After Market CV Axles on RockAuto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Nov 8, 2024.
  1. Nov 8, 2024 at 10:30 AM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Can anyone recommend a good aftermarket CV axle from Rock Auto? Mine is a V6 4liter 4WD Access Cab Automatic transmission with a leveling kit. I've been planning to get rid of the leveler and put Bilstein 5100's in to level it out that way. Any suggestions?
  2. Nov 8, 2024 at 11:02 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Generally. OEM are better CV's (than what you find at Rock Auto). Why are you replacing yours?
    2009Access4x4[OP] likes this.
  3. Nov 8, 2024 at 11:35 AM
    2009Access4x4
    Shane
    Yeah I’ve heard they’re better but I don’t wanna pay for em. Is it highly advisable not to use aftermarket? Mine are leaking grease and there is a clink coming from the front left every time I brake with the wheel turned.
  4. Nov 8, 2024 at 11:41 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    Oem is best but not the worst to save some cash.
    Napa has lifetime warranty as do a few others. Get one of those and at least if there’s problems you get a new one free.
  5. Nov 8, 2024 at 11:46 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    My man! I normally get killed when I just tell people to go NAPA.
  6. Nov 8, 2024 at 11:53 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Napas are fine. Just check for binding at full droop. In my experience, with napa replacements they are either slightly shorter or don't allow as much angle. In everyday street driving they will be fine. The lifetime warranty is a plus. You can rebuild your oem axles while they're off the truck
  7. Nov 8, 2024 at 11:55 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    If you aren't going to use OEM, use whatever parts store is nearby, all have lifetime warranties for when they break or start flinging grease in a few years and it's easier to walk to the local spot then wait for rock auto. Or just buy several of the $38 special.
    TheWildMan likes this.
  8. Nov 8, 2024 at 12:12 PM
    soggyBottom
    soggyBottom Well-Known Member
    I like the OEM ones because they are notches to help with removal and installation.
  9. Nov 8, 2024 at 12:18 PM
    2009Access4x4
    Shane
    I like the rebuild idea. How hard is it to rebuild them?
  10. Nov 8, 2024 at 12:21 PM
    AllTacosFloat
    Boston ish
    Easy with the right tools. Messy no matter what!
    Strictlytoyz likes this.
  11. Nov 8, 2024 at 12:23 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    This ^ , very simple process and simply very messy
    AllTacosFloat[QUOTED] likes this.
  12. Nov 8, 2024 at 12:25 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Look for remans and they'll most likely be fine.
    It's the new aftermarket ones that are complete junk.
  13. Nov 8, 2024 at 6:12 PM
    TacoTuesday1
    FL
    I did not buy garbage. I took my quality parts and put new boots on them. It is not hard.
    you do what you want.
    boots are rubber. Rubber wears. Rubber gets replaced.
    some people don’t change their oil and replace their engine due to this.
    I change my oil and run the engine.
    depends on funds. If million dollars in checking account, ignore the boots I guess.
  14. Nov 8, 2024 at 7:04 PM
    isdjww
    isdjww Active Member
    Pinewood Springs, CO
    2014 Tacoma, 4.0L, 6-sp manual
    I had a bad experience with NAPA axle recently.
    I purchased online and picked up at a local store.
    One of the CVs was seized, so went to return it. Turns out I was not allowed to return it where I picked it up. When I called NAPA to ship it back they gave me extreme grief.
    I was eventually able to return it, but I won't be doing that again!
    Anyone have experience with Raxles?
  15. Nov 8, 2024 at 7:25 PM
    hoarder23
    Shay
    NJ
    Scratches
    I don't see that they make a CV for a Tacoma, but they seem to be in the same game CVJ is. I've had luck with CVJ, the only CVJ axle I damaged was when I ripped an LCA off, they held up to trail abuse that killed more than a few O'Reilly's specials.
  16. Nov 8, 2024 at 8:14 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    I second cvj if you want oem remans
  17. Nov 9, 2024 at 4:12 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    As long as they start with an OEM core. You will find aftermarket axles that have been remanufactured these days due to a shortage of OEM cores.
  18. Nov 9, 2024 at 7:15 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I always say this in these threads: what you make up in cost savings by going with a cheap aftermarket CV, you'll put right back into by wasting your own time changing CV's every year due to cheap, torn boots. Not to mention the cheapies aren't built to the same tolerances for trueness, range of movement or strength.
    Lifetime doesn't mean they're good forever, either. Lifetime just means they'll exchange them when the boots tear. But after years and years of exchanging CVs in my 1st gen, some years more than once per year due to torn boots, I got flagged at O'Reilly. The guy even said, "it says here you're flagged for exchanging these too often." I said "if you build a better CV with a better boot, I won't need to exchange them"
    The easy choice is to buy once, cry once and go OEM. Our 2006 is still on its original CVs/boots at 240k.
