aFe throttle body spacer review
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco1004, Mar 14, 2021.
  1. Mar 14, 2021 at 8:37 AM
    Taco1004
    Taco1004 [OP] Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    So I know this is taboo... but I recently installed an aFe Silver Bullet throttle body spacer. And per others request, I wanted to do this thread for an initial review, and then update it down the road with a long term review. Most people say these spacers are a hoax. The companies that produce them do NOT necessarily claim any horsepower gains (minimal if anything on injected engines)... but the DO claim to improve throttle response and improve air/fuel mixture resulting in slight gains in fuel economy. I won’t be able to vouch for the fuel economy in this initial report, but I will update that information in a couple weeks.
    Let’s start with the basics... The vehicle is a 2020 TRD Sport DCSB v6 automatic 4wd with 5k miles. Just FYI, other power mods prior to tb spacer install are as follows... -full K&N intake kit -K&N throttle control module -MBRP shorty 3” exhaust (pre-axle dump). And I always run mid-grade fuel (89 octane).
    Install is pretty straight forward. On a scale of 1 thru 10, I would rate it at a 1.5-2. Basically it’s just lifting off the plastic engine cover. Disconnect the intake elbow from the throttle body, and set aside. Remove the 4 bolts holding the throttle body to the manifold. Remove the throttle body. Place the spacer and provided gasket in between the manifold and throttle body... make sure the arrow on the inside of spacer is pointed in the direction of air flow. Then re-install the throttle body to the spacer plate with the 4 extended bolts provided in the kit. Lastly, re-install the intake elbow back onto the throttle body. Simple as that! Total time about 20min.
    Initial first impressions. Upon start-up, I noticed nothing. No slight whistles noise like previous spacer mods on other vehicles. Went out with wife running errands yesterday... probably put 100 miles on truck. At a low RPM, still notice nothing. When accelerating it does feel slightly more responsive, not much. And there is a slight whistle around 3100rpm and again you hear it around 5500rpm... when your really into the gas! As far as any actual power gains go, I can’t say. If there is any gain at all, it’s not noticeable.
    But again, I did this mod for 3 reasons. First, it’s cheap. I believe retail is like $119. So why not? Second, I wanted to see if I could get improvements in fuel economy via a better air/fuel mixture. Does the vortex really improve MPG? Time will answer that. Again, will update information later on MPG. And the third reason I did it was just simply wishing that I get some type of power gain... weather it’s horsepower (doubtful), throttle response, or even just helping it rev out faster...
    Overall... eh. It’s done. And it’s always fun to modify or work on the truck in any way. So I enjoyed the garage time. Was it worth the money? Currently, probably not at this point. UNLESS, the long term yields better fuel economy. Then yes, it will eventually pay for itself. Do I regret buying it? No. I like modifying my vehicles, and this is just that... another mod on the list.
    Chime in with any questions or comments. And I will be doing another update in a couple of weeks as far as fuel economy update, and probably another after couple months.
    -Cheers!
  2. Mar 14, 2021 at 8:38 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
  3. Mar 14, 2021 at 8:47 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    So I'm here with my review. Our first stimulus bought my afe throttle body spacer so government sponsored lmao . Anywho so here we go now yes first impression slight improvement , whistles louder combine with k&n intake , I noticed power gains where I needed it mid range got a lil boost and top end little more power . Ok fuel mileage not much but some maybe .5 mpgs. Now gentleman if you take a look at what I have done to my truck far as performance mods I'm able to retain stock mpgs if not slightly better than stock mpgs with rolling 285/75/16 km3's E rated 10 ply tires at 35 psi stock gearing I drive mostly hwy 100+ miles daily Mon. Thru Fri.
    Taco1004[OP] and Junkhead like this.
  4. Mar 14, 2021 at 8:57 AM
    shotgunbilly420
    My butt dyno lol now I would definitely love to throw my truck on a dyno just to see what the heck all this money bought lmao
    Taco1004[OP] likes this.
  5. Mar 14, 2021 at 8:57 AM
    shotgunbilly420
    Have you had bad luck with these I replaced the filter with their blackhawk dry filter
  6. Mar 14, 2021 at 9:12 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    :confused: What’s wrong with k&n?
    Taco1004[OP], D.A.S. Taco and drizzoh like this.
  7. Mar 14, 2021 at 9:14 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I see, you are one of those guys.
  8. Mar 14, 2021 at 9:15 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    I’ve never had any problems with K&N systems. I’ve never had build up in my throttle body either. They are inexpensive, have actual dyno proven gains in up and torque... significant gains, usually 15+ across the spectrum. And they have one of the best warranties out there... like a 1 million mile warranty. Granted, their ram air design may need more maintenance than a sealed filter... especially in high dust environments. But there’s a reason why they’ve been the biggest name for so many years... their stuff just works!
  9. Mar 14, 2021 at 9:15 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    You can please the masses... but you’ll still have a few asses!!
    SethM, Reaper 4x4, 44-16 Taco and 2 others like this.
  10. Mar 14, 2021 at 9:16 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    K&N haters are coming your way now.
  11. Mar 14, 2021 at 9:17 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Sub'd
  12. Mar 14, 2021 at 9:18 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    Better duck and cover now I guess... that’s like opening Pandora’s box!!
    Junkhead likes this.
  13. Mar 14, 2021 at 9:21 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
  14. Mar 14, 2021 at 9:29 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Throttle body spacer's of this type do nothing, but lighten your wallet, and maybe make a bit of a whistle as air rush's through them. They only work when your mixing the fuel directly through them.
  15. Mar 14, 2021 at 9:30 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    If they really did anything meaningful you’d see throttle bodies rolling out from factory with an in-built version.
    Money probably better spent on fuel ups.
    Which to each their own. I don't take claims by the very company selling the product as gospel. Inherent bias and all that.
    Clearwater Bill, =JSG=, Chew and 3 others like this.
  16. Mar 14, 2021 at 9:33 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
  17. Mar 14, 2021 at 9:36 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  18. Mar 14, 2021 at 9:41 AM
    shotgunbilly420
    I call it by it's proper name k&n intake there is nothing cold about it wait put a block of dry ice by it fml dude again never had any problems with it I run k&n in everything even their oil filters
  19. Mar 14, 2021 at 9:43 AM
    Evostaco
    Nebraska
    I had a spacer on my 96 chevy, now maybe it was wishful buttdynoing but I think it made a difference. I'm interested to see the info you gather after a few weeks of driving
    Taco1004[OP] and shotgunbilly420 like this.
  20. Mar 14, 2021 at 9:43 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Just a heads up at 5k your mpg and assessing isn't set in yet
