Air bag light on at random, no codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Dec 31, 2019.
  1. Dec 31, 2019 at 2:31 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Just like the title says, I just started having issues with the airbag light coming on at random and it not turning off until I turn off the truck. I checked for codes both manually and using a Snap On Zeus scanner and there were no codes stored in both current and history codes on the scanner and manual retrieval resulted in no codes as well. Nothing has been messed with in the airbag system, and this just started happening yesterday.
    Whatcha guys got? Bad spiral cable? I know they seem to be the Achilles heel of the airbag system on these trucks.
  2. Dec 31, 2019 at 2:35 PM
    mthew96
    mthew96 Well-Known Member
    mathew
    Western Massachusetts
    2008 tacoma TRD sport access cab 6 speed
    Bilstein 5100 kit and 1” spacer 265/70r17 duratracs BHLM DRL mod anytime fog light mod stubby antenna TRD shift knob LED tail lights TRD cat back exhaust
    More information about your particular truck would be helpful. Any mods or recent work done? I’m not sure if your truck had it but if it has the passenger air bag on/off light is it functioning as you would normally see?
    Anymore information you can give about your truck will be helpful
  3. Dec 31, 2019 at 2:43 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't know what else would be needed other than the basic stuff. Oh, about 113K on the clock.
    No recent mods have been done other than a 2011 PCM swap, which is separate from the SRS control module. The truck has just been driven like it normally has.
  4. Dec 31, 2019 at 2:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The spiral cable is the weak point in the circuit and isn't really hard or too expensive to replace.
  5. Dec 31, 2019 at 2:47 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Will that cause a no codes situation though Jimmy? I'm sure it could but I'd like to get the reaffirmation before reinvesting my time into the spiral cable as I have before.
  6. Dec 31, 2019 at 3:10 PM
    mthew96
    mathew
    Ok lol
  7. Dec 31, 2019 at 3:16 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Most of the time with airbag lights I have found the problem to be with connection issues, particularly connectors for side airbags and such under the seats. Especially if you like to stuff crap under the seats like some people do. If the light comes on, just reach under the seats and wiggle any yellow connector you see, if the light goes out, your issue is with that connector. Although these issues do typically come with history codes present in the airbag module. Steering coil is another common area, but is also typically accompanied by codes.
    12TRDTacoma[OP] likes this.
  8. Dec 31, 2019 at 3:23 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah it's just odd. I have never stuffed things under the seat before, and all connections appear secure. I might just have to try and read the code while the light is on. Because every time I turn the truck off the light goes away, ever since yesterday though the light trips on at random out of nowhere and won't go away until the truck is off.
    Toyota sure knows how to piss me off too. The one thing I cantc stand are those stupid lights on the dash, SRS VSC ABS TPMS, and I've been fortunate enough to have to deal with all of them on at one point or another in the 113K miles of my ownership. Lucky me!
  9. Dec 31, 2019 at 4:58 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  10. Dec 31, 2019 at 5:55 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Your Snap-On scanner can read codes from the airbag module right?
    Airbag light on without a code would mean flaky wiring connection between the center airbag sensor and the gauge cluster, or flaky supply voltage to the center airbag sensor. Make sure your battery is good and the terminals are tight, then follow this service manual section.
  11. Dec 31, 2019 at 6:30 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I had an airbag light show up on my 2009 Silverado but there was no CEL code in the computer. My buddy had a Launch CRP123 Creader and it was able to read a couple of airbag codes that pointed to the driver's side sensor. I bought a new sensor and swapped it out and it cleared the light. I'm not sure if there is a specific scanner that needs to be able to read the Toyota airbag codes.
  12. Dec 31, 2019 at 7:00 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You won't get a code because every time you start the truck, the ECU does a continuity check on the SRS system. If the bag light stays off, it means the check passed.
    If you get a bag light, it means a connector or sensor is showing incorrect continuity (ohms).
    The continuity easily can return to normal between the last time you used the vehicle. (Yes it is that sensitive). so when you start the truck the next time, there may be no bag light after the dash light check.
    Like said above, the spiral cable is the weak link.
    The SRS does a system check Everytime the truck is started. If all components check out, the bag light turns off and stays off.
    If there is an issue, the bag light stays on. This reason is to tell you to find out why the bag light is staying lit.
    For example, if you do not put on your seatbelt when driving, the bag light will stay on. Click on the belt and the bag light goes off.
    The nice thing about the SRS system (yes, I know that stands for suplimental restraint system and is redundant) is that if you correct the issue, the light goes off on it's own.
    In addition, there is no way to clear an air bag light if there has been an actual collision causing a bag to deploy.*
    * You can clear the SRS ECU after a collision and bag deployment if you remove the SRS ECU from the vehicle and have it sent out to be re flashed back to factory settings.
    tacomalman and 12TRDTacoma[OP] like this.
  13. Dec 31, 2019 at 7:43 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have the feeling it is the spiral cable as well. I have had issues before with the horn not working which required I do a repin to an unused pin on the spiral cable to restore the horns operation. It wouldn't surprise me if there is further degradation of the spiral cable now that some time has passed.
  14. Dec 31, 2019 at 7:52 PM
    koditten
    Kirk
    Central Michigan
    Hint:
    Don't make the same mistake I did chainging out my 1st ribbon cable.
    If you do not have a steering wheel puller, do not improvise by using a slam hammer gear puller. ( Look it up )
    I've got the puller attached to the steering wheel, I'm sitting in the driver seat and I start to attempt to remove the steering wheel...
    I wake up with a bloody face and the steering wheel in the back seat...oh and a 8/10 head ache...
    I'll let you figure out what happened...
    12TRDTacoma[OP] and T4RFTMFW like this.
  15. Dec 31, 2019 at 7:58 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  16. Dec 31, 2019 at 8:00 PM
    koditten
    Kirk
    Central Michigan
    I'm thinking your imagination is just fine and spot on.
  17. Dec 31, 2019 at 8:02 PM
    T4RFTMFW
    Jimmyh, 12TRDTacoma[OP] and koditten like this.
  18. Dec 31, 2019 at 8:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  19. Dec 31, 2019 at 8:37 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I've pulled a few steering wheels off in the past using the proper tools to know better than to attempt to remove them using a tool like that. :rofl:
    My dude... You must have a death wish. Or an addiction to pain. :rofl:
  20. Dec 31, 2019 at 8:40 PM
    Bishop84
    Bishop84 Well-Known Member
    I've seen the passenger occupant detection cause this.
    Do the warning light work for the passenger seat? Does it turn off when you sit on the seat?
