Aftermarket lower control arms - which one is better?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lagbc, Apr 15, 2020.
  1. Aug 27, 2020 at 6:40 AM
    #41
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Looks like you already got them, but we use Beck/Arnley when we replace UCA's in our shop, and have never had an issue. I personally have Moog on my truck for the last 3-4 years and have also never had an issue, and I've jumped my truck on 35s etc.
    What cam hardware are you using? SPC?
    tacotoe, Dalandser and Crikeymike like this.
  2. Aug 27, 2020 at 8:33 AM
    #42
    taco912
    taco912 Well-Known Member
    North of the Bridge
    2006 AC 4.0 AT 4x4 SR5 TRD OR
    I know this is a done deal but having just rebuilt my UCA's and LCA's (Energy Suspension & Proforged) let me say, this is not a bump and run project. For your average R&R driveway mechanic with "basic" tools buy complete assemblies. Just doing an R&R on all 4 is a Saturday 4-beer day with basic tools and there are many video walk throughs. If you can get aftermarket parts for $500 and you get 40-50K miles, run and don't look back. It is all you, your pocket book and skinned-up knuckles need. JMO
    tacotoe and Crikeymike like this.
  3. Aug 27, 2020 at 8:57 AM
    #43
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Pressing bushings and balljoints can be a huge pain in the ass for sure. If you can get a coupon for one of the harbor freight H-frame presses and perhaps the balljoint replacement kit (you can use the cups it comes with in conjunction with the press for a lot of bushings as well) it can make it a lot easier. Still much harder than just swapping out the complete part for sure though.
  4. Aug 27, 2020 at 9:15 AM
    #44
    taco912
    North of the Bridge
    Oh yea, I have a 12 ton press, bent the hell out of the HF BJ "C" clamp press doing the BJ's on my old 4x4 Ranger and still had to go buy the HF decated Master BJ adapter set. Seriously, I tried everything including grinding up galvanized plumbing couplings to fit. Could not have gotten the job done without the HF adapters and pieces from the "C" clamp set. Now we can talk about burning out the bushings and cleaning up the hardware to install the Energy Suspension poly. I know of which I speak. LOL. :thumbsup:
    toytaco112 and tacotoe like this.
  5. Sep 19, 2020 at 6:53 PM
    #45
    lagbc
    lagbc [OP] Well-Known Member
    Canada
    I have only done about 4k miles/6k km since I replaced them and they are holding up fine, should probably get some pics. I wouldn't expect them to fall apart that soon, so time will tell :)
    Crikeymike likes this.
  6. Sep 19, 2020 at 6:55 PM
    #46
    lagbc
    Canada
    Not sure what is cam hardware, but I do have upper SPC control arms and for lower I bought new OEM inserts (adjustment sleeves).
  7. Sep 19, 2020 at 7:03 PM
    #47
    lagbc
    Canada
    Now that I have "spare" OEM LCAs I might go this route when/if these fail. But I would buy brand new parts as I did again if I didn't have spares.
  8. Oct 31, 2020 at 5:48 AM
    #48
    joshsinclair
    joshsinclair Member
    I just swapped to Delphi from stock, I like it! Went off a jump and felt the same, I do notice when I crank it all the way right it kinda sounds like a rubbing sound but not really ? I can’t tell yet, maybe it’s just the sound of it since it’s cheap, it only makes the sound when backing up really full crank
  9. Oct 31, 2020 at 5:49 AM
    #49
    joshsinclair
    joshsinclair Member
    For 364$ and 183$ labor in Mexico. I think it’s a great deal lol
  10. Jan 25, 2022 at 5:55 PM
    #50
    luka4600
    luka4600 Active Member
    Luka
    tofino Bc Canada
    06' 2.7 Turbo, 5 Speeed
    Eibach Pro truck lift, 33" Grabber atx, 4.88 Yukon Gears, custom turbo kit
    good choice going beck arnley in most cases they are toyotas oem provider ik this as i work for toyota parts, if i ever have to source aftermarket parts i go with them first as its very common to see toyota oem part numbers stamped on beck arnley products meaning they just reboxed oem. if you ever have the option of beck arnely go for it!
    TRDSport10 likes this.
  11. Jan 25, 2022 at 8:48 PM
    #51
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I’ve got about 50k miles on a set of Moogs with zero issue.
    TRDSport10, pahaf and tacotoe like this.
  12. Jan 25, 2022 at 9:37 PM
    #52
    TacoTuesday1
    FL
    Every OEM is garbage. What’s nice is fabricated. I can’t afford fabricated.
    so I bought new arms like $30/ea from China.
    because it would not be wise to overpay $300 on marked up stamped cheapshit
  13. Jan 28, 2022 at 5:03 PM
    #53
    jstanley
    jstanley Well-Known Member
    Central TX
    2013 TRD Sport 4x4 Pyrite Mica.
    OTT, OME, Dakar, Eaton rear locker, camper shell, Konig Six Shooters and 33" Wildpeak tires, Pelfreybilt front bumper and skids
  14. Feb 22, 2022 at 12:22 PM
    #54
    steveo27
    Pittsburgh
    Update.
    Truck failed inspection because of a bad lower ball joint
    No boot damage. No noise. No indication until I unbolted the spindle and shook the steering stop. Manufacturing error? No enough grease? Hard to say.
    Passenger side was fine.
    Not sure how it got so bad or when.
    Would I still purchase Moog LCAs?
    Yes.
    For 100$ a pop. I got about 3 years/50k miles of abuse out of them. 30$ a pop and about 30 minutes of my time a side to replace the ball joint, they are still worth it I think.
    The bushings are still holding up solid and aren’t frozen.
    Saskabush and burrito782 like this.
  15. Oct 17, 2022 at 2:21 PM
    #55
    JordansBlackTaco
    JordansBlackTaco Well-Known Member
    Jordan
    Arkansas
    2019 DCSB TRD Off-Road
    To be fair, I’m on this thread because my 3rd Gen LCA bushing and ball joints are toast with only 45k miles and no harsh off-roading.
  16. Oct 26, 2022 at 10:54 PM
    #56
    blahbaconblah
    blahbaconblah Member
    T
    2009 Tacoma Regular cab 4x4
    Has anyone ever tried the Autozone "Duralast" arms with limited lifetime warranty?
  17. Oct 27, 2022 at 7:02 AM
    #57
    BusyBee212
    BusyBee212 Member
    Doug
    2010 Tacoma 4x4 2.7L
    Do you have any proof to share with us since you are so strong on that stance? Tacoma frames have been rotting out faster than other truck brands on model years since the late 90s, what makes you say that Toyota really cares about the quality of their OEM parts versus an aftermarket company??
  18. Oct 27, 2022 at 8:04 AM
    #58
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I work at a Toyota dealership, so I get to see aftermarket junk failing at much higher rates than OEM every day. Remember, OEM parts need to last at least until the original warranty runs out. Aftermarket? You might want to check that out. You'll find that their warranty is significantly shorter - which explains how their manufacturing costs are lower, so their prices are lower, and the parts don't last as long.
    As for actual proof, I'll offer my favorite true story. I was asked to deliver an OEM Toyota Tacoma Intermediate Steering Shaft to a local shop. They had quoted a price to replace an original one with a Dorman part and the customer balked when they said the Dorman part was just as good as OEM. The customer was there when I walked in, and we plopped both parts on the front counter. The Dorman part looked like a toy compared to the OEM part leading to some red faces at the shop. Yes, they put in the new OEM part.
    As for the frames, yes, that's an issue. Do you know of an aftermarket frame supplier that makes better frames so we can compare them?
    So yes, I'm unabashedly pro OEM. Most folks don't get to see the difference between OEM and aftermarket parts like I do. It really opened my eyes.
  19. Oct 27, 2022 at 8:11 AM
    #59
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Probably doesn't help you much....but I put Duralast LCAs on my daughter car 3 years ago. No issues
  20. Oct 27, 2022 at 8:16 AM
    #60
    BusyBee212
    BusyBee212 Member
    Doug
    Strictly control arms are you claiming that the ball joint or bushing might wear out sooner than an OEM part on say a Moog part or are you going so far as to say the Moog control arm is going to break in half.
