Aftermarket Windshield Washer Reservoir finally available
Discussion in '1st Gen. Tacomas (1995-2004)' started by jammer, Feb 28, 2019.
  1. Jul 1, 2020 at 2:32 PM
    #41
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    There’s something to this. My ‘04 had been garage kept its whole life and the neck has dozens of cracks and looks like it will fall apart with the slightest provocation. I was considering this for $35
    https://www.partsgeek.com/gbproducts/AC/8218-04164236.html
    GQ7227 likes this.
  2. Jul 1, 2020 at 5:47 PM
    #42
    e304lyfe
    e304lyfe Member
    I ordered and installed that one very recently. It has the same problems as mentioned earlier in this thread that other people noted, so it is probably the same part. Filler neck is loose and the larger grommet is worthless (swap it with the one from your original tank).
  3. Jul 2, 2020 at 8:11 PM
    #43
    GQ7227
    GQ7227 mw survivor
    J A Y
    after 10pm here and the RH is 71% currently, always gets higher at night for some reason
    that is muggy!
    1997tacomav6[QUOTED] likes this.
  4. Aug 28, 2020 at 8:48 AM
    #44
    MomoFire93
    MomoFire93 Member
    Monika
    Reno, NV
    2003 V6 Tacoma 4x4 SR5 TRD Offroad
    Okay so this may be a dumb question but why do you guys do this? Is there a reason to move the location, like its more protected from the elements and cracks less or something?
    GQ7227 likes this.
  5. Aug 28, 2020 at 9:49 AM
    #45
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Hoping the material doesn't suck like the usual sized one. That being said, I got an aftermarket usual sized one and it is holding up so far, but I've only had it for a year and a half.
  6. Aug 28, 2020 at 10:17 AM
    #46
    moweebo
    moweebo Member
    I had to laugh when i saw this because ive got Gorilla tape holding mine together for the time being. Seems to be holding up though.
    GQ7227 likes this.
  7. Aug 28, 2020 at 11:47 AM
    #47
    umpire3
    umpire3 Well-Known Member
    Robert
    2004 Tacoma 4-door, V6
    ^^^^ Ditto.
  8. Dec 2, 2020 at 12:34 PM
    #48
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    the RTV I used on the filler neck joint near the actual reservoir isn't holding up that great, I might do something else with it but it's not really an issue unless I fill the container way up.
  9. Dec 2, 2020 at 1:09 PM
    #49
    Needfd
    Needfd Active Member
    99 extra taco
    Nothing wrong with Gorilla tape ;) ( Mine is duct taped)
  10. Dec 2, 2020 at 2:35 PM
    #50
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I sprayed the shit out of mine with flex seal and it hasn’t leaked a drop in 6 months. Hopefully it lasts a while but good to know there’s a cheaper replacement out there.
  11. Dec 7, 2020 at 9:29 AM
    #51
    foothill96tacoma
    foothill96tacoma Well-Known Member
    CORRECTION: This is the item I bought and installed.
    I bought and installed the model shared by the OP. Some observations:
    • The plastic is definitely thicker and less flimsy than the original, especially on the neck piece.
    • The install was straightforward
    • I did not swap out anything from the original part, as I wanted to see how it performed/leaked as is. Plus, it's an easy thing to pull and work on :)
    • No leaks thus far and it sprays fine on my windshield. The original U-shaped hose beneath the reservoir had a leak that I fixed by moving it around a bit and spraying it with a bunch of Flex Seal
    So far, so good. I'll try to remember to post a follow up review in a month or so after some miles.
  12. Dec 7, 2020 at 1:26 PM
    #52
    bcrooms
    bcrooms Well-Known Member
    Brandon
    Georgia
    1999 Toyota Tacoma XCab 2.7L SR5 4WD
    Glad I found this. Mine has been broken for awhile now and I can't fill it without losing half the fluid. I could do some flex seal i guess lol
  13. Apr 27, 2021 at 10:11 AM
    #53
    billpete
    billpete Well-Known Member
    Hendersonville, NC
    Had a 2002 DC, now a 2004 DC.
    Reading through this thread, is there a preferred aftermarket reservoir, or just take my chances with one of them? I do need the one with the low fluid sensor--I checked my truck for it. Thanks!
  14. Jul 7, 2024 at 12:56 PM
    #54
    SkyIer
    SkyIer Well-Known Member
