Aftermarket Drum Brake Kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scifidelity, Dec 14, 2020.
  1. Dec 14, 2020 at 9:31 AM
    scifidelity
    scifidelity [OP] Well-Known Member
  2. Dec 14, 2020 at 10:48 AM
    max_o
    max_o Well-Known Member
    Colorado
    2018 Silver Sky DCSB OR
    Power Stop is pretty reputable, but I agree, slotted and drilled drums? Interesting. I garage my truck and the rear drums are already pretty rusty. Was thinking of rattle canning them. Thanks for posting this, I may consider this when I replace in a year or two.
  3. Dec 14, 2020 at 11:25 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    I think that webpage is pretty messed up. They're talking about rotors, but display an image of drums.
    There are no drums listed on the PowerStop website, but they do have brake shoes available.
    I wouldn't order that kit and expect to get what you see in the photo.
    shakerhood and Skydvrr like this.
  4. Dec 14, 2020 at 11:30 AM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    SE MI
    LT, triple locked, 35s, custom aluminum utility bed with FWC
    some welding required
    It'd be best to call/email to check what they are selling for sure.
    Definitely confusing with their description too
    What's in the Box
    • (2) Rear Rotors
    • (1) Driver-Side Rear Brake Pad
    • (1) Passenger-Side Rear Brake Pad
    • (1) Stainless Steel Hardware Kit
    • (1) High-Temperature Lubricant
    • Installation Instructions
  5. Dec 14, 2020 at 1:12 PM
    scifidelity
    Both good points, that website has a kit that includes new rotors AND new drums. They just got the desc. mixed, per a rep I called. I will just PowerStop directly.
  6. Dec 14, 2020 at 1:20 PM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    If your rear drums are shot you're doing better than me. I'm at 170k and mine have a decent amount of pad left. I pulled them off at 130k when the front OEM pads were toast to find 1/2 pad or more left in the rear.
    CowboyTaco and Skydvrr like this.
  7. Dec 14, 2020 at 1:22 PM
    scifidelity
    The drums aren't shot, they are just rust buckets. Want to get a pair that is well coated in zinc, galvie, etc.
    whatstcp likes this.
  8. Dec 14, 2020 at 1:24 PM
    Blueberry.Taco
    Ryo
    SE MI
    depending on how much time you have vs money you'd spend to save time, you can sandblast+paint or get it zinc washed, etc as an option too
    whatstcp and scifidelity[OP] like this.
  9. Dec 14, 2020 at 1:26 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Why not just acid dip the ones you have then coat them
  10. Dec 14, 2020 at 1:27 PM
    scifidelity
    Good point. The only issue is the truck is un-drivable while coating is occurring. I don't have a backup.
  11. Dec 14, 2020 at 1:59 PM
    scifidelity
    yep, i've done that before. I use POR which works fairly well.
    whatstcp[QUOTED] likes this.
  12. Dec 14, 2020 at 3:56 PM
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    If you have half a day I'd just bust off the drums and hit em with a wire wheel. I'd pick up a quart of Chassis Saver from Napa and hit em with that. I promise you that stuff will never come off. Also I wouldn't trust extremeterrain. Based off the link you posted you're about as likely to get a new puppy in that box as you are shoes and drums that actually fit.
  13. Dec 14, 2020 at 4:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    Wire wheel
    POR 15
    BBQ grill paint
    All else is a waste of time and money on a big 'ole chuck of cast iron, as that surface rust is just cosmetic.
    You are concentrating on care of your frame, right?
    Chew and TurdTaco64 like this.
  14. Dec 14, 2020 at 9:59 PM
    scifidelity
    Yes, thanks, others have suggested this as well and yes, I sand off any rust spots I find and re-paint, I also do fluid film at least annually
  15. Dec 16, 2020 at 6:39 AM
    Rik808
    Rik808 Well-Known Member
    put these on mine 2 years ago and not a spot of rust yet. Power-Stop-KOE15389DK
  16. Aug 2, 2023 at 11:28 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Requesting a 2.5 year later update. Still good? I'm considering this kit or OEM parts. This kit is less expensive.
  17. Aug 2, 2023 at 4:38 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Are performance drum brakes a thing? Can I get some composite drums?
    Chew likes this.
  18. Aug 2, 2023 at 4:55 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    They are just drums . They are supposed to rust . Just clean the rust off repaint and put them back on . To spend money on this kind of stuff is silly, in my opinion .
    Chew likes this.
  19. Aug 2, 2023 at 4:59 PM
    gudujarlson
    Minnesota
    Old school thoughts from before pickups became a fashion statement.
  20. Aug 3, 2023 at 4:52 AM
    MGB
    MGB Well-Known Member
    2017 manual TRD Sport
    I painted mine with POR-15 top coat before the first winter (2017). Just painted them again as a little rust was starting to show. Works great...
