Aftermarket center console options?
Discussion in '1st Gen. Tacomas (1995-2004)' started by PumpinIron, Feb 16, 2020.
  1. Feb 17, 2020 at 12:24 PM
    PumpinIron
    PumpinIron [OP] Well-Known Member
    San Tan Valley, AZ
    Now this is awesome!
    How does it mate up to the shifter console trim? Got any pictures of that? Also, how does it bolt-to the floor? Did you have to fab some brackets up I assume?
    Was it a lot of work to get it to fit and look factory?
    EDIT: Nevermind, just saw the link to your thread!
  2. Feb 17, 2020 at 12:26 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Just edited my post, but check out the build thread, most of that info is in there.
    I had to slightly trim the front where it meets the shift console. Not much, but the "tabs" bulge out a little so I shaved them down on the back side.
    If you were just bolting in the stock console (no custom fiberglass), you could probably use the 4runner mounting bracket. My truck didn't even have the threaded holes for the tacoma console, so I just ignored that as an option.
    Yes it was a lot of work to make a custom sub box.
    Keep in mind the 4runner has the ebrake handle in the console, so youll have a big hole there.
    Picture of the front:
  3. Feb 17, 2020 at 12:29 PM
    PumpinIron
    San Tan Valley, AZ
    That turned out awesome, I'm impressed to say the least. This would actually give me a great place to mount a subwoofer, as I am upgrading my sound system and really having a hard time figuring out where I can fit a subwoofer at the moment.
  4. Feb 17, 2020 at 12:55 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    My oak carpet sure looks grayish now. Seems like it's dyed.
    PumpinIron[OP] likes this.
  5. Feb 18, 2020 at 6:29 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Seems like that "blank" space where the former handbrake lever was could be a terrific spot to mount switches or a USB power outlet.
    Nice idea and execution, @PumpinIron.
  6. Feb 18, 2020 at 7:17 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    In the next couple of weeks, I am going to refresh a heavily worn Oak console using some paint for plastic that comes close to the Oak hue. I'll post on the paint tonight. I found it at Ace Hardware.
  7. Feb 18, 2020 at 8:57 AM
    Wulf
    Wulf no brain just damage
    rock raisin
  8. Feb 19, 2020 at 8:48 AM
    PumpinIron
    San Tan Valley, AZ
    Yes, please do share the results, as this is an option I could use as well.
    Oh yes, I've seen these in many Jeeps. Stinks that it's too wide!
    CS_AR[QUOTED] likes this.
  9. Feb 19, 2020 at 9:10 AM
    Zimm!
    Zimm! Well-Known Member
    1999 Extra-Cab TRD 4x4
    What did those leather seats come out of? I like them a lot, they look comfy.
  10. Feb 19, 2020 at 9:26 AM
    nzbrock
    Noah
    San Marcos, TX
    From a 3rd gen 4runner.
  11. Feb 19, 2020 at 9:27 AM
    Zimm!
    Ah that's what I thought, thanks.
  12. Feb 19, 2020 at 9:28 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I like the idea but that seems like overkill for the size of that console. I wouldn't have gone larger than an 8".
  13. Feb 19, 2020 at 9:49 AM
    nzbrock
    Noah
    San Marcos, TX
    That is an 8"...
  14. Feb 19, 2020 at 11:01 AM
    CS_AR
    Colors are (lighter) London Gray or (darker) Satin Espresso - Paint bonds to plastic. I need to decide which color to use.
    tacoma_ca likes this.
  15. Feb 19, 2020 at 11:55 AM
    #35
    PumpinIron
    San Tan Valley, AZ
    If it were me, I think I would go for that satin espresso personally. That almost looks dead on.
    Thanks for this, I'm going to have to go look for a can of it now.
  16. Feb 19, 2020 at 11:59 AM
    #36
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    :rofl: My bad. The picture must add a few inches. Note to self :anonymous:
    nzbrock[QUOTED] likes this.
  17. Feb 19, 2020 at 1:05 PM
    #37
    nzbrock
    Noah
    San Marcos, TX
    Haha, you can't fit a 10" in that console. The main problem is the mounting depth since the console is only about 7" wide and I mounted the sub inset so the top is flush with the side. A 10" circle barely fit on the side, so if you had a shallow mount sub you might be able to pull it off.
    I built my own console previously that I put a rather beefy 10" in, but it was 9" wide.
    [​IMG][​IMG][​IMG]
    It's currently for sale in the FS section.
  18. Feb 19, 2020 at 7:58 PM
    #38
    CS_AR
  19. Feb 20, 2020 at 8:05 AM
    #39
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Don't use the SEM stuff on Vinyl..Doesn't work. Says it does, it doesn't.
    I used to it paint my door cards 7 years ago. The rigid plastic parts have held up great, anything high traffic like door seal protectors and the vinyl like fabric that we all rest our arm on while driving with the window down it won't last in the long run.
  20. Feb 20, 2020 at 10:07 AM
    #40
    CS_AR
    Thanks for the warning. I appreciate you speaking up.
