Aftermarket Flywheel Recommendation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacotime24, May 23, 2022.
  1. May 23, 2022 at 12:54 PM
    Tacotime24
    Tacotime24 [OP] Well-Known Member
    Ethan
    Oregon
    2017 Tacoma MGM DCSB MT 6-speed, 93 Toyota Pickup 3.4 swap
    Well clutch grenades itself at 67k. I have clutch master TOB and Phoenix friction stage 3 clutch too. Finally pulled my transmission out and Im in need of a new flywheel or having oem resurfaced. LCE is in the works of flywheel not eta. URD from what I've read isn't supporting 3rd gens any further or out of stock. I'm close to 6k in weight and I do offroad. Would it be a bad idea to use another stock flywheel?
  2. May 23, 2022 at 10:31 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Following for the future
  3. May 23, 2022 at 10:48 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    URD and Marlin both actually recommend I use a OEM flywheels in the past unless I absolutely needed a heavy one (which I did) when I did my clutch.
    But only 67k on a clutch?
    I feel like something is out of adjustment or you're doing something wrong.
    This is my OE disk with 144k on it.
    Plenty of life left.
    hiPSI, ConantTaco, RustyGreen and 2 others like this.
  4. May 23, 2022 at 10:58 PM
    Tacotime24
    Ethan
    Oregon
    Well I've been driving manual for 12 years no issues ever. I was negligent and felt the clutch start slipping quite some time ago. Buy once cry once kinda thing now. Don't wanna drop the trans twice for a flywheel. I don't tow often I'm regeared to 5.29. Could be bad luck I guess :censored:
  5. May 23, 2022 at 11:03 PM
    Key-Rei
    Key
    Florida
    Why did you take the bell housing off? o_O
    But yeah, if you're geared and and don't tow and feel like you have enough torque to tire when doing your preferred off roading without slipping then just stick to OEM.
    And if you slipped it enough to disintegrate the material like that I *STRONGLY* recommend you purchase new OEM as I can almost guarantee your's is too far gone to machine.
    Plus machining screws up the tolerances, you can usually get away with one time if it's not bad but IMHO not worth it just buy a new fly.
  6. May 23, 2022 at 11:06 PM
    Tacotime24
    Ethan
    Oregon
    Had to take it off due to the amount of material that was lodged and stuck couldn't be cleaned properly.
    ConantTaco likes this.
  7. May 23, 2022 at 11:07 PM
    Key-Rei
    Key
    Florida
    :ohsnap:
    hiPSI likes this.
  8. May 24, 2022 at 6:06 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Bump for good content. There is too many trash threads on this forum that ones like these get buried and forgotten
    Tacotime24[OP] likes this.
  9. May 24, 2022 at 6:29 PM
    Amanelot
    Amanelot Member
    Texas
    Well, I tried guys. Looks like this one is doomed to the depths of page x
    tacomalex1949 likes this.
  10. May 24, 2022 at 6:30 PM
    Tacotime24
    Ethan
    Oregon
    Will update once I find a good resolution :fingerscrossed:
    StandardTaco and Amanelot like this.
  11. Nov 22, 2022 at 6:24 PM
    tacomakid89
    tacomakid89 Awesome Member
    William
    Austin, Texas
    2010 Black, 4x4, TRD Sport Tacoma
    Hard Wired GPS, Scan Guage II, URD Short Throw Shifter, AFE Pro Dry S Air Filter, LED Mag Lite on seat side,Tailgate Theft Prevention Mod, Removed Front License Plate, Tint Cover Over Rear License Plate, Removed Secondary Air Filter, 13" Shorty Antenna, 5% Tint Rear, 20% Tint Front, Bed Extender, TRD Cat Back Exhaust, Fog Light On Anytime Mod, Dual Halo Projection Headlights, Disabled Seatbelt Chime, King coilovers with remote resi in front, Kings with remote resi in rear, Deaver J66 leaf packs, TC UCAs up front.
    Which flywheel did you end up going with? I will be replacing mine during the holidays coming up and I'm not sure if I should get a light weight, heavy weight or OEM flywheel. Thanks.
  12. Nov 22, 2022 at 7:08 PM
    Tacotime24
    Ethan
    Oregon
    Went with OEM resurfaced. 2nd gen could be a different since your gen has been out way konger and the support is there. I went to my local dealership they told me they haven't even done a clutch on a 3rd gen... but I did it myself :rofl:
