Aerodynamic mod to improve fuel economy
Discussion in '1st Gen. Tacomas (1995-2004)' started by aemsfactory, Dec 9, 2020.
  1. Dec 9, 2020 at 11:29 AM
    aemsfactory
    aemsfactory [OP] Well-Known Member
    2001 Black Tacoma TRD w/ extra rust
    Hey guys, been thinking about making some removable panels to hopefully improve the fuel economy of my truck. made a rough sketch of my idea. here is kinda what im going for.[​IMG]
    its a bit rough but let me explain. there would be 2 panels on hinges that could fold down to create a more aerodynamic shape. and fold up when not needed to rest on top of the topper. maybe some side panels too but not sure yet. let me know what you think or if this is a stupid idea.
    davidstacoma likes this.
  2. Dec 9, 2020 at 11:45 AM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    The ecomodder forum would have a lot of input for you on this.
    Long story short, if you do a lot of highway driving, And don't mind your truck looking unconventional, 10-20% gains in mpg are achievable.
    Just doing a kammi back on the back of the camper the sides sloping in and the top sloping down a bit can have a decent effect. Simi trailers have panels for that.
    Also aeroshell toppers are a thing.
    verynearlypure and Thatbassguy like this.
  3. Dec 9, 2020 at 11:54 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    It’s a truck, you’ll go from 22 mpg to 22.1 mpg.
  4. Dec 9, 2020 at 11:54 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  5. Dec 9, 2020 at 12:32 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Feels good to laugh
    TY
  6. Dec 9, 2020 at 2:04 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    While you're add it, add a convex plexiglass layer from the front of your hood to the top of the cab. Give it that full teardrop shape ;)
    As a side note, I've long wanted to build a flat undercarriage from the front bumper up to the carrier bearing and see what effects it gives me on handling and fuel economy. As for the back, you want as much turbulence as possible so a vacuum doesn't form, which is why tonneau covers don't help any, but a camper shell does. ie: you want a mostly flat rear with curved edges in the absence of a taper.
    Your drawing reminds me of the semi-truck rear aero addons, which do yield a 10-15% increase in fuel economy when used with sideskirts, IIRC. Personally I have a tendency to believe there are more improvements that can be made to the rear half of these trucks than the front, but improvements can be made all over, and it would have been much better that these improvements came from the factory.
    verynearlypure likes this.
  7. Dec 10, 2020 at 12:01 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    A downward curved wing on the back top edge of shell will help break the vacuum formed behind the truck . Like this one.
    crazytacoman likes this.
  8. Dec 10, 2020 at 3:26 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What do you haul that you need a truck??
    Downsize to a motorcycle ??
  9. Dec 10, 2020 at 6:55 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
  10. Dec 10, 2020 at 8:37 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Like, are you serious?
    Truckers use those aero shields on their trailers because they drive literally millions of miles. The few extra hundred pounds doesn't make a difference when you weight 80,000 pounds.
    Put that kinda of stuff on a pickup truck and the weight will be much more noticible.
    Best fuel economy mod:
    Or just drive 5mph slower; you'll get easily 2x better mileage than any sort of gizmo you can add to your truck to make it more "aero".
  11. Dec 10, 2020 at 8:46 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    That will also create lift and drag, creating the unknown of if you're even creating a net positive.
  12. Dec 10, 2020 at 8:51 AM
    jbrandt
    Justin
    Even a purpose built spoiler doesn't really start working (down force) until you're doing 120+
    So while you're technically correct, the amount of lift you'd get is going to be within the noise.
  13. Dec 10, 2020 at 8:57 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    I glanced at a couple of those. It should be noted that any non-ideal angles due to the short bed length can be rectified by using vortex generators, or as one comment mentioned, following the ideal angle and cutting a flat face short.
    More like 60-80mph for large wings, but true enough, but any fuel economy improvement is noise margin as well. IMO there's really nothing you can do on the top side of an SUV to make it better. Aero camper shell on a truck though could definitely yield improvements.
  14. Dec 10, 2020 at 9:06 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Learning how to drive efficiently is the only economically feasible thing to do.
    RA77 likes this.
  15. Dec 10, 2020 at 9:12 AM
    jbrandt
    Justin
    It would only yield improvements compared to a similarly weighted square shaped shell. I'm not sure you'd see overall improvements compared to just an empty stock bed.
    The added weight is going to be enough to counteract any small improvement in aerodynamics.
    The other thing to consider is that while a tear drop shell or other aero improvements will be more efficient, it also makes your truck a lot less useful, and pretty much defeats the purpose of having a pickup truck. At that point, you have a car with big tires.
    As I said, just slow down a few mph, that's free.
  16. Dec 10, 2020 at 9:16 AM
    jbrandt
    Justin
    Yep.
    Pretend you have an egg on the gas pedal.
  17. Dec 10, 2020 at 9:17 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Or better yet, put an egg on it lol. That'll teach ya quick
    otis24 and jbrandt[QUOTED] like this.
  18. Dec 10, 2020 at 9:22 AM
    jbrandt
    Justin
    The amount of money and time you'd spend trying to make your 4x4 pickup truck more aero, only to squeeze another 0.5% efficiency, you could have bought a mid 90's Honda civic.
    That's an instant 40mpg's.
    Wyoming09 likes this.
  19. Dec 10, 2020 at 9:26 AM
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    I personally have noticed better fuel economy when I have a canoe on the roof. Not sure if it's an aero effect or just me subconsciously driving more carefully but it looks cool and it seems to work. Parking garages might be a problem however.
    Thatbassguy likes this.
  20. Dec 10, 2020 at 9:28 AM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I say go for it. Do some research and give it a try.
    I travel a ton in my 4runner, so I can understand wanting to squeeze out a few extra MPG.
    I recall someone gained like 4 MPG by building a custom cap for their full-size. Don't listen to the negative Nellies!
    RA77, crazytacoman and treyus30 like this.
