Aftermarket tint doesn't match color
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaWillow, Aug 30, 2022.
  1. Aug 30, 2022 at 8:04 AM
    TacomaWillow
    TacomaWillow [OP] Well-Known Member
    Catherine
    2022 4WD 6 cyl SR5
    My 22 SR5 access cab came with the back side windows tinted but not the front side. I just took it to the best tint shop in town to have them match the back. Well they are now similar in darkness, but the factory tint is more smoke grey and aftermarket has a slight green cast. Now I'm looking at other cars on the road and I see this is common, but I don't like it.
    Is there an aftermarket tint that is true grey or otherwise matches factory, instead of green grey?
  2. Aug 30, 2022 at 8:08 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    What kind of tint did you get? Ceramic? Top-end ceramic?
    I have the highest grade ceramic my shop offered and I haven't noticed any green grey-ness from it.
    Chew likes this.
  3. Aug 30, 2022 at 8:08 AM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Toyota rears are super hard to match. I had to get the back tinted with a higher percentage to match. FYI the rears aren't tinted just a dye in the glass.
  4. Aug 30, 2022 at 8:09 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    You'll never get a 100% match. The factory glass has the "tint" made into the glass as opposed to adding a film later.
    I got close with 35% ceramic.
    FlyingWolfe, Wulf and Delta09 like this.
  5. Aug 30, 2022 at 8:14 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    As noted by everyone above the difference is hard to match. That said if you go 35 or 50 pct over the factory glass it hides almost all of the color of the smoked glass and is easier to match darker front tint to.
    SoCal_Erik likes this.
  6. Aug 30, 2022 at 8:40 AM
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    So get this 25% tint removed from the front and then have both front and back tinted to match?
  7. Aug 30, 2022 at 8:56 AM
    bonifacio_629
    bonifacio_629 Well-Known Member
    Walther
    Virginia
    2018 Tacoma TRD Sport, 6MT 4x4 DCSB, Inferno
    Predator steps, TRD cat-back, lots of orange stickers.
    My tint guy advised me NOT to go with ceramic, or at least the kind he offered, because of matching concerns. The one he helped me select is pretty close to if not identical in color to the rears. I also had the back windows done in a lighter film to achieve 20% tint all around.
  8. Aug 30, 2022 at 9:16 AM
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    Do you know what brand or type of tint he used to get that match?
    This might be something I get used to by tomorrow, but I'd like to know there are options if I still hate it
  9. Aug 30, 2022 at 9:18 AM
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    That does look good.
  10. Aug 30, 2022 at 10:25 AM
    Plain Jane Taco
    USA
    Ceramics are much more stable over time. The pigment in the very best dye film will eventually breakdown and turn purple under UV radiation. Most ceramics offer a lifetime warranty against it.
    The tint is 7 years old in this picture. Sits out in the sun all day at work.
    Steves104x4 and Wulf like this.
  11. Aug 30, 2022 at 11:23 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    The 2 fronts have a 'greenish' tint from the factory. When you add tint film, it still shows a little green.
  12. Aug 30, 2022 at 11:31 AM
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    Really? That's weird; they looked like untinted clear glass to my eyes.
  13. Aug 30, 2022 at 5:06 PM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    I went 50% of the same tint type all around all windows. The rear windows are thus darker than the fronts since the rear smoked glass is darker than 50% already, but all the windows now have a slight grayish tinge to the black that makes them match all around. If I wanted the front windows to match, I'd probably have had them just done in a darker color but using the same tint type to match the color tinge (in my case I mainly wanted the heat reflective properties of ceramic all around without reducing visibility in the front windows too much, so I wasn't trying to match the darkness of the windows)
    TacomaWillow[OP] likes this.
  14. Aug 30, 2022 at 8:33 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  15. Aug 30, 2022 at 8:40 PM
    SoCal_Erik
    SoCal_Erik Tiki Taka, Tika Taka
    ‘23 Tundra SR5 Sport, ‘16 SR5 DCSB (sold), ‘15 SR5 DCSB (sold), ‘16 4Runner SR5, ‘15 OR DCSB (sold), ‘05 SC (sold)
    Just tint the rear windows a bit and you’ll love the look. They’ll be slightly darker than front for more privacy and the truck will look sleek.
    idk about that green though. I’d have to see it.
    Wulf likes this.
  16. Aug 31, 2022 at 6:38 AM
    Technique
    Alex
    Utah
    Oh yeah, I do have my rear windows at 0% and front at 5% that's probably why I don't notice any green lol. whoops.
    I'd still get ceramic all around for heat reduction and lifetime warranty.
    Wulf likes this.
  17. Aug 31, 2022 at 8:03 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  18. Aug 31, 2022 at 9:05 AM
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    It isn't bothering me quite as much today, because I think the front windows would look darker if the windshield were tinted - it is flooding the front with light and that's part of why they look lighter from the outside. That won't fix the green, but it would be less noticeable.
    Both these windows were $100 all in and I suspect top of the line ceramic would cost a bit more?
  19. Aug 31, 2022 at 9:13 AM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    There are companies that can bake the tint into the glass. May want to look in to that if you're that picky, IMO.
  20. Aug 31, 2022 at 9:17 AM
    SSMTRDOR
    2020 TRD OR 4X4
    Looks good. I only did the 2 fronts also. LLumar ATC 30. $80 USD installed.
    The 2 fronts are a little lighter than the rears, but I'm pretty happy with the results.
