aFe Y-Pipe (48-46006) or URD Mark 2 Y-Pipe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by livpool14, Aug 1, 2019.
  1. aFe Y-Pipe
    22.4%
  2. URD Mark 2 Y-Pipe
    34.7%
  3. JFR Y-pipe
    42.9%
  1. Aug 1, 2019 at 8:43 AM
    livpool14
    livpool14 [OP] Well-Known Member
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    aFe CAI Momentum GT Power Package, aFe POWER 76mm Throttle Body, aFe headers, aFe Y-Pipe, TRD Exhaust, VFTune, LCEngineering Dual Comp Clutch - Kevlar, Tilton 6000 Series HRB, URD quickshift, Icon Stage II, Icon Delta Joint UCAs, ECGS bushing, Cooper Discoverer at3 255/75/r17 115T, FN f(x) Pro 17" Matte Black, Ice Gray Katzkin, RCI front skid, Optima Yellow Battery, StopTech Sport Slotted Cryo rotors w/ TRD Brake Pads, Morimoto XB HYBRID LED HEADLIGHTS AMBER DRL, Anzo L Bar Taillights, BAKFlip MX4, 3rd Gen Side Decals, Plasti Dip badges, Cab LEDs, redline hood struts
    I hope I get a few bites on this because I cant seem to find anyone with a similar setup or a comparison of the 2 pipes.
    Ive read through the endless amounts of exhaust threads and now here I am adding to the pile!
    My Taco is N/A and im trying to avoid losing noticeable low end torque and raspy/droning issues.
    biggest performance additions...(sounds great right now)
    - aFe CAI Momentum
    - OV Tuned
    - TRD Exhaust (PTR3135131): reading other forums I believe the pipe is 2.5"
    Y-Pipes:
    aFe $536 - 2-1/2" into 3" transition
    URD $585 - 2.25”
    both seem to be a very easy direct bolt on replacement. Ive read that being N/A I should avoid going too large (3") as that is where I would see the low end torque loss. However, with it going to a 2.5" exhaust maybe that wont be much of an issue?? Thoughts?
    Also regarding where the pipes meet will I need to do anything for it to transition from a 3" or 2.25" to a 2.5" exhaust?
    Any input on this would be greatly appreciated! I have no issue with admitting that im not the most mechanically inclined and that is why im here hoping for answers from the more experienced folks!
  2. Aug 1, 2019 at 10:26 AM
    Redsyota
    Redsyota Well-Known Member
    Denver
    15' SPORT 6 SPEED ACLB MGM
    Some of the things...
    Are you looking at the straight through AFE or the one with cats? Its going to sound raspy without cats or resonators of some sort (just my opinion from lots of ls based hotrods and now my own s/c'd 15 tacoma).
  3. Aug 1, 2019 at 10:43 AM
    livpool14
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    Thanks for the reply @Redsyota, I am looking at 48-46006 which is without cats. Is it really bad inside the cab?
    With my current setup and having the vinyl flooring instead of the carpet its still fairly quiet and sounds great
  4. Aug 1, 2019 at 1:25 PM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I just installed a used URD y-pipe on my HP Tuned but otherwise completely stock 2014. I wasn't expecting much in regards to performance but mainly wanted an improvement in off-road clearance.
    I'm a decent welder and many would consider me mechanically inclined so the URD pipe was a bit of a disappointment all around. C+ TIG welds, not perfect fit with my stock exhaust (had to push the stocker back an inch, bend a hanger bracket with a torch and am still getting some annoying crossmember contact at certain RPM's), no discernable power increases in my N/A truck and the install was understatedly not awesome.
    The truck is low mileage and rust-free so removal of the OEM pipe went super-quick. However, it was the removal of the header flange studs that turned a 45 minute bolt-on project into a 6 hour long cut, drill and tap fest. If URD had just designed the fitment to allow the use of the stock studs, I'd still be pretty luke-warm about it all, especially if I had to buy new and pay retail.
    Not sure about the AFE pipe, but if I had to do it again and wanted a nice Y-pipe to increase performance, I'd be plunking down for one of @Roostfactor equal length pipes.
    blu92in99 and Roostfactor like this.
  5. Aug 1, 2019 at 2:10 PM
    livpool14
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    Thanks for the reply, @DesertRatliff. Wow, that really has made this decision even harder because I was leaning towards the URD.. I would LOVE one of roostfactors pipes but I just cant see myself throwing 1k at a pipe unfortunately.
  6. Aug 1, 2019 at 2:22 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Are you just looking for added performance? It sounds like there's not much to gain in our N/A applications with the addition of an aftermarket y-pipe. @mightytacoman exhaust cam gears might be a better bang for the buck, especially since you can have OV Tune make them run perfect (mine are ready to install).
    Or just put that $500+ in a fund for a supercharger...
    If you're looking for better clearance, a simple $100 exhaust shop re-route might be the way to go. I got a good deal on the URD pipe here on TW, but in hindsight and if I had to pay retail, a re-route would have been sufficient for my needs.
    mightytacoman likes this.
  7. Aug 1, 2019 at 3:20 PM
    livpool14
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    I would like to see a small gain, however I know I may not see any change apart from sound change, better gas mileage, and as you stated a bit more clearance, which in that case I may just do the re-route.
    I do have plans to eventually throw a sc in it, but I want to have it paid off before doing so lol
    I will definitely look into the exhaust cams, I appreciate that info!
  8. Aug 1, 2019 at 4:47 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I'm happy to help you with the exhaust cams if you decide to go that route buddy.
  9. Aug 3, 2019 at 3:07 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Not sure what makes a URD Y pipe a MK2.
    Years ago I installed long tube DT headers and a URD Y pipe. Still has the oem exhaust from the Y pipe back.
    MPG definitely increased. Exhaust note rasp, yes it is there. I do not wring out every gear so not too bad most times.
    The left side Y pipe hanger was not a bad alignment during installation, however 800 miles from home, the Y pipe exhaust tube section around the hanger weld broke out a section of the pipe.
    My truck has other mods too beyond the exhaust, but no supercharger.
    Never ran the other brands of Y pipes.
    livpool14[OP] likes this.
  10. Aug 3, 2019 at 11:47 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    2.5" is too large and you will lose low end.
    I use 2.25" and want to try 2" for na trucks to keep exhaust velocity high.
    The raspyness comes from the exhaust pulses trying to fight their way through the merge collector.
    Having equal lengths lines up the exhaust pulses so they alternate through the merge collector which also creates the scavenging effect that is non existant with unequal length systems.
    This is specific to our engines firing order as each cylinder fires 120° apart alternating between banks.
    Hope this helps.
    Roost
  11. Aug 6, 2019 at 10:33 AM
    livpool14
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    @mightytacoman thanks man, im going to do some research on changing exhaust cams and will definitely give you a shout if I choose that route. If you have any quick and dirty details I would appreciate it!
    @Roostfactor thanks for that, it helps a lot. Looks like my Y-Pipe options are go with the URD and deal with a bit of raspyness or splash the cash on your pipe! Do you build any of them with a smaller diameter? It looks like yours is about 2.5"-3", is that accurate?
    mightytacoman and Roostfactor like this.
  12. Aug 6, 2019 at 10:56 AM
    Roostfactor
    TX panhandle
    Mine are 2.25" with a collector exit of 2.5 or 3" to mate to your exhaust.
    There is a lot more to it than just sound! There is a very specific reason why it's made the way it is. Efficiency!
    Torspd and BassAckwards like this.
  13. Aug 6, 2019 at 12:59 PM
    mightytacoman
    Kel
    4.5L 1grfe
    Most of the details are here buddy.
    https://www.tacomaworld.com/threads/exhaust-cam-gears-with-3°-retard-for-v6-1gr.618266/
  14. Aug 9, 2019 at 9:47 PM
    livpool14
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    @mightytacoman I'm ready to do this, but now my only concern is where to have it done or who to have help me! I'm not so sure I'm feeling confident enough to crack open my engine myself :/
  15. Aug 10, 2019 at 7:43 AM
    mightytacoman
    Kel
    4.5L 1grfe
    As much as I would like to help ya tackle this over a few beers, NY isn't exactly next door. Myself and others would surely answer any questions you had during the process. Pm me if you decide to place an order.
    livpool14[QUOTED][OP] likes this.
  16. Aug 10, 2019 at 8:57 AM
    ImBillT
    ImBillT Well-Known Member
    2010 4x4 base
    2.25” is somewhere between just right and too large. For the Y-pipe you essentially have two 120hp engines and each one has its own pipe until they merge. 2.5”-3” is almost certainly gonna cost you low end torque.
    Roostfactor and livpool14[OP] like this.
  17. Aug 10, 2019 at 9:36 AM
    livpool14
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    Thanks @mightytacoman I'll probably be doing that within the next few weeks. Ill get my brother In law to help me out with it :boink:haha. I appreciate the help, info, and responsiveness!
    Thanks @ImBillT I think I'm actually going to do both now... get the cam gears done along with throwing on the URD Y..
    @OVTune is this something that would require changes to my current tune? [Cam gears w/ 3° retard & URD Y Pipe] or is your tune already adjusting the exhaust gear timing? If that's even possible by ecu cal?
    I recall you saying it may need to be done with a complete new exhaust which the only stock part left would be the manifolds.
    Thank you guys, I'm really enjoying learning all of this new stuff
  18. Aug 10, 2019 at 9:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I was just about to mention a JFR Y-pipe...
  19. Aug 10, 2019 at 12:37 PM
    Roostfactor
    TX panhandle
    Yeah, he didnt put my y-pipe in the voting pole. :(
  20. Aug 10, 2019 at 1:43 PM
    livpool14
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    Ah man, makin me feel bad! Truthfully I feel like we cant compare them since yours is the only equal length! ;) If I had the money right now I wouldnt hesitate to snag one of yours!
    Roostfactor[QUOTED] likes this.
