Aftermarket or OEM catalytic converter and O2 sensors?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mainmoe02, Apr 29, 2013.
  1. Apr 29, 2013 at 8:11 PM
    Mainmoe02
    Mainmoe02 [OP] Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I'm hearing too many people say that the aftermarket cats don't last long. Or that the aftermarket cats are not meant to be on the Tacoma, so if you have a check engine light on then putting an aftermarket cat won't clear it because the sensors or electronic system won't match it correctly.
    The price difference is what makes me second guess what I should do. What I want is a product that will last and do the job. So if that means spending more on an OEM cat then I'm fine with that. Just thought I'd ask for the opinion and experience from others.
    Also, if I go with an OEM cat, am I able to just switch it out or should I take it to a muffler shop?
    Last question... Is there 1 or 2 cats on a 2001 3.4L Tacoma. I've been told there are 2, but also reading other people posts about how their truck is under California emissions so they have 2 cats. I'm in Austin, Texas so I'm not sure if mine should have 1 or 2. I took a look the other day and it looked like there were 2 cats. But then I looked online at Toyota.com and the diagram on their website said the 3.4 only has 1 cat. So I'm kind confused as to how many cats my truck has and actually needs to have in order to pass emmissions testing here in Austin.
    Thanks for y'all's help!!!!!!!
  2. Apr 30, 2013 at 7:26 AM
    tacocass
    tacocass Active Member
    cass
    okie-homa
    taco sr5 4X4 3.4V6
    BIL 5100'S, PRO-COMP 1" REAR BLOCK, DECK PLATE MOD W/ KN
    Just ran into this problem. I did a lot of research! I went with the magnaflow oe highflow cat. I ordered it from summitracing, $328 shipped for the front cat. It fit wonderfully and I have 0 issues. As for sensors, I went oe. hope this helps a little!
  3. Apr 30, 2013 at 8:26 AM
    peow130
    peow130 Active Member
    Bryan
    Spokane, WA
    1998 Taco TRD w/ 2.5" Skyjacker lift and 33's
    2.5" Skyjacker Platinum
    Did u check your o2s yet? Its pretty unlikely the catalytics are bad.
  4. Apr 30, 2013 at 8:33 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    I have 2 cats, they are fine at 180k and hard driving.
    Check your thermostat and only replace your O2 sensors from Legit sources like rock auto or URD and LCEngineering, They know what parts are needed and usually is the same as the dealer for less.
    Brie likes this.
  5. May 7, 2013 at 4:57 PM
    catrailrider
    catrailrider Active Member
    I put on a cheapie aftermarket and now have a "catalytic converter below efficiency" CEL and a smog due next month. A guy at work went thru the same thing a put a Magnaflow on his Taco without issues. I'll be looking for one this weekend
  6. May 8, 2013 at 6:11 AM
    Mainmoe02
    Moe
    Austin, Texas
    Well I found out that my rear Cat Conv. and O2 sensor are bad. I took it to a shop so they could test the exhaust system and tell me what wasn't working properly. When I got the code (po420) pulled at autozone they said that code meant it could be either a bad O2 sensor on bank 1 (front) or bank 1 Cat Conv. I'm glad I took it in to get tested or else I would have replaced the wrong parts. I'm guessing that the code P0420 doesn't always mean that it's only for the front sensor or cat converter. Heads up to all who have this code on their vehicle. Just because its code P0420 doesn't always mean bank 1, it very well might be bank 2.
    I'm gonna go with an aftermarket magnaflow Cat. because I've heard good things. If anyone doesn't think I should please chime in.
    Thanks!!!!!!!
  7. May 8, 2013 at 10:29 AM
    peow130
    Bryan
    Spokane, WA
    http://www.urdusa.com/product_info.php?products_id=1230100014
    That will fix your issue, without having to get a new catalytic.
    Either that, or get a new front o2.
  8. May 8, 2013 at 12:31 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Actually this is not uncommon at all. One of the number one causes of your catalytic converter going bad is correlated with not replacing your spark plugs at the recommended interval. Fouled plugs don't properly combust the air/fuel mixture which leads to not only wasted fuel, but unburnt fuel going to the catalytic converter. The unburnt fuel is heated and burnt in the converter basically destroying it and the element inside it.
  9. May 8, 2013 at 6:38 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
  10. May 9, 2013 at 4:31 AM
    catrailrider
    Replaced spark plugs and both 02 sensors, CEL still on. Started looking for exhaust/intake leaks. Everything good, CEL still on. Then my neighbor came over with a Snap-on code reader that can monitor things in real time. We were watching the pre and post O2 sensors while the engine was running and the post cat sensor was all over the map fluctuating huge numbers. That told me the cheapie cat was not doing its job
  11. May 9, 2013 at 9:26 AM
    Yamaha Dave
    At what interval did you replace your plugs? If the converter was already damaged because of prolonged plug use, changing the plugs afterwards would obviously not fix the converter.
  12. May 9, 2013 at 6:35 PM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    You know that could also mean the sensor is bad. It probably IS the cat, but my O2 sensor on my last truck had a rapidly fluctuating signal when it went bad.
  13. May 9, 2013 at 7:43 PM
    Bmack04
    Bmack04 Active Member
    Ohio
    04 DC trd 4x4
    deck plate mod, grey wire mod, 5100s front w/OME 881s, 5100s rear w/wheelers 5 leaf, 265/75R16 Firestone Destination A/Ts
    If you are going to try to troubleshoot your front/rear HO2 sensors and or cat converter by watching your voltages in real time via scan tool, you need to ensure that the converter is warmed up when you start judging them. When you first start the truck when the converter is "cold", your front and rear HO2 sensors will read virtually the same as far as voltage and switching. However, after a couple minutes of driving, the converter and HO2 sensor should be fully warmed up and functioning and although the front HO2 sensor will fluctuate rapidly, the rear HO2 should not fluctuate to the same voltage extremes or as rapidly. If after a few minutes of driving the front and rear HO2 sensor voltages are switching at the same pace and to the same extremes, it would be safe to assume that the cat converter is not doing its job. USUALLY, the ECM will pick up on this condition and set a code. This is all assuming that the HO2 sensors are heating up properly as they both have heating elements in them, however the ECM monitors the HO2 that they are heating up in the proper timeframe, and will set a code accordingly. I strongly recommend the use of OEM HO2 sensors as I have seen the cheap ones that don't heat up properly or that can be "lazy" in their voltage readings and switching, which can "trick" the ECM into setting false codes causing hard to diagnose drivability issues. Hope that this information is helpful in troubleshooting your problem.
    P.S. A faulty rear HO2 will never cause a drivability issue as its only function is to monitor the effectiveness of the cat converter.
  14. May 9, 2013 at 7:51 PM
    catrailrider
    Bmack, yes the truck was not cold when we were watching the O2 sensors and there were replaced with OEM Denso sensors. The only reason why I don't suspect a faulty new sensor is because a few weeks after the cat was replaced the old sensor triggered the same code. Also you are correct about the drivability as performance or mileage hasn't changed
  15. May 9, 2013 at 7:56 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    ive had the same code before, replaced upstream sensor and rear 02 sensor and was good, my cats have 275k on them and are still good btw
  16. May 10, 2013 at 2:18 AM
    808DAKINE
    808DAKINE Well-Known Member
    Kai
    Lahaina, Hawai'i
    01 Taco
    Cold air, Sounds, lift, lights, exhaust and a canoe!
    Just had the p0420 code.. turns out it was a bad spark plug..
  17. May 10, 2013 at 3:50 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    2001 was the transition year that Toyota began making Tacomas with two cats across the board, not just for California. However, the early 2001s had only one cat while later 2001s had two cats.
    Another possibility for the P0420 code is an air leak in your exhaust. Inspect the pipes before your second cat for holes and the gaskets at your flange joints. If you see any water leaking from the flange joints, you may just need a new gasket.
  18. May 15, 2013 at 8:54 AM
    peow130
    Bryan
    Spokane, WA
    Why wouldn't it?
    All a P0420 is is saying that your catalytic converter isn't efficient enough.
    That clears up the p0420.
    If nothing else appears except p0420, then why not?
  19. May 15, 2013 at 11:38 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I had a p0420 code but I knew that the cat was gutted. Picked up a used but still new Catco Cat and it cleared it right up. Only cost me $30 on Craigslist.
  20. May 16, 2013 at 11:50 AM
    catrailrider
    You can get away with that in most states
    Here in the Republic of Kalifornistan you'd be strung up by your manhood
    http://i.imgur.com/b5grOaC.jpg
