Airbag wiring diagram? Or wire path?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ttrevino, May 20, 2018.
  1. May 20, 2018 at 5:57 AM
    ttrevino
    ttrevino [OP] Member
    2000 prerunner
    Morning everyone, I’m new to the forum and looking for advice.
    The airbag light is on, on my 2000 Tacoma Prerunner. My mom gave it to my son so I don't know how long the light has been on. I found a broken wire on the seatbelt harness on the drivers seat, so repaired that today. I checked the clip under the seat and it looks clean so I reconnected it.
    The light is still on, so I disconnected the negative ground cable for about 20 minutes, to see if it would reset the light, but it's still on.
    I was wondering if anyone had a wiring diagram or wiring path, that I could start checking other connections? The 'normal' component that seems to go bad is the clockspring but I didn't want to just replace that without troubleshooting physical stuff first.
    Thanks in advance!
  2. May 20, 2018 at 5:59 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    You can't reset the airbag light without a professional level scan tool or a visit to the dealer.
  3. May 20, 2018 at 7:50 AM
    ttrevino
    2000 prerunner
    Thanks. I was wondering if I fixed the problem with the wires I corrected if it would reset itself? Over a period of time?
  4. May 20, 2018 at 8:20 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    In my personal experience I have never been able to clear an airbag system trouble code without a friends Snap-On scan tool or having the dealer do it after my clock spring was replaced.
  5. May 20, 2018 at 8:31 AM
    ttrevino
    2000 prerunner
    Thanks for the info, I’ll get it checked out.
  6. May 20, 2018 at 8:35 AM
    Bishop84
    Bishop84 Well-Known Member
    Yes SRS Airbag lights will turn off if the problem is resolved. You do not need to clear them, it does a self-check every time you turn it on. Hence why when there is no fault it still takes a longer time for the bulb check to turn off.
    koditten likes this.
  7. May 20, 2018 at 11:34 AM
    ttrevino
    2000 prerunner
    Any idea of the number of cycles before a reset, if all problems are corrected?
  8. May 20, 2018 at 2:47 PM
    Glamisman
    Glamisman Well-Known Member
    usually an auto parts store, Advanced, O'Reilly etc will scan it for free because they want to sell you a part.
  9. May 20, 2018 at 2:53 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    This. If there has been no actually crash, once the wires are fixed, the light will go off the next time you start the truck.
    You will need an advanced scanner to scan for air bag faults. Auto zone scanners can't do it.
  10. May 20, 2018 at 2:58 PM
    koditten
    Kirk
    Central Michigan
    Connectors are always the week link. All air bag wiring is covered with a bright yellow sheithing. Follow the wires down and check all connectors.
  11. May 21, 2018 at 9:03 AM
    Glamisman
    This is for MY 2000. hope it helps.
    • SRS.pdf
      File size:
      152 bytes
      134
  12. May 21, 2018 at 12:36 PM
    ttrevino
    2000 prerunner
    Thank you for the pdf, however, it says its corrupted or can't be opened?
  13. Jun 11, 2018 at 5:54 AM
    ttrevino
    2000 prerunner
    Quick update, after using the paperclip method to jump across the diagnostic port pins, I came up with 3 codes, 31 54 74. After further research, they all appears to be pointing to the airbag control module being faulty, even though the truck had not been in a wreck. Found one on ebay and $27 later, the airbag system is 100% functional!
    Thank you everyone for the help!
  14. Jun 11, 2018 at 5:58 AM
    Clearwater Bill
    Billy
    Largo Florida
    Thank you for the follow up. So many wander off after asking for help and we never know the end results.
    Glad you got it fixed.
    If you took any photos along the way it would be helpful for future readers if you could post them.
