AGM 24F or AGM Group H6 (48)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jerkwithkeyboard, Sep 14, 2023.
  1. Sep 14, 2023 at 7:04 PM
    jerkwithkeyboard
    jerkwithkeyboard [OP] Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Well Almost 5 years in and my Samsclub AGM 24F is getting weak. (OEM laster 34 months)
    Toyota Corp bought my replacement for me :thumbsup:
    It would last longer if i did the ECU Volt flash (can't find just the battery/ Not the $500 $700 Full flash ) i could be wrong..... it would be worth $50 ~$75 maybe (chicago West Suburbs)
    Yes i top it off with a charge every now and then, but it doesn't last long.
    Well the 24F has been hard to find lately, H6 is everywhere.
    I do think the H6 fits with maybe a little trim (1/8 inch wider)
    What did people do to get the H6 to fit?
    And it looks like a better battery anyways.
    Good idea or Bad ?
    Walmart has
    EverStart Platinum AGM Battery, Group H6 (12Volt/ 760CCA) $180.00
    NOT a FRIDAY THREAD ! :anonymous:
  2. Sep 14, 2023 at 7:26 PM
    K9tacoma
    K9tacoma Well-Known Member
    Austin
    Central Ohio
    2023 Tacoma TRD Off Road - Lunar Rock
    In for if anyone has used a similar substitute. Tried to pick up a 24F AGM at Costco yesterday and he said he couldn’t find stock at any of my local stores unfortunately
  3. Sep 14, 2023 at 9:04 PM
    jerkwithkeyboard
    Thats what I'm finding out, there hard to get at a good price
  4. Sep 14, 2023 at 9:51 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Group 27F (2nd gen towing pkg) and group 35 (2nd gen base) fit as well. I'm running an Optima Red 35, 720 CCA and 20 lb lighter than stock.
  5. Sep 15, 2023 at 1:46 AM
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    I just installed a Duracell 24F AGM from Sam's club on Labor Day. Set up an appointment for the following Saturday morning with my KDMax tuner Vic and he installed the 10.0 tune and adjusted the alternator output to 14.4 volts...so far, no complaints.
    jerkwithkeyboard[OP] likes this.
  6. Sep 16, 2023 at 6:17 AM
    jerkwithkeyboard
  7. Sep 16, 2023 at 7:05 AM
    K9tacoma
    Austin
    Central Ohio
    Does the 27F work with the stock battery tray? I’ve read mixed things. I’d prefer a drop in replacement personally
  8. Sep 16, 2023 at 7:41 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    A 2nd Gen with tow package has the correct battery tray for the 27F. However what you are reading is that it will fit without changing it out, but be aware it will overhang the stock battery tray.
  9. Sep 16, 2023 at 7:32 PM
    K9tacoma
    Austin
    Central Ohio
    Understood, thanks! I’ll do some measuring of my stock tray and see how it’s going to hang with a 27F. Sounds like they’re a lot easier to find and I’d like to have the additional capacity.
    shakerhood likes this.
  10. Oct 2, 2023 at 6:53 PM
    jerkwithkeyboard
    Well this didn't get many hits
    Is there a cheep way to just get the ECU flashed for a AGM battery Or i need to go back to the lead acid.
    My AGM is going fast and needs to be replaced.
    My Fiat AGM is on 9 years - Tacoma 4 and dead....
  11. Oct 2, 2023 at 11:08 PM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
  12. Oct 2, 2023 at 11:17 PM
    Benny22
    20Tacoma
    Worked fine in mine. Just a little trim on the tray.
  13. Oct 3, 2023 at 3:40 AM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Unless you have a VFTuner Pro friend, there is no cheap way to get an ECU tune just for the AGM voltage adjustment. On the cheaper end, maybe you are looking at $300ish, might as well get a full tune up too with the AGM setting.
    The other option is to hook your battery up to a battery charger (Battery Tender, Noico, etc.) every so often.
  14. Oct 3, 2023 at 4:59 AM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    I installed a 2 Amp charger and plug my truck in every month or so. Granted this battery is still new, but I usually get 5 to 7 years on my AGM batteries using a charger.
  15. Oct 4, 2023 at 6:03 PM
    jerkwithkeyboard
    Did the charger thing also. still only lasted 4 years. Granted way better than the OEM 2 years 9 months (yes Toyota corp bought my AGM for me)
    $300ish is better than the $700 i have read. Better MPG would help offset it some. i am running +1 bigger tires. Just not sure who to go to for it.
