Air bags or Sumo springs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mas Olas, May 27, 2022.
  1. May 27, 2022 at 7:48 AM
    Mas Olas
    Mas Olas [OP] Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Truck is leveled with 5100s and unloaded rides and looks as expected. Headed to Baja in a couple of hours with all the heavy gear forward-gas can are empty.
    I had Firestone bags on my Tundra and they worked awesome for a decade until I sold it. Looking at the Amazon reviews all I see is bubbles from leaky fittings and would like some input from the braintrust. Bags or Sumos? Thanks!
  2. May 27, 2022 at 7:55 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I have no experience with Sumo Springs, but I like the adjustability of air bags. I've put them on my last 2 Tacomas. The ability to adjust for loads that vary significantly is what works in my case. If I was constantly carrying a moderately heavy load, Sumos might work to keep from bottoming out. But in that case, I'd likely look for a leaf pack designed for my "normal" load.
    02Duck likes this.
  3. May 27, 2022 at 7:58 AM
    mattrussmill
    mattrussmill Well-Known Member
    2015 SR5 DCSB
    If you don't care about ride quality, care more about durability, and want to save a buck go with sumos... but I cannot recommend them in good faith. Personally I tried them for towing (worked great with a trailer attached) but the ride was so awful without an enormous amount of weight back there all the time that I removed them and instead upgraded my entire leaf pack to meet my needs. They really seem to screw with dampening too. Most notably if you do any washboard road driving (even on poor highway roads) it will buck and kick you in your ass when they engage over larger bumps. Some people seem to love them but I see them as a Band-Aid to a larger problem.
    Imo if you don't want to look like you're sagging loaded up and stay stock, ditch the leveling kit. A truck used as a truck should have a forward rake unloaded ;)
    If you really need extra support and want to keep the front height I would consider an add-a-leaf.
    Rock Lobster and WiFiDoctor like this.
  4. May 27, 2022 at 8:04 AM
    WiFiDoctor
    WiFiDoctor Well-Known Member
    2021 TRD Pro
    I tried sumo springs for carrying a constant 700lb load and they were bouncy. They work fine for occasional heavy loads only. I needed up with add-a-leafs and am happy with the result.
    Gen3TacomaOBX and mattrussmill like this.
  5. May 27, 2022 at 8:40 AM
    Mas Olas
    Woody
    By adding leafs it keeps the same stance but is stiffer? Isn’t it harsher unloaded? I’ll prolly just go back to bags and hope the quality is still there.
  6. May 27, 2022 at 12:20 PM
    mattrussmill
    2015 SR5 DCSB
    It would give you a 1.5" rake again unloaded (a little less if you've got the 6ft bed) if you're currently dead level. The ride wouldn't be harsh. I have 600 constant load pack on with nothing but a mid rise ARE cap and I wouldn't consider my ride harsh, but it's stiffer than stock empty.
  7. May 27, 2022 at 2:48 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    do they not make air shocks for the tacoma? that would be my choice.
    hfjeff likes this.
  8. May 27, 2022 at 2:52 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Air bags FTW. I love the ability to load up 1/2 or 3/4 yard of gravel and not bottom out the rear suspension. For the other 90% of the time, put 10psi in, and enjoy the plush ride. I added 5100's and bumped the front up .8" and now the truck sits level all the time.
  9. May 27, 2022 at 5:18 PM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    Exactly my plan.
    2016Tacoman likes this.
  10. Jun 8, 2022 at 4:46 AM
    JJ6453
    JJ6453 Active Member
    Joe
    2022 Tacoma TRD Off Road
    Looking to add air bags to my 2022. Just curious, how did you lift the front .8? Thanks.
  11. Jun 8, 2022 at 5:44 AM
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    the disadvantage of air bags, in my experience, is constantly having to check and adjust the pressure. Some can also be damaged if you put your truck on a lift. I tow a travel trailer and the Sumo Springs work well for me, and they do not make contact with the frame when not towing, so I have not experienced a bouncy ride when not towing.
    JGO likes this.
  12. Jun 8, 2022 at 6:01 AM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2018 TRD Sport 4X4 DCSB
    ive got the blue sumos and theyre perfect for me, not harsh at all. They didnt change my unloaded ride bc they dont ride on the frame until theres some weight in the back. Aint gotta fool with adjusting the air, either.
    DexterMagnus and JGO like this.
  13. Jun 8, 2022 at 6:14 AM
    Firk
    Firk Well-Known Member
    I’m very happy with my Firestone airbags, I put 1000-1200lbs on my truck at least once a week
  14. Jun 8, 2022 at 6:18 AM
    stressler
    stressler Well-Known Member
    Scott
    Orlando
    19 TRD -OR
    I have been happy with my bags and cradles. It was one of the first things I did to compensate for the soft TRD OR suspension. I have since then added a small lift and kept the bags. The ability to adjust for loads is a great advantage.
  15. Jun 8, 2022 at 6:53 AM
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    AAL’s are pretty harsh without weight and will give a lift. Replace my AAL with a full pack because it was so bad. Felt like it was an old wagon with zero suspension. But I hardly ever have any weight in the bed.
  16. Jun 8, 2022 at 10:19 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
  17. Jun 8, 2022 at 10:29 AM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    This is why I think it's good to keep some rake. I don't really understand why everyone wants to level. /rant
    Anyway, I'm still on stock suspension and with my shell anytime I add anything to the bed I start to get droopy. I hate that and it doesn't drive great either.
    I was going to do a temporary AAL until I can get my 5100s and new leaf pack installed but instead added Sumo Springs. Contrary to some of the above posters, I think they are actually quite good. They were simply outstanding with my bed loaded and/or with a trailer. With it mostly empty and just the shell it still rides great. They aren't overly obvious driving around town but speed bumps and such I "think" I can feel them dampen the hit and there seems to be less bounce compared to just the stock shocks. To be honest, I don't really notice or think about them. For the price, they were a great solution.
  18. Jun 8, 2022 at 10:38 AM
    mattrussmill
    2015 SR5 DCSB
    ^ This is what I'm curious about. Do people who actually have a good experience with sumos live in places with exceptional road conditions? Driving PA roads a lot made them intolerable. Parts of Pittsburgh are worse than most fire roads I've been on in other states. They were installed properly with the appropriate amount of gap but the average pot hole around here will cause a fair amount of suspension travel.
    mdjackson likes this.
  19. Jun 8, 2022 at 10:44 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Do you have a link to the air bags?
  20. Jun 8, 2022 at 10:48 AM
    toku58
    Mall Crawler!
    Sumo springs?? Seems way too overpriced for what they are.
    Would this be the Air Bag kit?
    https://amzn.to/3O82uJj
    Anyone have experience with these?
