Aftermarket Mud Flaps to Eliminate Rubbing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Captains1911, Jun 6, 2023.
  1. Jun 6, 2023 at 9:32 AM
    Captains1911
    Captains1911 [OP] Well-Known Member
    2023 Tacoma TRD OR 4x4 AT DCSB
    I have a '23 TRD OR. After upgrading to 17" TRD Pro wheels and BFG K02 265/70/R17 tires, there is rubbing on the OEM mud flaps (even though this forum suggested it wouldn't...) I tried forming them with a heat gun but it didn't help. I live on a gravel road so I want mud flaps, but the rubbing is annoying. Are they any aftermarket flaps that might eliminate the rubbing?
  2. Jun 6, 2023 at 9:46 AM
    Buggin112
    Buggin112 Well-Known Member
    Portland, Oregon
    2022 Tacoma TRD Off-Road
    I am in the same boat. Going in for an alignment this weekend to get the caster adjusted for more clearance.
    eurowner likes this.
  3. Jun 6, 2023 at 9:50 AM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    Rok Blokz Rally XL mud flaps have a little cut out section for bigger tires
  4. Jun 6, 2023 at 11:36 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Before I bought my Michelins at the end of last year I read through a lot of posts regarding this. I'd say it was about a 50/50 split between those who had no problem and those that had some rub on the OEM mud flaps. In the end I didn't want to be trimming or taking my mud flaps off altogether so I just went with the stock 265/65/R17s rather than chance going up to a 70. For the light non-pavement driving I to they are just fine.
  5. Jun 6, 2023 at 11:45 AM
    Captains1911
    For the record, I too read through many threads and posts, and recall it being closer to 95/5 (no rubbing/rubbing). Moot point now I guess. I'm considering trying out the Rockblokz flaps, hopefully that solves it.
    FL_TRD Sport[QUOTED] likes this.
  6. Jun 6, 2023 at 1:12 PM
    TacoGranny
    TacoGranny Well-Known Member
    2020 TRDOR DCSB Cement 6MT
    33's, Sliders, Skid Plates, Softopper, ATH rear bumper
    https://rokblokz.com/collections/to...a-tacoma-mud-flaps-2016?variant=6401422589995
    I went with these (in the original size) when I upgraded to 255/85R16's, they work great, and no rubbing (although expensive for what they are).
    The cutout is for the cab mount and allows you to mount the flaps tighter to the wheel well. I cut the cut out with a razor blade (which I do not recommend, it took forever), if I was doing it again I'd use a dremel or something.
    SoonToBeOn39s[QUOTED] likes this.
  7. Jun 6, 2023 at 1:17 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    It’s not 50/50, they all rub the same if running the same size tire and same flaps and rims. Your rim definitely would rub flaps with 265/70. With 265/65 it would not, as you have experiences.
    the 50/50 comes from half the folks not even having mud flaps, so they won’t rub nor will they mention anything. Have to see pics from them and pay attention to notice they don’t have flaps, which means their input is next to worthless.
    Meanwhile I just put 255/75 (32.1”) on Sport wheels and they’re not even close to rubbing the flaps. Love it.
  8. Jun 6, 2023 at 1:18 PM
    Captains1911
    Without the cutout option, I assume they still provide more clearance than the OEM flaps?
  9. Jun 6, 2023 at 1:21 PM
    Captains1911
    I recall several people, with the identical wheels and tires and me, and with OEM mud flaps, who reported zero rubbing issues. Maybe these people only ever drive on flat pavement with no bumps..
  10. Jun 6, 2023 at 1:21 PM
    BLtheP
    Plano, TX
    Folks who suggested you would not have rubbing with that rim don't have mud flaps. There is a lot of mixed up advice and experiences thrown out there. That rim will 100% rub the mud flaps with 265/70R17, every time you hit a minor bump with the wheel turned practically at all.
  11. Jun 6, 2023 at 1:22 PM
    BLtheP
    Plano, TX
    I actually just replied to your other post, but I'm not sure what kind of world those people live in. I've seen countless people with flaps and the same wheel and tire size have rubbing on turns with bumps. I did as well, until I traded for Sport wheels.
  12. Jun 6, 2023 at 1:22 PM
    TacoGranny
    I'm sure the clearance is better, but the cutout is worth doing. The cutout is just a small portion on the front flaps (the odd shaped area below the 2nd mounting hole on the top flaps pictured below). It avoids interference with the cab mount.
  13. Jun 6, 2023 at 1:32 PM
    Captains1911
    Thanks for the info, I'm going to give these a try. Cheaper than a lift...
  14. Jun 6, 2023 at 1:38 PM
    Brownie_Man
    Brownie_Man Well-Known Member
    Maine
    2019 Off Road
  15. Jun 6, 2023 at 2:03 PM
    Buggin112
    Portland, Oregon
  16. Jun 12, 2023 at 6:18 AM
    Captains1911
    The Rock Blokz flaps seem to have solved my rubbing issue. I installed them with the portion cutout for larger tires, and without the supplied spacers, to provide the greatest clearance. Thanks everyone, this forum is very helpful.
    02Duck and FL_TRD Sport like this.
  17. Jun 12, 2023 at 9:30 AM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    went from rekgen to rokbloks when I went from 265/75/16 to 285/75/16 and I dont have any rub.
  18. Sep 6, 2023 at 10:14 PM
    Faroutspacenut
    Faroutspacenut Well-Known Member
    Southern California
    2020 DCLB TRD OR
    FWIW I just put 265/70/17 on my truck today and yep, I got the rub. This is with stock suspension.
  19. Sep 7, 2023 at 2:42 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the 2nd gen oem running boards will block alot of the rock throw too
  20. Sep 12, 2023 at 5:52 PM
    Captains1911
    For whatever reason I’m getting some slight rubbing now with the Rock Blokz flaps. I’m not sure why it wasn’t an issue for about 3 months right after I installed them, but it is now. I’m just going to learn to live with it for now.
