Aftermarket Cruise Control - Good or Bad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rickochet, Oct 27, 2008.
  1. Oct 27, 2008 at 5:51 PM
    Rickochet
    Rickochet [OP] Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    I just got my '09 Taco which is a pretty basic 2.7 I4 Access with auto and air which I am totally tickled with. It did lack a few things I would have liked, DRL and cruise control would have been nice but not a deal breaker. I have found info on adding DRL. I don't seem to find a lot of info about aftermarket cruise. I have found a kit that Rostra makes that looks ok but not something I would want to install myself.
    Something I read somewhere said most after market cruise units just don't work that well.
    Any thought would be appreciated.
    Rick
  2. Oct 27, 2008 at 11:04 PM
    mainerinexile
    mainerinexile Well-Known Member
    central Maine
    2014 SR5 Access cab I4 4x4 5 spd
    Rick, both of my Tacomas came with OEM Cruise, but I put aftermarket units on my Matrix and a Nissan HardBody before that. Both units worked fine for years--much better than living without cruise. I went to a auto electronics shop for the install for the Matrix, and a speciality auto shop for the Nissan. Not sure I'd want a place like Wal-Mart to do the install.
    I think the units are $300 to $400 nowadays, depending on whether you have an automatic or manual (manual is more because they have to install two kill switches ( brake and clutch).
  3. Oct 27, 2008 at 11:10 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I've had cruise on all my vehicles & never think to use it. Just my opinion, if I had a choice in getting it or not. I probably would leave it off & use the money for a better mod.
  4. Oct 28, 2008 at 4:20 AM
    Rickochet
    Rick
    Kentucky
    I have cruise on my other vehicle and use it a lot. The roads I travel most are strictly enforced. As smooth as the Taco rides I find myself blowing well past 55 on the back roads before I realize it.
  5. Oct 28, 2008 at 4:23 AM
    Rickochet
    Rick
    Kentucky
    I think the Rostra kit runs just under $200 and I figurered another $100 - 200 for the installation. There is a truck accessories store not too far away that has been doing this for years.
    Thanks for the info.
    Rick
  6. Oct 28, 2008 at 4:39 AM
    1-3-2-4 Squirrel Mincer
    Ithaca, NY
    06 Titan King Cab
    A.R.E. tonneau cover
    Do yourself a favor and install the factory kit. It is plug and play and factory-seamless. You can find the parts for about $125; installation took me about 30 minutes total including cleanup and all.
    For DRL, you can install the factory system for about $50 after shipping. If you do this at the same time as the cruise control, it only adds about 3 minutes. Seriously, it is that plug and play.
    Cruise: http://www.toyotanation.com/forum/t171992.html
    DRL: http://www.tacomaworld.com/forum/technical-chat/1475-05-drl-daytime-running-lights-install-oem.html
  7. Oct 28, 2008 at 5:32 AM
    Rickochet
    Rick
    Kentucky
    Thanks for the info. I had already read the DRL thread. I guess "plug and play" depends on your skills. I am a bit hesitant to tackle both. If it is that easy I am surprised my Toyota dealer will not do either mod. I also noticed that the aftermarket cruise companies list a different kit for the 09' from the '05 to '08 so I am not sure if the OEM install will work.
  8. Oct 28, 2008 at 6:30 AM
    Ithaca, NY
    06 Titan King Cab
    I definitely can't vouch for the 09's being the same as the 05-08's, so you'll have to figure that out with your dealer and the parts fiche. That being said, it really is very simple. If you were local, I'd help you do it to prove how easy it is:)
  9. Oct 28, 2008 at 6:42 AM
    Rickochet
    Rick
    Kentucky
    Thanks for your help. I just get a little nervous hacking into a week old Taco, particularly around the airbag. I found another company that offered an OEM type kit for the '09 and reading the instructions it showed basically the same as the link you showed plus having to route a harness and tieing it into a terminal block behind the glove box. Definitely a bit more than Plug and Play, at least for me. :eek:
    Rick
  10. Oct 28, 2008 at 7:11 AM
    Ithaca, NY
    06 Titan King Cab
    Yeah, understood. Call the dealer and see if the p/n's match up for the 09 models. If so, you're golden (I'd be surprised if it didn't work). As long as you disconnect the battery, the airbag issue is moot and you'll be ok.
    Edit: I just read that you have an auto...as far as the install goes, you're even luckier since you don't have to install the clutch switch...i.e. no need to go under the dash. The whole process should only take you about 10-15 minutes. No, I'm not exaggerating.
  11. Oct 28, 2008 at 7:11 AM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    Yea, it can be a little bit unnerving to start to take apart and modify a brand new truck. It only gets easier, once you get over you initial fear to mess something up. I mean, you really do not need to be mechanically inclined at all to do some of the mods on this truck. As long as you have some simple tools, and are careful, you'll be fine. I'll tell you what - I'll dispatch Guidance and Contorl to your house if you break something. :D
  12. Oct 28, 2008 at 7:48 AM
    Rickochet
    Rick
    Kentucky
    After looking at it again it doesn't appear to be that difficult. Looking at the new wiring harness I see a spade connector that goes back to the airbag ground and I am assuming that there is a multi pin connector that goes to the stalk"
    I guess I need to go to the dealer and see if this will work on the "09.
    Does Toyota have any kind of chatline or tech help online that could answer this?
  13. Oct 28, 2008 at 8:47 AM
    Rickochet
    Rick
    Kentucky
    I just found a similar thread in a Tundra forum and putting cruise on an '06 Tundra uses that same parts mentioned above. It also said that it would not work on '07 and '08's because the required wiring is not put in unless the cruise was factory installed. I am guessing the same is true for the '09 and also applies to the Taco. :(
  14. Oct 28, 2008 at 9:00 AM
    redraider
    redraider Well-Known Member
    Eric
    San Antonio,TX
  15. Oct 28, 2008 at 9:32 AM
    Rickochet
    Rick
    Kentucky
  16. Oct 28, 2008 at 9:39 AM
    steelerfan7p
    steelerfan7p My other car is a Bugatti
    Yes
    Fairmont, WV (1 Hour South of the City of Champi
    Non-TRD, Non-SR5, Non- Prerunner
    Rear Leaf Spring TSB, Metra IPod Adapter, AFE Pro Dry S Air Filter, I was added to the truck to make it better, so does that count as a Mod?
    If you look at some of the later threads on the ToyotaNation site, it seems that people have been getting it to work on the 07-08's and maybe even the 09's. But if you have a manual, you might have to order one other part. I have an 08' AC V6 that I have been wanting to do it on. Maybe it will be a Christmas present for myself:D
  17. Oct 28, 2008 at 10:13 AM
    HardCase
    HardCase Winter is coming.
    Robert
    Kalispell, Montana
    2017 Tacoma (Inferno) TRDOR 4x4 DCLB
    I mentioned in another thread about recently taking a 2700 mile trip in my basic regular-cab 2.7/5speed and wishing at times that it had CC. I do find, however, that I rarely use it around my neck-of-the-woods. I live over 100 miles from the nearest Interstate highway and most of the roads around here are 2 lane and CC just isn't needed all that much. I have it in my two cars and rarely use it close to home, but it sure is nice on a long road-trip on the slab. I probably won't be taking my Taco on too many of those however, so doubt that I'll add it as an option......but may reconsider if that changes at some point in the future.
  18. Oct 28, 2008 at 10:25 AM
    Rickochet
    Rick
    Kentucky
    Thanks, I will check further.
  19. Oct 28, 2008 at 10:28 AM
    Rickochet
    Rick
    Kentucky
    We drive to a lake most every weekend about 90 miles. The roads are straight, flat and heavily patrolled. I have cruise on my Blazer I always use on that trip. I have taken that trip with my Cherokee without cruise and really missed it. We will be driving the Taco most of the time now for that trip. Cruise would be nice for me.
  20. Oct 28, 2008 at 10:57 AM
    jeepinoutwest
    jeepinoutwest Well-Known Member
    just installed OEM cruise on my '08 reg cab 2WD, Works perfect, would never know it didnt come that way, super easy to install, all for $106.22 shipped from 1sttoyotaparts.com
