After Airbag deployment - ABS brakes locked up
Discussion in '1st Gen. Tacomas (1995-2004)' started by AddictedOffroad, Nov 10, 2013.
  1. Nov 10, 2013 at 7:51 AM
    AddictedOffroad
    AddictedOffroad [OP] Well-Known Member
    Windsor, CO
    2000 4runner. Linked and locked
    So, I finally got the double cab back on the road yesterday. Now the front two calipers are locking up. Pedal is VERY firm now too.
    I bled the system, but it feels like every press of the pedal makes it worse like a valve isn't allowing the brakes to release.
    I am wondering if the airbag deployment locks up something in the ABS system similar to how it locks up the seat belts.
    Anyone know for sure? Is there a way to reset it?
    Or, do I just bypass the ABS unit as its no good to me with the SAS in the near future anyway?
  2. Nov 16, 2013 at 2:30 AM
    lunch box
    lunch box diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    why did your airbag deploy ....
  3. Nov 16, 2013 at 2:37 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    What did you replace and why?
  4. Nov 16, 2013 at 2:41 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Sounds like your ABS control module needs to be reset. Bleeding the brakes will not help. Let us know the outcome.
  5. Nov 16, 2013 at 6:14 AM
    AddictedOffroad
    Windsor, CO
