After valve cover gasket question
Discussion in '1st Gen. Tacomas (1995-2004)' started by thefourthwalston, Aug 5, 2018.
  1. Aug 5, 2018 at 4:58 PM
    thefourthwalston
    thefourthwalston [OP] New Member
    Adam
    1996 Tacoma xtracab auto 3.4L V6 4x4
    After VCG replacement, what is general consensus wait time before full-go driving?
    FIPG says 1-2 hours to set up. 16 hours until fully rubberized.
    Just wanting to know how long people are waiting before driving?
    If it matters: 96 extcab 3.4L auto
  2. Aug 5, 2018 at 5:30 PM
    All Rice
    All Rice Well-Known Member
    Aloha State
    I usually just wait till the next day. Also current temp in your area will make a difference.
  3. Aug 7, 2018 at 12:02 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Right away? The heat from the engine will help cure any sealant.
  4. Aug 7, 2018 at 12:08 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I let it sit for 12 hours then let the engine idle for 15 min then light drive for 5. I always want to make sure the RTV dries before i start normal stop go driving again.
  5. Aug 7, 2018 at 1:48 PM
    thefourthwalston
    Adam
    Did it yesterday. But now I’m out of town for a week. Do you think It matters if I don’t start it for that long after install?
  6. Aug 7, 2018 at 3:25 PM
    757yotas
    Virginia
    2007 TRD Sport
    No it will be fine
  7. Aug 7, 2018 at 3:50 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I was wheeling in Co last month and blew a cv axle seal, since I didn’t have tools I brought it to the dealership. They also noticed a cracked valve cover. I had them replace the cover and both seals. I drove it about 30 minutes to a friends house, spent the night and then drive 12 hours. No problems
  8. Aug 7, 2018 at 5:05 PM
    thefourthwalston
    Adam
    Right on.
    I had my wife (who is home) turn it over, let it idle for 5 min. Didn’t spew oil or throw any codes. Hopefully, that’s good enough sign.
  9. Aug 8, 2018 at 9:21 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Straight off the box (Toyota FIPG):
    Remove all the old FIPG material from gasket surface and sealing groove
    Clean all components to remove all loose material
    Clean both sealing surfaces with a nonresidue solvent
    Apply seal packing
    Assemble parts within 15 minutes after application
    Engine may be started in 1 to 2 hours
    Hardens to become rubberlike in 15 to 16 hours.
    :thumbsup:
    DrZ likes this.
