Air Injection Pump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Youright, Apr 26, 2023.
  1. Apr 26, 2023 at 9:26 PM
    Youright
    Youright [OP] Member
    Hawaii
    P2440 and P2442 error codes popped up.
    Shop quoted me about $780 for a brand new Air Injection Pump straight from Toyota. Bought a similar pump from Amazon instead for $130.
    Everything was pretty much plug and play. Only difficult part was getting the rubber mounts on the new pump attached to the original bracket.
    After disassembly and inspecting the old pump, the foam filter was completely disintegrated and nowhere to be found. The teeth on the fan were brittle. Pump runs fine, still have the error codes though..
  2. Apr 26, 2023 at 9:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The pieces are probably stuck downstream in the switching valves.
    Kolter45 likes this.
  3. Apr 26, 2023 at 9:42 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Yes. The switching valves get corroded and sticky as well.
  4. Apr 26, 2023 at 10:33 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
  5. Apr 27, 2023 at 12:34 AM
    Youright
    Hawaii
    Is this something you usually would just replace completely or just clean out somehow?
  6. Apr 27, 2023 at 4:44 AM
    c4haskett
    c4haskett Active Member
    Charles
    2012 DCSB 4.0 Barcelona Red
    10thMTNgrunt, Kolter45 and clifpaul like this.
  7. Apr 27, 2023 at 7:38 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    A few people have taken them apart and cleaned them and they worked for awhile but typically they have to be replaced.
  8. Apr 27, 2023 at 8:26 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    How is the aftermarket one working? I've been curious about them seeing the vast price difference. I posed the question a few months ago, but no one responded (I assumed no one has tried it).
  9. Apr 27, 2023 at 8:36 AM
    Sharpish
    Brian
    A tuner might be able to disable the SAIS. You’re still spending a few hundred bucks but this way you get some increased power, fuel economy and drivability too.
  10. Apr 28, 2023 at 9:22 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    The Uni Mod can fix this. That foam is the problem. I've had the Uni Mod for years
    https://www.youtube.com/watch?v=exLfmrVqinU
  11. Apr 29, 2023 at 8:40 AM
    GilbertOz
    GilbertOz Driver
    CA
  12. Apr 29, 2023 at 6:19 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP. Am i correct in assuming you have a 2012?
    There might be a good use case to buy a 2013+ ECU to plug in so you get the shutdown purge of the system if the valves are a problem for you. (this is assuming the plugs are the same which i believe they are)
  13. Apr 30, 2023 at 11:33 AM
    Youright
    Hawaii
    Louder than stock. That's the only difference I've noticed.
    tak1313[QUOTED] likes this.
  14. Apr 30, 2023 at 11:34 AM
    Youright
    Hawaii
    Yup 2012. I'm considering that Bypass kit everyone is replying on here.
  15. Apr 30, 2023 at 11:54 AM
    nd4spdbh
    SoCal
    If you have visual smog in your state you will fail FYI.
  16. Apr 30, 2023 at 11:58 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    You should qualify for the open recall, my folks’ 2012 had their secondary air system system completely replaced by Toyota at no charge. I apologize if this thread had gone over my head.
  17. Apr 30, 2023 at 12:01 PM
    MikeSpiller
    MikeSpiller Member
    To address the error codes, I would suggest checking the air injection control valves and the air switching valves, as they are also common causes of the P2440 and P2442 codes. Make sure they are functioning properly and not clogged or damaged. If the problem persists, it may be best to take your vehicle to a trusted mechanic who can diagnose and resolve the issue for you.
  18. Apr 30, 2023 at 12:07 PM
    10thMTNgrunt
    2013 TRD Sport
    I’m nearly certain Toyota will address all of OPs concerns for free. Someone correct me if I’m wrong, isn’t this why there’s an open recall on the 2012 secondary air system?
  19. Apr 30, 2023 at 1:50 PM
    10thMTNgrunt
    2013 TRD Sport
  20. Apr 30, 2023 at 7:37 PM
    Sharpish
    Brian
    I think that’s 10 years from date of first use. So he would be out of the window.
