advise for install axle shims
Discussion in 'Suspension' started by brutalguyracing, Jan 24, 2010.
  1. Jan 24, 2010 at 6:40 AM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    any tips for the install of axle shims 09 tacoma d.c.s.b.
    i plan on doing it in the next hour or so
    i have done the aal myslef
    is there any trimming or or special line up needed???
    any tips tricks ???
  2. Jan 24, 2010 at 6:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The thin side goes tward the front of the truck, torque the U bolts propperly.
  3. Jan 24, 2010 at 6:43 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
  4. Jan 24, 2010 at 9:44 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    help i, in the middle of installig them and the centering pin is not long enough to reach the hole in the axle????????
    help help help
  5. Jan 24, 2010 at 9:45 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
  6. Jan 24, 2010 at 9:46 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Gonna have to get new pins and cut them to fit... Don't do it without doing that!
  7. Jan 24, 2010 at 9:50 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    yea thats great i wish someone would have told me that before hand thnaks
    anouther wasted day
    thanks toyotech.......
  8. Jan 24, 2010 at 9:51 AM
    HBMurphy
    Paul
    So California Coast
    None
    That is a bitch. Sorry to hear of the delay!
  9. Jan 24, 2010 at 10:15 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    IIRC, the center pin doesnt go all the way back into the axle mount through the shim
  10. Jan 24, 2010 at 10:20 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
  11. Jan 24, 2010 at 10:24 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    has anyone here actually installed shims themselfs or is everyone guessing
    just wondering....dont take it the wrong way
    but i could use some help from someone who has done this .....
    the shims are from toyotech which i asked them for tips or instructions "basic" but no help
    the shims themselfs i belive are a "piece of crap"....could have been designed much better as like how a lift block is.......
    im just putting it back toger and going to watch the jets
    screw this
    things should not have to be this hard
  12. Jan 24, 2010 at 10:25 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    If I remember right the new pins I got with my toytec AAL did not have an extended pin. The overall threaded part was longer and needed to be trimmed. Let Chris chime in or PM him or hodge but I think you might be okay with what you have.
  13. Jan 24, 2010 at 10:26 AM
    JJ Customs
    Jay
    NV
    I did my install but it has been a while. Let me go crawl under mine and see if I can remember. BRB.
  14. Jan 24, 2010 at 10:31 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks man
    here are some pics
  15. Jan 24, 2010 at 10:38 AM
    JJ Customs
    Jay
    NV
    Okay bro here is what I got, I crawled under mine and your shim has a channel that runs all the way out the back (thicker end) this goes towards the rear of the truck. The open end of the channel should be facing up, the bottom is textured to assist with meshing with the axle. Mine all put together, the shim is only 3/16's thick where the pin runs through the shim, I think head of the pin is a 1/4 or so. End state if the head of the pin is more than 3/16's you should be good. Either way mine has not moved a bit. I will go take a few pics for ya. I hope this helps.
  16. Jan 24, 2010 at 10:49 AM
    JJ Customs
    Jay
    NV
    I don't know if this will help at all but here ya go.
    Cudgel likes this.
  17. Jan 24, 2010 at 10:51 AM
    JJ Customs
    Jay
    NV
    PS. Your ride looks good!
  18. Jan 24, 2010 at 11:04 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks
    yea thanks for the help... my pin does not stick out past the bottom of my shim at all " i have the exact one u have".....
    and when i did my all my axle moves and i have to kick it while im bringing the axle back up to pop the centering pin into place ....now if i put it back in like it is now it wont be centered ...opening up a whole new set of problems...
    im goona see if someone makes a good axle shim.....
  19. Jan 24, 2010 at 11:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. All the shims I have seen, have had a recessed hole for the pin, and a protrusion on the other side to rest into the axel.
    Mack411 likes this.
  20. Jan 24, 2010 at 11:13 AM
    HBMurphy
    Paul
    So California Coast
    None
    Wow call me a dummy (for what it is worth educated as Aero/Mech Engr) and my strong opinion is you may get away with it but the design of the rear end mounts require that the pin goes through all all the leafs and the shim and the perch. In the meantime just don't wheel it hard, run over ANYTHING, and re-torque on a regular basis. I WOULD NOT DRIVE IT WITHOUT a pin going all the way through it. JUST MY OPINION. and BTW I do dummy things that I am sure you would say "I wouldn't do that!"
    Bottomline - Good luck and I appreciate your efforts!
