Air filter wasn't properly sealed for 2-4 months.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Locks1587, Mar 7, 2017.
  1. Mar 7, 2017 at 12:33 PM
    Locks1587
    Locks1587 [OP] Member
    T
    British Columbia, Canada
    2005 Tacoma TRD Sport - SWB
    2005 v6 4.0L
    Thought I properly sealed my air filter, only to check a few months later that it wasn't. Drove around 2000Kms (1250 miles) before i noticed. Seemed to lack power, fuel economy Seemed brutal. What do you guys think?
  2. Mar 7, 2017 at 12:36 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Make sure it's sealed up proper and go drive it. Does it fix the issues? Decent chance they were just a poorly calibrated butt dyno.
    Locks1587[OP] likes this.
  3. Mar 7, 2017 at 12:38 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I can't imagine the additional/unfiltered airflow would affect power or fuel economy so much... but, maybe one or both threw off the MAF sensor? Did you get a "check engine" light?
    I would not worry about damage unless you were driving very dusty roads the whole time. In which case, change the oil and clean the TB and MAF sensor. And make sure your air filter is properly seated :D
  4. Mar 7, 2017 at 12:42 PM
    Locks1587
    T
    Sealed it up (triple checked this time) and hit the highway.. couldn't tell just yet if it made a big difference.. might have to give it a day to see. Where I live there's been a lot of snow and cold dry weather. Sand on the roads but not that dusty. Couple long distance trips tho so hard to say.. let's say my truck is pretty dusty right now so don't feel to good about it.
  5. Mar 7, 2017 at 12:46 PM
    Locks1587
    T
    And the check engine light has not come on
  6. Mar 7, 2017 at 1:10 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    After only 1,250 miles your oil should still look fairly good. If its really dark and dirty looking wouldn't that be a sign of extra contamination getting into the engine?
    EDIT: Nevermind, realized you checked your air filter after 1,250 miles... not an oil change.
  7. Mar 7, 2017 at 4:53 PM
    Locks1587
    T
    Due for an oil change anyway.. smelt a little burnt but wasn't black
  8. Mar 7, 2017 at 5:02 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Change engine oil and filter. Cut filter open and inspect. Send oil sample for analysis if worried.
  9. Mar 7, 2017 at 5:04 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Your fine
  10. Mar 7, 2017 at 5:11 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Have you done the charcoal filter delete? https://www.tacomaworld.com/threads/cheap-free-mods.4838/page-4#post-46273 If not, the charcoal filter will block any large particles from going into your engine. Not sure why there's a performance loss though.
  11. Mar 7, 2017 at 5:17 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Because the CPU is getting conflicting info, with the air filter not sealed the MAF sensor is not correctly metering the amount of air entering the engine, making it run lean, the O2 sensor is seeing that it is running lean and telling the CPU to richen the mixture to get 14.7-1 AFR.
  12. Mar 7, 2017 at 5:18 PM
    blur
    blur Well-Known Member
    When I first installed a K&N filter I didn't seal the box at the back and immediately got a check engine light. I'm surprised you didn't get one. Should be okay, but make sure it's sealed up now.
  13. Mar 7, 2017 at 5:22 PM
    Locks1587
    T
  14. Mar 7, 2017 at 5:28 PM
    KenLyns
    Belly of the Beast
    ^It's there to absorb fuel vapors flowing back up the intake in California. :p
    That's only true if the leak is downstream of the MAF sensor. The air filter is upstream of it.
  15. Mar 7, 2017 at 5:34 PM
    95 taco
    95 taco Battle Born
    Ahh, I'm unfamiliar with the intake system on the 4.0, I've seen a few but it's been about a year since I have.
  16. Mar 7, 2017 at 5:53 PM
    KenLyns
    Belly of the Beast
    The air filter is always upstream of the MAF sensor in all the vehicles I've seen. :notsure:
    95 taco[QUOTED] likes this.
  17. Mar 7, 2017 at 5:55 PM
    95 taco
    95 taco Battle Born
    Yeah, brain fart on my part, I was visualizing the intake on my truck with the filter being at the top of the block like the 4.0
  18. Mar 7, 2017 at 6:11 PM
    KenLyns
    Belly of the Beast
    @Locks1587 try cleaning the MAF sensor. Truck is 12 years old after all. Follow this video if you haven't done it before, except use MAF cleaner instead of electronics cleaner:
