from my location. The whole town just got flooded out due to an ice jam. Weird
  19. Feb 22, 2022 at 2:06 PM
    chequamegon
    chequamegon Well-Known Member
    Tim
    Minneapolis, MN
    2013 Super White DCLB
    White DCLB w/ Fox 2.5 Adj Resis, 32" Duratracs on TRD 17s, SuperPacific camper, 4.56 Nitros, ARB Front bumper, CBI rock slides, dual rear swingout rear bumper, solar, fridge, electrical
    For ice, you want the opposite of airing down. You want pressure. Remember, your tire pressure is exactly how much pressure your tires are exerting on the ground. downward pressure helps create some grip on ice, and surface area does not.
  20. Feb 22, 2022 at 2:37 PM
    Boco10
    ADK
    I agree for on road. I watched a few vids and opinions vary for off road. I guess I was trying ask if there was a sweet spot to get the sidewall to bite. I would love to go out front of my house and do some testing with our 48-degree weather today. Looks like only 4 wheelers out there today so my testing will have to wait.
