Air Fuel and Oxygen Sensors - quick question
Discussion in '1st Gen. Tacomas (1995-2004)' started by kingston73, Jul 1, 2010.
  1. Jul 1, 2010 at 11:20 AM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I don't have a check engine light but I've been thinking I should maybe replace my sensor(s) just to prevent any type of problems. The sensor before the cat was replaced about 2 years ago, the one after the cat has never been replaced. Looks like I can get them both for $177 here:
    http://www.amazon.com/Denso-234-9001-Air-Fuel-Sensor/dp/B000C5WD2Q
    My question is: are these the correct one's and is Denso a good brand to buy?
    2nd question: Will replacing the rear one do anything, or should I replace both?
  2. Jul 1, 2010 at 11:23 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    denso is a very good brand.if the light is not on i would'nt replace them.
  3. Jul 1, 2010 at 11:30 AM
    toy02ota
    toy02ota Local TW dissenter
    Brownsville, TN
    2005 Chevy Silverado
    I've got the light :eek:. I just cant afford to fix them. What kinda problems could the sensors being out cause other than messed up mpg?
  4. Jul 1, 2010 at 11:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Running rich, possible build up of carbon in the CC's.
  5. Jul 1, 2010 at 11:42 AM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    2004 PreRunner Xtra Cab
    STOCK
    Also, if the Oxygen sensors arent working, the ECU is unsure of the current running condition of the motor and will TYPICALLY throw the vehicle into limp mode. ( revert to a presaved safer fuel/ignition timing maps. This usually results in running rich to avoid engine damage which = decreased engine efficiency and decreased gas mileage. )
    Replace the sensor if you have CEL for an O2 sensor failure. Ive also seen people pull an 02 sensor and spray it down with WD40 or carb cleaner in an effort to band-aid it into working again.
    If it aint broken, DONT FIX IT.
  6. Jul 1, 2010 at 11:45 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I'm confused about these sensors after reading all I could, is it only the upstream sensor that affects mileage? What is the function of the rear sensor, and why is it so much less expensive than the front one?
  7. Jul 1, 2010 at 11:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The front is the Air/Fuel sensor, and the back monitors the front one.
  8. Jul 1, 2010 at 12:15 PM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    STOCK
    Typically there is a sensor pre catalytic converter and post catalytic converter.
    Front usually monitors air/fuel mixture and tells the ECU to adjust accordingly. The back/post cat sensor usually monitors the efficiency of the cat to insure functionality to meet emissions requirements, and serve as another data plot to accurately shoot for a stoichiometric A/F ratio.
    Its possible the rear sensor is comprised of cheaper materials due to not having to "sniff" directly unburned fuel/combustion by-products like the front sensor does and hence is cheaper.
  9. Jul 1, 2010 at 12:25 PM
    98tacoma27
    Ben
    Not Beech Creek
    *seconds motion*
    $82 for the rear. Depending on if you are manual or auto $114 or $126 for the rear. Then add the 5% discount code for rockauto.com and it's even cheaper. Which one is bad? It could also be just an exhaust leak.
  10. Jul 1, 2010 at 12:35 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    the front is the air/fuel mixture.the rear monitors the convertor.so the ecm knows front o2 mixture,and then checks the readings from the rear o2 to check convertor efficiency.if your light is on,your ecm operates from whats called a reference voltage,which will get you by till the repair.(usually a little rich)
  11. Jul 1, 2010 at 3:41 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    my CEL has been on for a week it threw the code for the front. I have the sensor (from rock auto) but havent had time to put it in. However, i am getting better gas mileage (about 2 mpg more) with the light on.pretty weird if you ask me!
  12. Jul 1, 2010 at 4:56 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    wtf your getting better mpg with the CEL on?? well thats a new one,ive never heard of that happening before.
  13. Jul 1, 2010 at 7:26 PM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    What would happen if your catalytic converter is not functioning properly?
  14. Jul 1, 2010 at 8:53 PM
    clarkie152
    MA
    2016 4Runner Trail
    I usually get about 300 miles to a tank. I am at 300 miles right now, and only at a lil less than a quarter of a tank. My driving habits havent changed or anything.
  15. Jul 2, 2010 at 2:01 PM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    STOCK
    It wont pass emissions, will likely leave black soot all over your rear fender/ bumper, potential to foul the secondary o2 sensor.
    Short of that, its function is for emissions plan and simple.
  16. Jul 2, 2010 at 2:03 PM
    Killer
    Mobile, Al.
    If it fouls the secondary o2 sensor, I guess that will make the check engine light come on?
  17. Jul 2, 2010 at 2:17 PM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    STOCK
    Yes. Typically it would throw a CEL if the cat were dead as well as the secondary o2 would throw a "cat no workie" error.
  18. Aug 8, 2010 at 2:00 AM
    ExtremeAtheist
    ExtremeAtheist Active Member
    Nick
    Wilson, NC
    96 tacoma stock
    Blown head gasket mod. Busted radiator mod. Rust brown engine bay to compliment other 2 mods.
    I got the cel and pulled the code for the second o2 sensor, when i pulled the cat, it was empty, I want to install a test pipe and cat back exhaust, how do I get the cel to go out without a secondary o2 sensor?
  19. Aug 9, 2010 at 6:59 AM
    98tacoma27
    Ben
    Not Beech Creek
    Use a URD O2 simulator. www.urdusa.com
  20. Aug 9, 2010 at 3:44 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    ^ yah that will do the trick,easy as hell install to. the code that it is meant to clear is P0420 IIRC.
