Air compressor tank has a leak, what to do?
Discussion in 'Garage / Workshop' started by tango down, Apr 1, 2012.
  1. Apr 1, 2012 at 7:56 PM
    tango down
    tango down [OP] Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    So I have a decent, but it was free, used compressor. Its some sort of no name, farm-n-fleet brand of air compressor. I have no complaints, it compresses air and I use it to fill tires, soccer balls, blow stuff (wife wont, lol) off the work bench and garage floor.
    Well today it was running and had a tiny pin hole pop in the bottom of the tank. The pinhole is no where near the release valve either.
    Is there a way to switch the compressor parts to a plain / replacement air tank or do I have to get a whole new compressor?
    I am a tool/compressor n00b, but I know new ones are expensive...like if i have to get a new one, i'll probably drop a few hundred. IDK. I'd rather get a tank for barely nothing and throw the compressor parts and shit on it.
    ANyone do this before?
  2. Apr 2, 2012 at 1:44 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    drill out the hole and put a screw with a rubber washer to plug it. might work
  3. Apr 2, 2012 at 1:46 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i would think if you are careful you could drain the tank and spot weld it to close it
  4. Apr 2, 2012 at 4:32 AM
    tango down
    jeff
    Thanks rellik, ill try it. The welding sounds like it could work, but I can't weld.
  5. Apr 2, 2012 at 4:52 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If it's leaking on the bottom it most likely is rusted inside. I would not try to fix a leaking tank way too dangerous if that thing decides to come unglued there could be flying parts going every where.
  6. Apr 2, 2012 at 12:06 PM
    tango down
    jeff
    I bet it is rusted in there. There was a little splash of rusty water under the pin hole spot that popped. Looks like I'm compressor shopping. Grrrr!
  7. Apr 2, 2012 at 12:09 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    This ^^^
    If the rust has gotten to the point that there is a pinhole, then the metal is pretty rusted. Those tank walls are relatively thick enough where the only way to develop a pinhole is via rust.
  8. Apr 2, 2012 at 12:10 PM
    macgyver
    Brad
    Canton, GA
    Don't worry, I'm right there with you. My Harbor Freight 25 gallon died about 9 months ago. Fortunately I have a small Porter Cable pancake compressor I can use in the mean time.
  9. Apr 2, 2012 at 12:12 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    jb weld
    or
    drill and tap with a plug.
    or both
  10. Apr 2, 2012 at 12:17 PM
    macgyver
    Brad
    Canton, GA
    I vote Bondo. People use it all the time to cover up rust holes in body panels...why not air compressor tanks?
    ;) I know from experience on a flip car I repainted. Bondo Works like a charm
    ...for about 2 months.
  11. Apr 2, 2012 at 12:17 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Harbor freight actually has some decent/cheap air compressors. Husky compressors from Home Depot are also good and the price is not bad.
  12. Apr 2, 2012 at 12:18 PM
    macgyver
    Brad
    Canton, GA
    They're decent until the capacitor decides the melt and implode on you then you can't find a replacement capacitor :mad:
  13. Apr 2, 2012 at 12:21 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    lol That sucks. I've had one for years with no problems, bought it at a yard sale.
  14. Apr 2, 2012 at 12:24 PM
    macgyver
    Brad
    Canton, GA
    Mine is about 5-6 years old. I bought it new at Harbor Freight for like $180.
  15. Apr 3, 2012 at 4:59 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Or 2 seconds @ 150 psi or what ever comes first.
  16. Apr 4, 2012 at 11:23 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'd try it, if it doesn't work it's cheap and useful for other crap, if it does work, cool. Then again I'd just weld it.
  17. Apr 21, 2012 at 3:48 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    There is a small porter cable compressor that is on Amazon for like 99 bucks, will do what you need it to and as a bonus it runs off the bed outlet on 2nd gens.
  18. Apr 21, 2012 at 3:57 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Don't try to patch that hole in any way. If it is rusted at that location it is rusted everywhere else along the bottom, so you just open yourself up for trouble.
  19. Apr 21, 2012 at 4:10 AM
    Honey Badger1
    Honey Badger1 Well-Known Member
    Trip
    New Hampshire
    2011 Tacoma TRD Sport
    Fuzzy Dice, Fighter pilot mod, power ports always on, GPS wired to come on as key is turned, LED Map/dome lights, all weather mats, bed liner, tool box on rail system, Tinted tail lights, repainted badges, Home made grill, Light mounting bracket with two 6 inch. PIAA Drive lights, Stealth mod DTRL on/ off, leather arm rests, door and center.
    There should be a water drain at the bottom of the tank. You should drain on the change of seasons or if its in a damp place (basement or you live in FL) more often. secondly I'd be nervous about putting a projectile into the tank. that being said if you were to get a self tapping screw and rubber washer I'd tac weld it on the tank after. the metal around it may just give out at 120psi and then you have a mighty fast screw you'll have to dodge. I'd try sears I don't normally like them but they will defiantly have some good tanks. I have a 60g snap on compressor I bought when I was 16 I'm now 23 and it still works great. so investing in good tools rather then new tools every few years
  20. Apr 21, 2012 at 4:19 AM
    Catbone
    Catbone Well-Known Member
    Oregon - Columbia Gorge
    '12 4WD V6 SR5
    DeeZee Bull Bar
    As a former Ironworker and having additionally worked in the pressurized tank biz...
    That receiver tank is officially red-tagged. I would not do anything but junk it.
