Airaid MXP CAI
Discussion in 'Performance and Tuning' started by Menj309, May 10, 2014.
  1. May 10, 2014 at 8:30 PM
    Menj309
    Menj309 [OP] Well-Known Member
    Richard
    SoCal 909
    13 trd sport
    CB Radio
    Does anyone have this CAI? Looking to buy a intake. Haven't found to many reviews from taco members?
  2. May 10, 2014 at 8:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The Airaid filters dosent "filter" well, and the intake just makes noise. No MPG orHP gains.
  3. May 10, 2014 at 10:32 PM
    Menj309
    Richard
    SoCal 909
    13 trd sport
    CB Radio
    Thanks Chris. How about the aFe stage 2 SI I believe it's called? It seems to get a lot of good reviews on here
  4. May 10, 2014 at 10:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Really, the only intake that gives reliable gains, ir the URD>
  5. May 17, 2014 at 7:34 PM
    BLOODYMARY
    BLOODYMARY Well-Known Member
    Keith
    Tulsa, OK
    2012 Tacoma Double
    AFE Exhaust, AFE Panel Filter
    I have the Airaid with my TRD Supercharger...filter fits perfect. Larger intake tube, little turbulence and smooth throttle response. Air Fuel Ratio is very consistent. I actually love this intake.
  6. May 19, 2014 at 8:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There was a guy who dyno'd before and after that Airaid. His dyno showed gains.
  7. May 19, 2014 at 8:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  8. May 19, 2014 at 9:12 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I like my Volant CAI. The Donaldson dry filter on my Volant won't foul the MAF sensor like an oiled cone filter on most setups. I also feel much safer knowing my filter is a good filter rather than some mesh or spongy material. The filter also has an extremely high surface area compared to most filters, the thing is literally the size of a loaf of bread! It's also rated for 100k per filter, though I'd change it at half that just to be safe. I highly recommend that intake and filter, though it does cost a little more. URD is likely to inhale water when it rains, and if you rain sock the filter you lose a lot of the advantages of the setup.
    IMHO from what I've seen most people get slight power gains with most CAI's but lose some fuel economy or vice versa on naturally aspirated setups. In short you may want to consider spending your money on headers or other mods if you want more power from your stock 4.0L.
    However, in a forced induction setup like my tacoma there is a huge power increase due to the unrestricted airflow and the nature of an Roots type blower. Proof in point, I drove exactly the same Tacoma as mine from Cochrane Toyota on a test drive without a CAI and even the dealership salesman agreed my truck had way more get up and go with the CAI and a supercharger than a stock truck with supercharger.
  9. May 19, 2014 at 10:32 PM
    Menj309
    Richard
    SoCal 909
    13 trd sport
    CB Radio
    Cool thanks everyone. Now I need away to get it. Fucking CA laws suck
  10. May 20, 2014 at 4:58 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    FYI, URD filter is not oiled, it is a dry filter. I've had both the aFe Stage II Si and a URD, neither one had any mpg deltas from stock, my experience though.
  11. May 20, 2014 at 9:42 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Good to know. I went off a second hand account of my dealership on that one, lesson learnd.
    Anyways I agree with you 100 percent. As many say, you will not feel a power increase if the increase is under 10 percent. Sadly, other than forced induction, there is no one bolt on mod that will get you more than 10 percent. If there was everyone would do it.
  12. May 20, 2014 at 10:10 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Don't know if I believe the 10% aspect, think it is probably closer to 5, but understand the concept.
    Just fyi for OP and anyone else interested, some of my personal data
    http://www.tacomaworld.com/forum/performance-tuning/141312-afe-stage-ii-perf-data.html
    BTW, in the data above, I couldn't tell a butt-dyno difference until I added the URD CAI and the MAF Cali together. G-tech did show a difference though, but these are not lab environments.
  13. May 20, 2014 at 12:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'm working on that 10% + mod. :cool:
  14. May 20, 2014 at 12:45 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You mean 10% stock parts left?
  15. May 20, 2014 at 7:59 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lol. Nope. I mean 10%+ bolt-on to stock.
  16. May 20, 2014 at 9:43 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Well it does exist, but most people don't want to spend 4000-6000 dollars on the supercharger or destroy any chance of warrenty work with a tuner chip/ECU lol. I wish you the best of luck, if you find something so easy yet effective I know I'll be one of the first in line to try it out!
  17. May 21, 2014 at 10:34 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Oooh... what is it?
    Can you offer a hint? ;)
    Greg
  18. May 21, 2014 at 10:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  19. May 21, 2014 at 10:52 AM
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    After owning, and modifying, a couple of high-performance vehicles over the years I'm 100% convinced that gains from a CAI are minimal at best. The two things you'll definitely get from a CAI are a 'cool looking' air filter under the hood and some additional intake noise. My opinion is that any money spent on a CAI kit can be better spent on something else...a cat-back exhaust system (should return modest performance gains), preventive maintenance, a tune-up, etc.
    On my last car a lot of guys did pretty extensive dyno testing on CAIs and found that the best setup was either totally stock or a stock air-box with a K&N drop-in filter. Even on a 400HP+ twin turbo engine the gains were almost laughable considering the cost of most CAIs. Just my two cents...
  20. May 21, 2014 at 11:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Varies greatly depending on vehicle and intake design. This specific vehicle/engine has been proven to pick up cost worthy HP, dependant upon which CAI is purchased/installed.
