Advice on removing the oil filter cap.
Discussion in 'General Tacoma Talk' started by poordesign, Oct 11, 2023.
  1. Oct 11, 2023 at 5:48 PM
    poordesign
    poordesign [OP] Member
    Anyone have tips for removing the oil filter cap. went and grabbed the tool from auto zone and it broke my cap.
    in a bind trying to change the filter before work tomorrow.
  2. Oct 11, 2023 at 5:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Big pipe wrench?
    Possibly a big crescent wrench?
    AwesomeLaw68 likes this.
  3. Oct 11, 2023 at 5:54 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    could try a strap wrench. or a wide-jawed pipe wrench if using things nearby.
    the bottom of the canister is a hex, auto parts stores will carry the socket adapter for that.
    i use this nicer motivx version myself because life is too short of cheap tools.
    https://www.amazon.com/Motivx-Tools...oyota+tacoma+oil+filter+socket,aps,284&sr=8-3
    AwesomeLaw68 and airmax233 like this.
  4. Oct 11, 2023 at 5:55 PM
    Bishop84
    Bishop84 Well-Known Member
    You need a long driver/pry bar and have someone tap an edge while putting pressure on it with the filter tool.
    Junkhead and joba27n like this.
  5. Oct 11, 2023 at 6:01 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Take the round plug off using a 1/4 extension first.
    Then use the housing filter wrench to remove the housing.
    I had to use a cheater metal hollow pipe (2ft) to get some leverage.
    Use slight torque and Lefty-Lucy it.
    Good luck.
  6. Oct 11, 2023 at 6:10 PM
    McHale
    McHale Well-Known Member
    2023 Toyota Tacoma TRD OR MGM Access Cab
    Do you have a brand new cap to replace that one with once you take it off? If not, I wouldn't remove it. Just refill the oil and order a new cap, a proper removal tool, and try again once they arrive.
    AwesomeLaw68, airmax233 and usmc2msu like this.
  7. Oct 11, 2023 at 6:19 PM
    poordesign
    thank you for the replies. i have resigned to driving the f250. and already moved my gear over. i think i just need to figure out my filter size and get one of the filters like soundman98 mentioned
  8. Oct 11, 2023 at 10:48 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    The silver cap can be removed with (as I recall best) a 3/8 in breaker bar, but just use the square part. A 2 ft breaker bar should allow hammering on the end of the bar which will overpower resistance on the cap.
    After that the Motivx cap/wrench does a good job, and that Motivx has the same 3/8 in square head for the breaker bar. Less actual force that can break it loose slowly and carefully.
    TacoTime55 likes this.
  9. Oct 11, 2023 at 11:05 PM
    MGMDesertTaco
    soundman98 likes this.
  10. Oct 12, 2023 at 1:10 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Like others have said buy a new cap. When you put the new one one make sure you torque to the correct spec and you should be ok going forward . The motive wrench is a good product.
    The Baxter conversion is great but I never did it because of warranty . I don’t like to open a chance of any ways to say something is my fault
  11. Oct 12, 2023 at 5:49 PM
    soundman98
    NW Indiana
    i dunno, i've done 2 oil changes to my truck, the first time, i blamed whoever changed it before. the second time, i know without a doubt that i torqued it snug, but never tight, and it was just as much of a bear to get off.
    it's just the nature of the beast, er, oil filter cap.
  12. Oct 12, 2023 at 5:52 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    I explained the same thing in my most recent oil change.
    That's why I don't believe the housing should be over torqued...the vacuum of the engine block seems to create that tightness.
    At least, that's my uneducated guess as to why it felt so difficult to remove the oil filter housing.
  13. Oct 12, 2023 at 6:28 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Consider swapping for the alum housing, 15620-31060; you may have to swap center tubes. It was a direct replacement on our 2018 Lexus model with the same engine.
    To get the composite housing off, maybe try a different tool. I use the socket type that goes on the end of the housing, tool CTA 2485, the 64mm version.
  14. Oct 12, 2023 at 6:31 PM
    TruckGuy63
    Gilbert
    New York
    Also putting a nice coat of oil inside where the filters housing goes into on that flat area helps
  15. Oct 12, 2023 at 6:36 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    Get a decent housing filter wrench and put in on correctly to match the slots on the plastic housing.
    Then, install the aluminum housing unit.
    The plastic one has more wing flanges to align.
    This is what I put on and it works like a charm.
    4x4Taco2012 likes this.
  16. Oct 12, 2023 at 7:04 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Toyota put directions on the cap...
  17. Oct 13, 2023 at 3:36 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    I have a 2022 Tacoma TRD, i tried to buy this on Amazon and its stating it doesn't fit my Tacoma, is amazon wrong?
  18. Oct 13, 2023 at 4:46 PM
    poordesign
    so motiv socket came in today. couldnt get it off with regular wretch or the cordless impact. even the corded impact ugga dugga'd for a while before finally backing it off. moral of the story stay well fuckin clear of landers toyota in Little rock.IMG_5012.jpg IMG_5014.jpg
    usmc2msu and MGMDesertTaco like this.
  19. Oct 13, 2023 at 4:52 PM
    Shellshock
    Iowa
    Yep seems some dealers like to go crazy. I had the same issue the first time I changed the oil in my 2017. A breaker bar eventually got it off and I switched the the aluminum housing.
    Roof Walker likes this.
  20. Oct 13, 2023 at 6:13 PM
    Roof Walker
    Roof Walker Well-Known Member
    SE Michigan
    2021 Tacoma TRD Pro MT
    Maxxis Militia
    Aluminum housing and proper torque specs are the way to go.
