Air intake box fills with water while raining
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gundry, Dec 30, 2020.
  1. Dec 30, 2020 at 10:41 AM
    Gundry
    Gundry [OP] Member
    Kody
    2003 Toyota Tacoma 4x4 V6
    Howdy! First post. Just bought this 2003 Tacoma. The air intake pulls in a lot of water while I’m driving in the rain. It has about a half an inch of standing water and the bottom of air filter gets wet with just 10 minutes driving in the highway.
    Is there some way to fix this without a snorkel. Anyone else have this problem? Thanks!
    Taco critter likes this.
  2. Dec 30, 2020 at 11:03 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Replace your cracked air box
    Or
    Missing fender liner
  3. Dec 30, 2020 at 11:06 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You don't need a snorkel. You have a leak somewhere.
    Does it get water inside just sitting in the rain, or only when driving?
    The airbox pulls air from inside the fender (tube going from air box to side of fender). You probably don't have an intact fender liner and the tire is tossing water inside.
    Black DOG Lila, slander and Dm93 like this.
  4. Dec 30, 2020 at 11:17 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    This, check the liner, the intake is basically right above the centerline of the tire. When I did my SAS and had to remove that liner I built a guard for it out of a licence plate, a less redneck solution would be a new fender liner on a stock truck.
    Black DOG Lila likes this.
  5. Dec 30, 2020 at 11:19 AM
    Gundry
    Gundry [OP] Member
    Kody
    It only happens when I’m driving in the rain and flings water and dirt into the air box tube. Does the fender liner cover the air intake tube to prevent water from getting in?
  6. Dec 30, 2020 at 11:22 AM
    jbrandt
    Justin
    That's exactly what it does.
    Do you not have one at all?
  7. Dec 30, 2020 at 11:25 AM
    Gundry
    Gundry [OP] Member
    Kody
    I’m guessing not. Here is a photo of the fender and the air intake tube. EC8322A4-CA61-4546-BE6C-63E6256B0A9E.jpg
  8. Dec 30, 2020 at 11:28 AM
    jbrandt
    Justin
    Yep, that round plastic clip (is what used to hold it in place.
    I don't really have a good pic of what mine looks like, but it's just thin plastic sheet that's molded to the shape of the fender. You can buy them (maybe used are best from a wrecking yard) or make your own without too much trouble.
  9. Dec 30, 2020 at 11:31 AM
    Gundry
    Gundry [OP] Member
    Kody
    I see. Thanks guys! I’ll see if I can find a new or used liner. Much appreciated.
  10. Dec 30, 2020 at 11:43 AM
    Gundry
    Gundry [OP] Member
    Kody
    In the mean time, any suggestions for covering the hose but letting air still pass through?
  11. Dec 30, 2020 at 11:49 AM
    jbrandt
    Justin
    Might be able to just remove the snorkel piece, and let air in directly from the engine compartment. That's basically what my "cold air" intake does.
    Then cover the hole in the fender (where the intake tube/snorkel goes) with some plastic sheet or something.
  12. Dec 30, 2020 at 11:56 AM
    Black DOG Lila
    Virginia
    Flex patch :confused: or Duct tapeo_O
    :fingerscrossed:
  13. Dec 30, 2020 at 1:15 PM
    Gundry
    Gundry [OP] Member
    Kody
    I wonder if it will still get enough air if I cover it in duct tape?! Ha! Maybe poke a few holes in it? Worth a shot. Thanks.
  14. Dec 30, 2020 at 1:22 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Wrong thinking......
    pull the air box OFF the piece that enters the fender. Just allow the air box to pull air from the engine bay until you manage a repair. Meanwhile, cover the HOLE in the fender with a few lengths of duct tape.
    Don't start cutting holes in the intake air duct work or air filter box or the plenum......
  15. Dec 30, 2020 at 2:18 PM
    Gundry
    Gundry [OP] Member
    Kody
    I’ll give that a try. Thanks. I meant I would put duct tape over the air intake hole in the fender and poke a few holes in the duct ape to let some air pass. Not the best plan.
  16. Dec 30, 2020 at 2:29 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I did the Elbow Mod where I removed the factory "backward snorkel" and the box draws cold air from the inner fender area. Never gets water in the box even in heavy rain. Obviously that liner is very essential. I would get that liner done straight away before even allowing hot air from inside the engine bay up the intake.
  17. Dec 30, 2020 at 2:30 PM
    Gundry
    Gundry [OP] Member
    Kody
    Thank! I ordered a fender liner. $18. Hopefully it lasts.
    Ridgerunner likes this.
  18. Dec 30, 2020 at 2:32 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    The liner is essential, knew a guy that nearly hydrolocked his engine going through a big puddle after he removed the liners to clear 35" tires. Stalled and wouldn't start. Only thing that saved him was his air filter that was drenched, after we pulled that out it started right back up.
    He has a snorkel now, but in your case you just need a new liner
  19. Dec 30, 2020 at 2:38 PM
    eon_blue
    Azusa, CA
    The fender liners also keep mud and debris from getting into the inside of your door jambs. I cut my liners where they meet the pinch weld to clear 33s and it lets a lot of mud into there now
    Seagull233 and Black DOG Lila like this.
  20. Dec 30, 2020 at 7:30 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    It's too bad you couldn't heat and then form those liners to accommodate your tires instead of cutting-I wonder if that's possible.
