Airaid Throttle Body Spacer, Worth It?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ewansong, Mar 27, 2022.
  1. Mar 27, 2022 at 2:58 PM
    ewansong
    ewansong [OP] New Member
    Eric
    2019 White Tacoma TRD Pro
    TRD Cold Air Intake
    Hi All. Have seen lots of mixed messages on the value and benefit of a throttle body spacer. I've got a 2019 Taco TRD Pro with a TRD CAI. Can anyone verify the improved torque, throttle response and mid-range power, ideally with an Airaid TBS? Thanks in advance!
  2. Mar 27, 2022 at 3:00 PM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler . Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Save your money. It's worthless.
  3. Mar 27, 2022 at 3:20 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Skydvrr, skeletron, ceh527 and 3 others like this.
  4. Mar 27, 2022 at 3:46 PM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    It’s only worth it if you get it for free.
  5. Mar 27, 2022 at 3:49 PM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    I'll take it, but do you have it in a larger size?
    skeletron and Speedfreak[QUOTED] like this.
  6. Mar 27, 2022 at 4:36 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
  7. Mar 27, 2022 at 5:53 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    If there was a easy and cheap way to add more performance I'm betting the manufacturers would have done it themselves.
    Key-Rei likes this.
  8. Mar 27, 2022 at 5:58 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
  9. Mar 27, 2022 at 5:59 PM
    Holling
    Holling Well-Known Member
    West Coast
    2021 DC TRD Sport
    Thinking of marketing a throttle body reducer.
    RustyGreen likes this.
  10. Mar 27, 2022 at 6:02 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    save your $$$ and just go get the YW or KDMax-Pro Tune. Done until you want the Magnuson SC - which YW is developing a much better Tune for than Maggy will drop on you.
  11. Mar 28, 2022 at 5:33 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Throttle body spacers only work if you have throttle body fuel injection, otherwise save your money.
  12. Mar 28, 2022 at 8:39 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I run one on my Tacoma and I will say it gave a slight increase of power on mid rpms and high rpms
  13. Mar 28, 2022 at 8:43 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i hear snake oil can actually increase MPGs. slippery like a snake...:anonymous:
  14. Mar 28, 2022 at 10:31 AM
    zoo truck
    None
    BS. Our engine guy did dyno pulls trying multiple type throttle body spacers on a mulit-port injected engine sometime back...0 gains. If the spacer was manufactured with a helix type bore, all that was created was a whistling sound similar to what you'd hear from a supercharger that can make big mental hp.
    To get any gains using a throttle body spacer, it would need to have a fuel mixture being pulled through it, not just air.
    Murd3rd likes this.
  15. Mar 28, 2022 at 10:49 AM
    shotgunbilly420
    So I will totally agree with you if it is all you add to your truck and nothing else . Now if you combine with multiple bolt ons I disagree . From what I built over the years and one adding a throttle body spacer gave me a better experience with our V6 . Now I'm sure your gonna fire back and argue . But it's my opinion and my experience and that I back it 100% with my experience not data . I still keep 20 to 19 mpgs on the hwy with a weight of close to 5500 lbs stock gears rolling on 315/75/16 . What's next we gonna argue how headers on our V6 is snake oil too. I'm glad they are not popular cause then the price would rise on these snake oil products. Oh I'm sure you have great argument how running premium is a waste of money too . FML maybe my Blackstone lab results telling me that my engine looks great with 5k mi oil change intervals with over 153k mi is a bunch of bull too .
    Skydvrr likes this.
  16. Apr 2, 2022 at 12:33 PM
    ewansong
    Eric
    TRD Cold Air Intake
    Hi all. Thanks for the responses. Doesn’t ‘sound’ like it’s worth it. Appreciate the help.
  17. Apr 2, 2022 at 1:32 PM
    zoo truck
    None
    Depends what you call add on's. Stuff like headers will add hp. Throttle body spacer no.
    Skydvrr likes this.
  18. Apr 2, 2022 at 1:53 PM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    They're worth it if you drill a hole in it and mount a water\meth injection nozzle in them. Perfect for that. Otherwise, it's pointless.
    zoo truck likes this.
  19. Apr 2, 2022 at 2:03 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Our “headers” are built into the block. :oops:
    Murd3rd and shotgunbilly420 like this.
