Air/ Vent Selector not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jgwilson88, Dec 10, 2018.
  1. Dec 10, 2018 at 7:58 AM
    jgwilson88
    jgwilson88 [OP] Well-Known Member
    Josh
    1999 Tacoma Single Cab, 2009 Tacoma TRD Sport DCSB
    1999 Rear lowered 2 inches 2009 2" Leveling kit
    Ok, Need some help with my 2009 with 77K miles....Detailed my Tacoma this past weekend and took it out for a drive. I had my air selector on defrost and later on went to change it to front vents and it doesn't change. When turned on high you can hear it blowing hard. It seems to still heat and A/C cuts on when selected it just seems the selector knob wont change to any other position. Any ideas or anyone else ever had this issue.
    Thanks in advance.
  2. Dec 10, 2018 at 8:03 AM
    dbennett48
    dbennett48 Member
    Dave
    Ukiah, CA
    2006 Tacoma Access Cab,5 spd.
    Totally Stock
    Vacuum line has come off the selector valve. I don't know Taco's heating system but most all vehicles use vacuum to select where the air goes. Defrost is the default.
    jgwilson88[OP] likes this.
  3. Dec 10, 2018 at 8:05 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Didn't know this.
    Subbed for outcome. I'm sure I'll have this issue sometime soon on an 06
  4. Dec 10, 2018 at 8:22 AM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    Our system uses a mode servo to move position based on where the switch is set. More than likely there is a issue with the servo
    Jimmyh likes this.
  5. Dec 10, 2018 at 8:26 AM
    jgwilson88
    Josh
    Thanks, ill give that a try. do you have any idea where this line would be?
    inwood customs likes this.
  6. Dec 10, 2018 at 8:28 AM
    jgwilson88
    Josh
    That's what I thought. From what I have read I was thinking the Servo Mode Selector motor. Just wanted a few more opinions before I spent money on that.
  7. Dec 10, 2018 at 8:30 AM
    OKTACO
    Ty
    2005 SR5 Taco
    I said actuators when they are really servos.
    LiquidSteel68 likes this.
  8. Dec 10, 2018 at 8:32 AM
    jgwilson88
    Josh
    Yes, This is the same diagram I came across. Im guessing it would probably be the "mode control servo motor"
  9. Dec 10, 2018 at 9:05 AM
    dbennett48
    dbennett48 Member
    Dave
    Ukiah, CA
    Totally Stock
    Probably the "Air Mix Control Servo Motor".
  10. Dec 10, 2018 at 9:18 AM
    jgwilson88
    Josh
    Wouldn't "Air Mix" Be the hot/cold selector?
  11. Dec 10, 2018 at 11:21 AM
    dbennett48
    dbennett48 Member
    Dave
    Ukiah, CA
    Totally Stock
    You are probably correct. It would be the mode control servo motor.
  12. Dec 10, 2018 at 12:23 PM
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    Intersted to see how this goes for you. I purchased a 09 w 140k this year and the mode selctor doesn't seem to do much. Kinda just blows out of all vents evenly, or maybe just a slight change. Thought maybe it was a weak blower motor or a clogged filter, filter was new. I can hear the motor change from LOW-HI, but there really doesn't seem to me much CFM change between vents while making mode selections. Its enough to warm me up and defrost my windows so I've just learned to live with it.
  13. Dec 10, 2018 at 12:26 PM
    jgwilson88
    Josh
    Yes, The issue your explaining is pretty much what mine is doing. Seems to just blow evenly throughout all vents. Im ok with it now in cooler months here in Alabama but when summer gets here it may be an issue.
  14. Dec 17, 2019 at 12:03 PM
    D-rock
    D-rock New Member
    Micah
    2005 Tocoma 6 speed 4x4
    Any updates? I’m having the same issue.
  15. Dec 17, 2019 at 12:42 PM
    jgwilson88
    Josh
    Mine randomly started to properly work. Haven’t had any more problems as of now.
  16. Dec 17, 2019 at 10:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Remove the mode control servo and then manually move the diverter to see if it is just stuck or the Servo Actuator is defective.
    While unbolted you could watch the actuator move when you change modes.
    igno1tus likes this.
  17. Dec 18, 2019 at 5:31 AM
    weeksz
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    I ended up having a giant mouse nest right above my blower under the dash. Literally like a basketball size ammount of grass and stuff. Couldn't beleive it, dealership never checked the cabin filter?
    cleaned the blower motor changed the air filter and she works great now.
  18. Nov 11, 2022 at 8:16 AM
    LiquidSteel68
    LiquidSteel68 Member
    Kenny
    2011 Tacoma Sport
    Nothing yet...
    I have a similar problem.
    Changing from vent to defrost work very well. When I put the selector on for the feet, air only blows on the passenger side. Not the drivers side.
    Any guess as to why?
  19. Nov 11, 2022 at 8:31 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    See if the actuators are moving correctly, if they are it's something going on with the doors themselves or something blocking the vent.
  20. Nov 22, 2022 at 8:39 AM
    LiquidSteel68
    Kenny
    2011 Tacoma Sport
    Nothing yet...
    Thank you Dm93. I tried looking for this when I dropped the glove box. There is a factory piece of plastic blocking my view. I did order this, and will be looking internal tomorrow when my scope arrives. I borrowed a friend's scope at his garage, but that was for only a few minutes. I was able to locate one door on the passenger side and he thinks there may be two doors that open. I'll update more when I find out.
    Dm93 likes this.
