aFe Pro Dry cleaner solution
Discussion in 'Technical Chat' started by jrdbrn, Nov 19, 2012.
  1. Nov 19, 2012 at 2:27 PM
    jrdbrn
    jrdbrn [OP] Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
  2. Nov 19, 2012 at 2:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    I wash mine in hot dish soap water. Havent had any probs.
  3. Nov 19, 2012 at 2:41 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    So, soak it for 15-20 minutes and let air dry over night should be OK...?
  4. Nov 19, 2012 at 2:44 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    That should be fine to be honest with you. The cleaner will work better since its a contact cleaner but as long as the filter isnt drenched and totally filthy then dish soap and water should do just fine. Just see how it looks like after you clean it then clean it again if need be.
  5. Nov 19, 2012 at 2:49 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    Roger that. I will buy the kit since it's so cheap, but my wife is off tomorrow and I will take her car to work so the filter can completely dry out.
  6. Nov 19, 2012 at 2:51 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I would buy it just to have and compare the differences on how much better it cleans versus just soap and water. If you want to dry your filter faster....I've used my blow dryer to speed up the process.
  7. Nov 19, 2012 at 6:22 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    I am noticing the red plug is missing somehow... wtf? How important is that piece?
  8. Nov 20, 2012 at 9:29 AM
    Nikwanchoo
    Nikwanchoo Well-Known Member
    Florida
    TRD Sport 4x4 DC SB
    You mean the one at the bottom of the AFE/TRD air box? Mine was loose to begin with. I assume its only function was to allow the box to drain in case water got in. Probably can just plug it with something else.
  9. Nov 20, 2012 at 9:38 AM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I think it sounds a little better with the red plug in it. Vroom Vroom.
    RE: cleaning/drying...
    I hose mine off really well until the water is clear. I then use my g/f's hairdryer, and wrap a towel around the "nozzle" part so it fits tightly in the cone. I tape down the "Cold Shot" button on the hair-dryer, and about 20 minutes later it is dry and ready to go.
    (If you can't tell, I am impatient :D)
  10. Nov 20, 2012 at 11:10 AM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    I let it soak for 30 minutes. Washed it thoroughly with water. Let it dry over night. Truck runs smoother. It was dirty, but not that dirty...? Might be in my head.
  11. Nov 20, 2012 at 1:25 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I bought the cleaner..... only $13..... Why not?
    I won't argue either way. I've been trying to stay consistent with the technicalities of maintenance since it was new. I figured I'd stay on course. I clean the filter about twice a year as regular maintenance.
    I have the original paper filter (new) that I put on the truck while the AFE is getting cleaned. I'll put the AFE back in the next day when its fully dry.
