Advice requested: TEMPORARY ladder rack that works with TONNEAU
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drink Hell Cola, May 31, 2019.
  1. May 31, 2019 at 10:40 AM
    Drink Hell Cola
    Drink Hell Cola [OP] Member
    Lon
    2014 Tacoma Access Cab (6' bed)
    I have a 2014 Tacoma Access Cab. I need to buy a tonneau cover, but before I do I need to make sure it works with an OCCASIONAL (1x/year) ladder rack. The two off-the-shelf fixes are PRICEY, and have LIMITATIONS:
    1) KB Voodoo URTC with one of their approved tonneau's
    2) Bakflip CS).
    Ideally, I would purchase a tonneau (hard or soft - leaning hard/tri-fold) and then attach the ladder rack for our annual trip, removing upon arrival at home. Would GREATLY prefer the tonneau to be closed during trip but would consider folding/rolling/detaching it if necessary.
    This kind of rack (does not HAVE to be this particular unit) would be fine for my annual usage, and the price is right.
    https://www.northerntool.com/shop/tools/product_200649170_200649170
    Any suggestions for a cost-effective temporary ladder rack that works with a tonneau would be greatly appreciated!
  2. Jun 1, 2019 at 9:35 AM
    Drink Hell Cola
    Lon
    Trailer, it is !~
    Muddinfun likes this.
  3. Jun 1, 2019 at 10:30 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  4. Jun 3, 2019 at 4:50 PM
    Drink Hell Cola
    Lon
  5. Jun 4, 2019 at 7:37 PM
    Drink Hell Cola
    Lon
    Let me reiterate: I would settle for installing the ladder rack temporarily WHILE LEAVING THE TONNEAU OPEN/OFF. Looking at Undercover Ultra Flex or Bakflip MX4 it seems like there's just a small amount of top rail taken up by the tonneau's mounting rail. IF LEFT OPEN couldn't you use metal shims slightly taller than the tonneau mount rail, and with the cover off/up clamp a ladder rack in place?
  6. Jun 4, 2019 at 7:46 PM
    whoispurplegoo
    whoispurplegoo Well-Known Member
    SE Florida
    2018 MGM Sport 4x4 DCSB
    what you're looking for only exists in a few forms. the ones you listed and the Retrax XR w/ Yakima Overhaul HD bed rack. That's it.
    the ladder racks that connect to the bed rail need to sit directly against the bed side caps, so you'd need to find a tonneau that is completely removable.
  7. Jun 5, 2019 at 1:21 PM
    Drink Hell Cola
    Lon
    I believe our boy Rustytaco71 has shown me the way, and it's NOT ladder bars:
    Am now thinking Extang Solid Fold 2.0 and a KB Voodoo Hi Rise or Mobtown Low Rise. Combine these with a pair of (probably off-brand, maybe these) J-Bars...off we go.
    This system would let me run it open or closed. Closed means that it STAYS closed throughout trip, which seems like a pain in the ass for loading and unloading gear. Open means that the bed's contents are open to the elements/petty thievery, but means that I can run straps up and over the whole kayak/rack assembly to the front/rear bed cleats (trusting the rail system to much torque makes me nervous- should I be?). If things go as they should, I may even be able to sandwich my wife's 10.6' SUP between the (10') 'Yaks.
    Am I missing something, or is this workable?
  8. Jun 5, 2019 at 3:59 PM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    I purchased these J bars, ran a little cheaper. The only complaint I have is that they like to spin on the Yakima bars. I’m going to figure out a way to buy some rubber in between the plates and bar so it creates friction and won’t move. I also purchased some anti theft nuts. The J bars just have a simply spin on cap to tighten them down which can easily be removed in a minute and have the bars stolen. I put the nut after the cap that way it’s locked in place and can’t be tampered with.
    Kayak Roof Rack for Car - Kayaks Accessories Best for Kayaking J Hooks Bar Mount Carrier Transport Sit on Top Canoe Fishing Jon Boat Surf Ski Caddy Racks Fit Truck SUV Van Cars w/ Universal Crossbars https://www.amazon.com/dp/B075Z8XFN4/ref=cm_sw_r_cp_api_i_NJe-CbAES6E95
    Lightronic M8 Security Hardware Kit For LED Light Bar Work Lights (4 lock+ 1 key) https://www.amazon.com/dp/B073QGJZ9Q/ref=cm_sw_r_cp_api_i_bKe-Cb9AH5K2E
