Air Conditioner Smell - 2021
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BattleKat, Feb 21, 2022.
  1. Feb 21, 2022 at 3:09 PM
    BattleKat
    BattleKat [OP] Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    Hi All - I searched and found a # of posts on older Tacomas but nothing similar to what I am experiencing with my truck.
    Summary:
    • 2021 Offroad Model
    • Used AC all last summer with no issues. And I like it cold, so I ran it a lot!
    • We had a warm spell here in San Diego off/on over the last few weeks so I've run it a number of times
    • Scent is sort of foul, but sweet smelling at the same time (if that makes sense)
    • Literally lasts for about 10-20 seconds when I turn the A/C on, subtle smell but noticable to anyone in the cab.
    • It then clears up and doesn't smell anymore
    What I've checked:
    1. Checked cabin air filter today and it had your typical dust/dirt on it so I shook it out and re-installed. Nothing unexpected.
    2. A/C Drain - ran A/C and condensation drains perfectly fine. Not clogged.
    Any suggestions/ideas?
  2. Feb 21, 2022 at 3:18 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Check the cowl behind the hood where the a/c air intake is...pop off the black covers and make sure nothing is in there and no critters have chewed up the mesh and/or set up a nest.
  3. Feb 21, 2022 at 3:55 PM
    Doc2
    Doc2 Well-Known Member
    NE GA
    2020 Tacoma SR5 Doublecab 6cyl
    Nerf bars, bed mat, anything I can think of!
    Sounds like a dead mouse somewhere.
  4. Feb 21, 2022 at 4:25 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Your in California... What you expect...lol
  5. Feb 21, 2022 at 5:14 PM
    N4VGW
    N4VGW New Member
    Don
    2017 Tacoma TRD Sport
    I had the exact same issue with a new 2017 TRD Sport. I took it back to dealership and they stated this was a common issue - you are smelling bacteria growing in the coil. They cleaned it with Toyota OEM Air Conditioner A/C CLEANER REFRESHER KIT. It was under warranty however you can find the kit on Amazon if you decide to tackle it yourself unless your warranty covers it. Ask your dealership.
    https://www.amazon.com/dp/B07XC93LK9
    Gamehenge and nightcrawler like this.
  6. Feb 21, 2022 at 5:36 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    When I lived in AZ, this was common for my 17 and both 19's its related to bacteria growth in system, try circulating it to open not closed when using a/c.
    #4TOY4ME and MadKatt like this.
  7. Feb 21, 2022 at 6:16 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    You need to run your system with the recycling off and open to air outside the vehicle for about 30 seconds before you shut your vehicle off every time you use your air conditioner. This will keep you from getting the bacteria build up and smell. That is what was explained to me by someone on here and it has worked for me have never had a bad smell using my ac yet.
    coma toy, #4TOY4ME and TacoBuffet like this.
  8. Feb 21, 2022 at 6:41 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    It's just part of the brilliance of Toyota engineers, because they only design perfection.
    It's a by-product of recirculation being on by default when you run the a/c. Every other car manufacturer defaults recirculate off, and when you turn it on it turns off automatically after 10-15 mins. Ya know...to prevent this from being an issue.
    Who knows, maybe Toyota will figure it out some day.
    Kaizen.
    Natetroknot likes this.
  9. Feb 21, 2022 at 6:53 PM
    eurowner
    eurowner Duke Sky
    Scoty
  10. Feb 21, 2022 at 9:43 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I bought an ozone spray because where I live there has been an increase of skunk sightings and spraying. While this spray doesn’t necessarily make the ac smell better, it is good at removing any and all odors.
  11. Feb 28, 2022 at 8:45 AM
    BattleKat
    San Diego
    Thanks everyone. I turned off recirculate for a few days and the "scent" is gone. Appreciate the feedback. Super bizarre as I have used recirculate with A/C on in my other vehicles for decades with no issues.
    eurowner likes this.
  12. Feb 28, 2022 at 9:07 AM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    This. Something I've never had to worry about in any other car I owned. Now all of a sudden in my Tacoma I have to manually turn off recirc and blow warm/hot air through the system every time I use the AC. Ridiculous
