Aftermarket vs OEM Catalytic Converters
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JustinInATX, Feb 15, 2024.
  1. Feb 15, 2024 at 1:32 PM
    JustinInATX
    JustinInATX [OP] Well-Known Member
    Justin
    Texas
    2019 Super White TRD Off-Road 4x4
    So I have two quotes for replacing my cats (mine have gone bad at 100k miles). One quote is with Genuine OEM Cats and one for Aftermarket OEM direct fit cats. Any experience? Is the OEM worth the additional $1000?
  2. Feb 15, 2024 at 1:46 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    in general OEM last longer
    not all AEMs will pass inspection in all places
    Brianz1001 likes this.
  3. Feb 15, 2024 at 2:07 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    If it works, it works! I personally would not spend an extra Grand for oem cats for a truck with a 100K on the clock. But then again, what the hell do I know!
    4x4spiegel, Stevie17 and TacoTime55 like this.
  4. Feb 15, 2024 at 2:10 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    :sawzall: cant you go parking lot shopping for some OEM's??
  5. Feb 15, 2024 at 2:23 PM
    HiBillyMaysHere
    HiBillyMaysHere Well-Known Member
    PNW
    2021 TRD Off Road Access Cab
    Buy aftermarket as long as your state/municipality doesn't do inspections that will care. No reason to spend the markup on OEM on a 100k mile truck.
  6. Feb 15, 2024 at 2:38 PM
    GearHead899
    GearHead899 Well-Known Member
    Justin
    Ocean View, NJ
    11' Black X-Runner, 06' RR X-Runner
    In my experience, most vehicles dont like aftermarket cats. Meaning that most will still throw p0420 codes after. If your state doesnt do a visual inspection under the truck, you can just throw a o2 sensor spacer on the rear o2 sensor and it will do enough to keep the CEL from coming back on
    BoomerGVNG and BlueRibbonRM like this.
  7. Feb 15, 2024 at 3:46 PM
    BlueRibbonRM
    BlueRibbonRM Well-Known Member
    2023 TRD OR
    My experience has also been that at least 90% of aftermarket converters will throw an engine light at least intermittently. Some of them will do fine for certain types of driving but set the codes at other times. If you want to be certain no codes will set go with OEM. This is what I explain to all my customers when giving them their options. In most cases the best scenario is the aftermarket will last 1-2 years before the codes come back, and that is if they are properly heat cycled which no shop will take the time to do, general motors has a good description of an initial heat cycle that involves highway driving, shut down for a few, then continue driving basically.
    BoomerGVNG, D. Lengua and GearHead899 like this.
  8. Feb 15, 2024 at 3:47 PM
    BlueRibbonRM
    2023 TRD OR
    Also, unless there is a core charge associated with the new cats you purchase, request to keep the old ones as scrappers will pay good money for them.
    GearHead899 likes this.
  9. Feb 15, 2024 at 7:20 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    If you are in a non sniffer test state that answer is easy. And it doesn’t involve any cats.
    HiBillyMaysHere and ToyoTaco25 like this.
  10. Feb 15, 2024 at 7:43 PM
    gasganofj60
    gasganofj60 Well-Known Member
    87 FJ60 & 21 TRDOR
    Emissions aside, anyone ditch the cats?
  11. Feb 15, 2024 at 8:06 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    If the vehicle is registered in Brazoria, Fort Bend, Galveston, Harris, Montgomery, Collin, Dallas, Denton, Ellis, Johnson, Kaufman, Parker, Rockwall, Tarrant, Travis, Williamson, or El Paso counties, you may want to lean towards the OEM cats. These are the only Texas counties with annual auto emissions testing.
  12. Feb 15, 2024 at 8:14 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    In this department, I would go OE, unless you plan to dump it in another year or two.
    Maybe see if you can shop em online and get local dealer to match or have shipped (if size allows) and have an independent shop install to save some money.
    BoomerGVNG likes this.
  13. Feb 15, 2024 at 8:25 PM
    MattiasdelTaco
    MattiasdelTaco unknown member
    Illinois
    2023 trd sport MT
    swapped for clean, scoopless hood
    Based on very limited other Toyota experience, I would say oem is not worth it, and you may be better off getting a quote for universal aftermarket cats from a shop that does a lot of exhaust work instead of direct fit if direct fit is a custom to the taco part and significantly more expensive?
    On a previous Toyota one mechanic said i had to go oem because Toyota makes the computer very picky, but when i went to an experienced exhaust shop, the aftermarket ones installed were about a third if the cost of the oem part including install. They made the light+code clear, just as they said it would, but i can’t give an anecdote on longevity because i sold the car within a month. Anyways, even if they coded later, replacing or rotating cats every 2 years for the emissions test still seems cheaper than spending 3-4x as much for oem.
    Aren’t the oem cat converters supposed to last a really long time, 100k seems very short!? I thought they should go for 300k + based on nothing just making up a number, ….
    Anyone who knows more, and still reading, have a summary of what they have gleaned as being normal cat part life, and why cats can go bad early other than mfr part quality?
  14. Feb 16, 2024 at 2:47 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    OE cats. My 99 4runner cats just started o have a blockage and throwing the code. My 4R is sitting at 292K miles and is in impeciable
    condition so I paid up $1800 for new cats and sensors. To me its worth it.
  15. Feb 16, 2024 at 5:14 AM
    GearHead899
    Justin
    Ocean View, NJ
    Me. Both of my trucks are catless
  16. Feb 16, 2024 at 5:23 AM
    soggyBottom
    soggyBottom Well-Known Member
    Yeah but the exhaust smells like ass without them.
  17. Feb 16, 2024 at 6:09 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    No joke. I wouldn't want a DD without cats again.
    OP I'd look for a used OEM setup. Look in the classifieds here.
    Koolbreeze7 and BoomerGVNG like this.
  18. Feb 16, 2024 at 6:21 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    Toyota/lexus vehicles are notoriously picky when it comes to aftermarket cats, so if you decide to go aftermarket be prepared mentally and financially to have to do them again with OEM anyways.
  19. Feb 16, 2024 at 6:35 AM
    GearHead899
    Justin
    Ocean View, NJ
    Am I the only one who loves the smell of catless exhaust?
  20. Feb 16, 2024 at 6:53 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    100k miles? All of my previous trucks - all of them including the Ford and Chevy - never needed new cats even when pushing 300k miles with the other Toyota’s. And I live in Cali. Is this really something to look forward to with a 3rd Gen when it hits its first 100k?
    Either Newer Tacos have shi-y cats, or you guys are getting really crappy gasoline where you live that is prematurely ruining your cats.
