Air Conditioning died
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Alan_G_TRD, May 8, 2019.
  1. May 8, 2019 at 9:37 AM
    Alan_G_TRD
    Alan_G_TRD [OP] The Mug Shot
    Alan
    Orillia, Ontario
    2016 Tacoma TRD Off-Road
    I've got a 2016 OR with about 63K Kilometers (roughly 40K Miles) and to my surprize on the first hot day this spring I noticed my air conditioning is not making any cooling difference now whatsoever. Used to be able to turn the cab into an ice box if I wanted.
    I'm kind of bummed it's gone out already. Anyone else have this issue, and is it a common problem on these trucks? This can't be normal life expectancy for the air conditioning system.
    :notsure:
  2. May 8, 2019 at 9:46 AM
    Labbi85
    Labbi85 Well-Known Member
    Maybe a simple refill of the AC liquid will do the trick!?
    wilcam47 likes this.
  3. May 8, 2019 at 9:48 AM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Definitely a little premature. Does the compressor kick on? There is a safety override that prevents the compressor from engaging if the coolant is low. Take it in and they’ll check the coolant level and run a pressure test to see if you have any leaks. Best case is the leak will be at the fill port and just hooking up to it and refilling will lubricate it up and stop the leak.
    Jaque8 likes this.
  4. May 8, 2019 at 9:53 AM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Start with the fuses there's two of them for the AC system, then check the relay. If all 3 of those are working then its likely a leak causing low pressure. The compressor itself could have taken a shit but I think thats unlikely given the age, possible though.
    Skidog1 likes this.
  5. May 8, 2019 at 9:54 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Start simple: Check your cabin air filter. Mine was so clogged, blowing on your hand was more powerful than the AC. Changed out the filter, and back to meat freezer mode!
    oneup714 and Jaque8 like this.
  6. May 8, 2019 at 9:55 AM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    Good luck! My 2016 w/ 38K miles in at the dealership now. Evaporator has a leak and has to be replaced. $1400 and full dash tear out to replace it.
  7. May 8, 2019 at 9:57 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Automatic or manual A/C? Automatic A/C has a host of sensors that can cause this.
    There's a way to get it to display specific DTCs for the A/C...I'll look it up and post when I get home.
  8. May 8, 2019 at 10:05 AM
    Lunabird
    Lunabird Well-Known Member
    Crap, I think I have the same thing, I better get it under warranty as mine runs out in August.
  9. May 8, 2019 at 11:51 AM
    Alan_G_TRD
    Alan
    Orillia, Ontario
    Thanks for the feedback everyone, although I must admit member "Freetime" has scared the crap out of me!
    I've got it scheduled for a dealer visit, $145 to check the system over. They can't get me in for another 2 weeks though, they are totally swamped in their service department.
    TomTwo likes this.
  10. May 8, 2019 at 12:25 PM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    If you’re not under warranty, perhaps a local/small business garage service center could diagnose and repair for less? $145 seems steep just to test...
  11. May 8, 2019 at 4:22 PM
    splitbolt
    NW Arkansas
    You never said if you had a manual or automatic A/C...
    This only works for automatic A/C.
  12. May 9, 2019 at 7:02 AM
    Alan_G_TRD
    Alan
    Orillia, Ontario
    I've got Auto AC, and thanks very much for the information!
  13. Jun 11, 2019 at 7:56 AM
    Alan_G_TRD
    Alan
    Orillia, Ontario
    Finally got my truck looked at by my dealer this week and apparently it's a blown O-ring seal so it leaked and now has no charge left.
    They told me they felt this happened somewhat prematurely and they would share in the repair costs, whatever that means. It's going in next week to get fixed once a new O-ring comes in, it's about a 3 hour job I'm told.
    shakerhood likes this.
  14. Jun 11, 2019 at 8:01 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Wow, hope you had an extended warranty.
  15. Jun 11, 2019 at 8:11 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Sounds like a good dealer .
    TomTwo likes this.
  16. Jun 11, 2019 at 8:25 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    the a/c system on 3rd gen trucks uses 1234yf refrigerant not the old r134a. which is cheaper and widely available to do simple recharge the fittings are different and old style rechargers for r134a will not attach to the new ports. right now an 8oz can of 1234yf goes for 70$..... so if you only want to spend that money once you better find where the leak is coming from.... gone are the days of just recharging once a summer or however long the system holds.
    ATX_78738 and Madtown like this.
  17. Jun 11, 2019 at 8:27 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Probably from lack of use. I'm guessing in Canada you don't use your AC a whole lot.
  18. Jun 11, 2019 at 9:12 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    All AC’s will eventually leak as the piping is sealed by O-rings...it’s common among all manufacturers.
  19. Jun 11, 2019 at 9:13 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    They are going to 100% cover the entire cost of the O ring, all you have to pay for is 3 hours labor @ $150/hr, 2.3 lbs of super eco friendly refrigerant @$265/lb and oh yeah, the $300 EPS surcharge for not recovering the lost refrigerant.
    But again, the good news is that 75 cent O ring is gratis
  20. Jun 11, 2019 at 9:15 AM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Threads like these have me rethinking the extended warranty. Good luck OP
