Air pressure in 10 ply tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Codys9469, May 14, 2020.
  1. May 14, 2020 at 12:41 PM
    Codys9469
    Codys9469 [OP] Member
    Cody
    2017 Tacoma SR5
    hey guys I was just curious i just got new tires on today and I was wondering what air pressure I should run in them? I went from a 245/75R16 to 265/75R16 but the new ones are also 10 ply. Didn't really want 10 ply due to the weight but I got a good deal on them and just wondering what would be best air pressure I should run for a thicker heavier tire like that. I currently have 32psi like the door has but it seems like there's a lot of resistance while driving...
    Junkhead likes this.
  2. May 14, 2020 at 1:10 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    37
    Codys9469[OP] likes this.
  3. May 14, 2020 at 1:12 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Varies based on season, roads, etc. but I usually shoot for about 34 front / 32 rear in hopes of having something close to a smooth ride
  4. May 14, 2020 at 1:19 PM
    BravoSix
    BravoSix Well-Known Member
    2017 MGM SR5 DCSB 4x4
    Seat jackers, Tonneau, Toyo AT3 235 85 16.
    I run 40 and they heat up to about 42 43 when driving. I've only had them a couple weeks and am experimenting with it. Since they are new, I'm seeing how the the "nipples" or "whiskers" are wearing. I also did a chalk test and at 40ish, they may be a little too high in the center of the tire. I've got 235 85 16 toyo at3 and I can feel a big difference from stock as far as feeling the extra weight.
    Edit: mine look low at 37lbs. They bow out at the bottom and dont look right. Maybe that's just part of a high sidewall.
  5. May 14, 2020 at 1:25 PM
    splitbolt
    NW Arkansas
    3d gen Tacomas have a inflated load weight of 2,149 lbs-2,172 lbs from P and euro metric tires.
    Examples:
    265/70/16/112 @ 30 psi = 2,149 lbs(Offroad)
    P265/65/17/110 @ 29 psi = 2,149 lbs(Sport)
    P245/75/16/109 @ 32 psi = 2,172 lbs(SR)
    The vehicle manufacturer de-rates euro-metric and P-metric tires for use on trucks and SUVs.
    If you switch to LT tires, the new inflated load weight is 2,149/1.1=1,954 lbs.
    Use the LT load charts to find the PSI that attains this weight for your particular size.
    TOYO PDF
    https://www.google.com/url?sa=t&sou...Vaw0zaHumL9xB01d0CRYFLPCS&cshid=1562890063059
    NITTO PDF
    https://www.nittotire.com/media/152964/TechBulletin_NTSD-12-011.pdf
    https://www.tiresafety.com/en_us/choosing-tires/sizes-and-classifications/light-trucks-and-suvs
    https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=195
    https://www.moderntiredealer.com/article/311494/lt-or-p-metric-tires-for-light-trucksuv-applications
    https://www.tirereview.com/tire-types-and-load-capacity/
    https://www.tirereview.com/the-importance-of-load-ratings-the-unsung-hero-of-vehicle-safety/
  6. May 14, 2020 at 1:25 PM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    only way to know for sure and for your setup is a chalk test. fwiw, I run 38 on highway
  7. May 14, 2020 at 1:27 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    This. Listen to this. He helped me come up with this same answer, mine have been perfect at this pressure.
    Astr0Aar0n likes this.
  8. May 14, 2020 at 1:28 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Chalk test it. With my sliders, skids, truck box and bumper, I run 36 in the front and 32 in the rear, for a perfect chalk test. 265/70/17
    maxtherat and Triple P like this.
  9. May 14, 2020 at 1:33 PM
    BravoSix
    My 235 85 16 E would look damn near flat at 32. Maybe my eyes are fooling my old ass.
    Guess I better go back down to 37 since it heats up to 40 on highway.
    cubie[QUOTED] likes this.
  10. May 14, 2020 at 1:35 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    42 here but I'm pretty heavy
    BravoSix likes this.
  11. May 14, 2020 at 1:37 PM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    Im really glad you posted this. This is how to find the proper PSI needed. The "chalk test" can lead to some dangerously under-inflated tires.
    splitbolt[QUOTED] likes this.
  12. May 14, 2020 at 1:38 PM
    splitbolt
    NW Arkansas
    I agree...
    The 'math' puts you at 43 psi.
    43 psi in a LT235/85/16/120 is 1,966 lbs.
  13. May 14, 2020 at 1:39 PM
    BravoSix
    So I should be at 43?
  14. May 14, 2020 at 1:39 PM
    BravoSix
    Damn math! I cant do it lol.
  15. May 14, 2020 at 1:50 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I have 265/65/17 e load ko2s and run 30. I tried 35 but it was way to rough for my liking.
    I get advertised mpgs and the truck got plenty of power at 30 psi.
    Just because you got 10 ply tire, IMO doesnt mean you need to run higher pressure unless you added weight. Just my .02, good luck!
  16. May 14, 2020 at 1:54 PM
    BravoSix
    And they dont look super low?
  17. May 14, 2020 at 1:58 PM
    splitbolt
    NW Arkansas
    Yep...
    2,149 lbs x 4 tires give you 8,596 lbs.
    Curb weight is 4,000-4,500 lbs; GVWR is 5,600 lbs. Let's just suppose average cruising weight is 5,000 lbs...
    This gives a 1.7 dynamic load coefficient.
    Chalk test is fine if you're just going back and forth in a flat parking lot.
    Amanelot and WZ00R2[QUOTED] like this.
  18. May 14, 2020 at 2:02 PM
    splitbolt
    NW Arkansas
    The 'math' puts you at 41 psi; LTs probably aren't for you.
  19. May 14, 2020 at 2:03 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Thats 30 psi. Thats what toyota recommends, why would it look low? 10 ply is designed to carry more weight, so thats why you could put more air in them, other than that just run what toyota recommends.
    BravoSix[QUOTED] likes this.
  20. May 14, 2020 at 2:03 PM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    I run 35 psi cold on 265/75R16 E load, on a OR DCSB with about 50 lbs of gear in the bed, they run around 38-39 warm.
