Air bag light help??? ASAP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Feb 4, 2017.
  1. Feb 4, 2017 at 11:32 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    Airbag light on. Plugged in a scanner to read the obd2 and cleared everything. The light still on any help thanks. Any suggestions? Never show anything on the scanner. Any help thanks
  2. Feb 5, 2017 at 12:01 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    clock(spiral) cable? seat connection? clean and dialectic grease all plugs
  3. Feb 5, 2017 at 12:11 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I can't tell what truck you are driving. How about a little more info.
  4. Feb 5, 2017 at 12:12 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Assuming you are driving a 2nd gen, your culprit is going to be your spiral cable (cable inside the steering wheel).
    Known defect. I believe they issued a recall for this, check with your dealer - you may be able to get it fixed free of charge.
  5. Feb 5, 2017 at 12:16 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    I have a spiral cable post recall for sale w/out steering wheel controls for cheaper then factory pricing.was on for 2 weeks.if that is your problem
  6. Feb 5, 2017 at 12:48 AM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    Maybe a stupid question and I'm honestly not trying to troll you OP but could it be the passenger airbag light that will come on when no one is in the pass seat or the pass doesn't weigh enough to make the airbag work? Forgive me if you've owned this truck for a while and things are just now coming up that you have questions with.
  7. Feb 5, 2017 at 5:34 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Like others have said, check connections, especially under the seats, before you do anything drastic. I used to jam stuff (gloves etc) under the seat and this has happened.
  8. Feb 5, 2017 at 5:55 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I recommend black electrical tape over light
    bluezzy likes this.
  9. Feb 5, 2017 at 5:41 PM
    pinktaco808
    Base model
    Base model 2.7 4 cylinder. How many plug for air bag?
  10. Feb 5, 2017 at 5:43 PM
    pinktaco808
    It on the dash not the clock bezel.
  11. Feb 5, 2017 at 5:51 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    That's because the SRS codes are mfr-specific and not part of the basic OBD2 protocol. The more expensive pro scanners from Snap-On, OTC, Autel, etc. can read them. Or you can get a mini-VCI cable with a bootleg version of Toyota Techstream to read the codes, something like this: https://www.amazon.com/AUTOS-FAMILY-Techstream-V10-30-029-Diagnostic-Software/dp/B00OOP72U8/
  12. Feb 5, 2017 at 5:54 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    two in the steering wheel and I think one under each seat
  13. Feb 5, 2017 at 5:54 PM
    koditten
    Kirk
    Central Michigan
    Seriously? I ask for a bit of back ground on the vehicle and I get "base model"?!
    What year? How long has the light been on? Does it stay on or does it go off once and awhile? Any previous accidents. Work with us a bit please.
    I'm not seeing where you are putting a lot of effort into solving your problem, so I'm having a hard time putting much effort on my end.
    You got 2800 post. I think you know how forums work.
    If you want a direction to go, look up some of my previous post involving air bag issues.
  14. Feb 5, 2017 at 5:56 PM
    koditten
    Kirk
    Central Michigan
    Apologies. I didn't see where this was posted to the 2nd gen section. Not easy to pic that up on a phone.
  15. Feb 5, 2017 at 7:52 PM
    KenLyns
    Belly of the Beast
    Anyone know what type of scanner they use at Autozone, Pep Boys, etc. for reading codes? Maybe they can read the SRS code and help @pinktaco808 narrow down the culprit.
    You know what's worse than an airbag that doesn't work? One that deploys when it isn't supposed to. :devil:
  16. Feb 5, 2017 at 7:58 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    what year is your truck?
  17. Feb 5, 2017 at 9:19 PM
    pinktaco808
    2006 single cab 4 cylinder 125k miles. Accident long time ago like 2 years ago.light has been on since about 2 weeks ago right before my alt and batteries died. I changed both alt and battery. Horn works fine.
  18. Feb 5, 2017 at 9:32 PM
    koditten
    Kirk
    Central Michigan
    Now we are getting somewhere. Thank you .
    You want to know where the connectors are that you need to check. There are weight sensors under the seats. These are the most common connectors to get loose. Check those. You have sensors and connectors on the frame. These are the second most common offenders. There have been reports of the crash sensors on the frame getting corrosion and failing as well.
    All the wiring for the SRS (supplemental restraint system) is covered with a very bright yellow covering. Its the only place this color is used in all vehicles. You can easily follow these wires down and check all the connections.
    The nice thing about the SRS is that when you fix the problem, the light turns off. You don't need a code reader to clear the light. It turns off on its own.
    The SRS is a very robust system. You won't be accidentally causing the bags to deploy by checking these connectors.
    When you first start the truck, the SRS ECU does a check of the system. Its nothing more than a continuituy check. The ECU knows the resistance of all the sensors on the vehicle. If you have a bad sensor or sensor connector, you get the light. Once the issue is solved, the next time the truck is started and the light goes off and stays off.
    pinktaco808[OP] likes this.
  19. Feb 5, 2017 at 9:44 PM
    pinktaco808
    How
    How do I check them?
  20. Feb 5, 2017 at 9:48 PM
    koditten
    Kirk
    Central Michigan
    Just pull them apart and plug them back in. Most of the connectors have a double security lock. There will be some head scratching on how to get them apart. Just take some time and figure them out.
    llibrm and pinktaco808[OP] like this.
