Air compressor recommendation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by supersizejm, Jan 17, 2022.
  1. Jan 17, 2022 at 8:06 PM
    Spencer_Taco21
    Spencer_Taco21 Well-Known Member
    Spencer
    2021 Cement Tacoma OR 4x4
    Against most of the popular choices I went with desert armor beast compressor and a quad hose. Filled up my buddy and i’s 33’s back to back and it handled it fine. It’s a little large but if you take off the dust tray on the bottom, it fits behind the back seat in the cubby. I think they just came out with an onboard mount too if you plan on doing so down the line. Was going to go arb twin but saved a couple hundred this way and it fits my needs really well.
    supersizejm[OP] likes this.
  2. Jan 17, 2022 at 8:09 PM
    ohcjam
    ohcjam Well-Known Member
    2018 TRDOR DCSB
    Eibach 2.0 Stage 1 Suspension Kit Headstrong Off-Road 1/4" spacer Deaver AAL Total Chaos Bed Stiffener BakFlip MX4 Tyger Running Board N2 12Volt Remote Start Pop N Lock Auxbeam Blue 8 SW Panel Blue Sea System Fuse Block Auxbeam H11 LED Headlight JDM ASTAR Fog Light CaliRaisedLED Ditch Lights 27W Hondo Garage: Un-Holey Dash Mount + Perfect Grip 12" RCI Adjustable Bed Rack (RotopaX and MAXTRAX mounts) Anytime Backup/Front Camera ME-SO Customs stuff..and more stuff..and more..stuff...
    I started with one of those cheap cigarette lighter compressor from Lowe's and started to worry about failing based on how hot it got airing up one stock tire by 10 ~ 15 lbs. Got a single stage ARB. Didn't like how expensive it was going to be after buying a mount and all the accessories. Got a VIAIR 400P after changing to 265/75/16. Yes, they get hot after airing up, but I have been just throwing them back in the bag unzipped and then in the bed. Based on VIAIR's duty cycle, I'm personally not worried.
    I'm sure a dual ARB compressor can air up faster than a VIAIR 400p, but I couldn't justify spending twice as much for an ARB to shave off few minutes. I spend that extra time it takes to air up to stretch my legs and talk to my wife about our trip.
    c_walters and supersizejm[OP] like this.
  3. Jan 18, 2022 at 2:25 AM
    soysauce021
    soysauce021 Well-Known Member
    Bay Area, CA
    2021 DCLB Sport
    Just a makita lxt air compressor for now. Works fine and is portable enough that I can take it away from the car for other items. Love the digital gauge/auto shutoff as well. Fashioned up a small trigger lock and it works awesome.
  4. Jan 18, 2022 at 4:31 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Same for me but my portable is a Makita, because I already had other Makita tools with the same battery system and rapid charger. I keep it behind the back seat in a rigid case and check the battery every couple of months if it's not used.
  5. Jan 18, 2022 at 4:59 AM
    Jammers1971
    Jammers1971 Well-Known Member
    James
    2019 Tacoma TRD Off-Road 4x4
    3.5 lift, 315/75-16, DIY hybrid front bumper, skids, sliders, ditch lights, hood struts, tailgate lock, bed rack, custom exhaust, horn meant for an actual truck, neoprene seat covers
    My Buddy and I each got one of these from Napa and love them.
    I have mine set up with a DIY 4 tire simultaneous inflation/deflation. Running 315/75-16's. Was done inflating one tire ahead of the other three guys using smaller inflators with OEM tires ... and I was bleeding off air the entire time because the auto-shutoff overpressure switch I wired in kept tripping from the air pulses... Totally my oversight.
    I've since remedied that, no overpressure safety built in other than me actually paying attention to whether everything is hooked up and open prior to turning on comp. lol
    https://www.napaonline.com/en/p/BK_...IOyxG9Hv4vJXkCL0DBoCH4IQAvD_BwE&gclsrc=aw.ds&
    S2KON2 and supersizejm[OP] like this.
  6. Jan 18, 2022 at 5:28 AM
    508surfcaster
    508surfcaster Well-Known Member
    17 Tacoma Offroad Acess Cab
    BFG KO2 265 75 16 Front coil spacer.....
    Is there a write up for the diy quad hose setup?
  7. Jan 18, 2022 at 7:51 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Asc_0989, drizzoh and supersizejm[OP] like this.
  8. Jan 18, 2022 at 8:40 AM
    Jammers1971
    James
    Not yet, but I will work it up tonight, get list of material, and take pics etc.
  9. Jan 18, 2022 at 10:11 AM
    2wdSR52022
    2wdSR52022 Well-Known Member
    Jc
    Expensive SR5
    Yup mine fits perfectly behind the seat. I carry this along with my DEWAlt impact just in case...needless to say I’m team yellowBC1F48F5-D9CF-43C4-912E-96BD013B93CB.jpgBB3F430A-1A9B-4D05-B415-99A023216666.jpg
  10. Jan 18, 2022 at 10:16 AM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    I have the Viair 300p works fine, Sure gets hot but they all do
  11. Jan 18, 2022 at 10:21 AM
    S2KON2
    S2KON2 Well-Known Member
    So Cal (SFV)
    This one also gets my vote. They have been labeled as other brands as well and been sold for $200+.
    I'm also on a 4-way inflator/deflator and had 4 33s go from 18# to 33# in roughly 4 mins.
  12. Jan 18, 2022 at 10:24 AM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
  13. Jan 18, 2022 at 10:36 AM
    lalonguecarabine762
    lalonguecarabine762 Well-Known Member
    Brodey
    2022 F150 Tremor
    Previous 2016 TRD Offroad
    yqQCSIMWeVi6wDvAVosPCxLduRkVehm84GH7K_bs_97368d6e973896c36289b9a01ed66a5f2f36eee3.jpg
    Prompted by this thread I pulled out my Viair 300P to see if I wanted to clean it up and sell it or hold onto it as I just switched to a vehicle with larger tires. Found this. Only $15 said and done to replace from ScAmazon but you can tell it is a pretty poorly cast part. Also see the 300P's going for over $200 now when I think I paid $125 for mine.
  14. Jan 18, 2022 at 10:52 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  15. Jan 18, 2022 at 1:50 PM
    #35
    rainsux
    rainsux Well-Known Member
    2021 Tacoma Off Road
    None.
    Seat Jacker has a kit that will permit installing an air compressor under the front seat.
  16. Jan 18, 2022 at 2:37 PM
    #36
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
  17. Jan 19, 2022 at 9:34 AM
    #37
    Jammers1971
    James
    Drainbung likes this.
  18. Jan 19, 2022 at 4:51 PM
    #38
    lalonguecarabine762
    Brodey
    2022 F150 Tremor
    Another interesting finding as I delve down this rabbit hole is the duty cycle, or rather how long the pump can run before it needs to cool down. Dewalt is about 10 minutes, Ryobi 5, but the Viairs are more like 20 depending on the model. When I would air down to about 16PSI and then was try to get four 265 tires back up to 38PSI, it surely took at least ten minutes of consistent run time on the pump. Having to break that up to cool down the unit or not burn in out seems like an unnecessary compromise.
  19. Jan 19, 2022 at 5:15 PM
    #39
    2wdSR52022
    Jc
    Expensive SR5
    I just got DEWAlt because I have plenty batteries but it all depends on usage. I’ve used Ryobi too and for the price is not bad but I didn’t like that it did not have an option to plug its battery only. DEWAlt is battery and 12v. Never looked at viair. I use it for the inflatable bed and for the kids pool in the summer too.
  20. Jan 19, 2022 at 5:25 PM
    #40
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    $598 vs $89. is it even surprising
    DingleTower likes this.
