Advice on installing mud flaps with fender flares.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Troublshoot, Jul 27, 2017.
  1. Jul 27, 2017 at 4:28 PM
    Troublshoot
    Troublshoot [OP] Member
    Los Angeles CA
    2004 TACOMA 1ST GEN 4DR CREW CAB METALIC SILVER
    GAYLORD HARD TOP LOCKING BED COVER BEDRUG BEDLINER SIDE STEP
    I've read that a lot of Taco Techies are anti mud flap but I want to put some flaps on my 2004 Taco 4 door. Problem is I have fender flares and there are only 2 screw holes that I can see where to attach mud flaps. I got these RoadSport 6416 Pro Fit Truck/SUV/Van Splash Guard that I bought from Amazon. Evan though they said they would fit my truck upload_2017-7-27_16-12-36.jpg
    the holes are nowhere near where you would attach these. I have no problem drilling some holes but would rather not if I don't have to. Did I buy the wrong ones or are there flaps that fit my Taco with fender flares?
    PROseur likes this.
  2. Jul 27, 2017 at 4:36 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Mud flaps for life
    Live shots of front and rear
  3. Jul 27, 2017 at 4:46 PM
    Troublshoot
    Los Angeles CA
    Ah I guess those are the OEM hundred and bla bla dollar ones? lol Yeah I saw those but dang are they expensive. Thanks for your input Pro.:)
  4. Jul 27, 2017 at 4:54 PM
    PROseur
    Pussy
    Welcome boss
  5. Jul 28, 2017 at 8:54 PM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    @troubleshoot
    hold the mud flap up in the fender well and take a picture so we can see what were are dealing with? Then we can help. I have had mudflaps attached right to the fender flare with 5 screws.
    Troublshoot[OP] likes this.
  6. Jul 28, 2017 at 11:44 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Amazon isn't exactly an auto parts dealer, so I wouldn't expect them to get what fits your vehicle right every time. This is hardly the first thread I've seen where someone gets hosed buying auto parts from amazon...
    I would just hit up a pick n pull/wrecking yard type place.
    Whatever you do, make sure you have a metal brace (a la oem) to prevent it from getting sucked up into the tire when backing up.
    Troublshoot[OP] and PROseur like this.
  7. Jul 30, 2017 at 8:25 PM
    zoblo
    zoblo Active Member
    03 extra cab trd v6
    I ran into the same problem with my 2003 tacoma with factory fender flares. they appear not to be made to fit fenders with the factory flares. I wound up cutting off the outside part of the flap (curved part) that would normally go on the outside of the fender if there where no factory flares. There are 3 holes and when you cut that part off, the flap it fits fine.
  8. Jul 31, 2017 at 11:48 AM
    Troublshoot
    Los Angeles CA
    That may be the answer I was looking for. Thank you.
    oem bracket.jpg and this is the bracket you refer to?
  9. Jul 31, 2017 at 11:57 AM
    jbrandt
    Justin
    That pic is too small to see what you are talking about. Honestly, you could probably just make a bracket out of a thin piece of scrap metal. It's just a bracket that hangs down a few inches from where the flair bolts to the body so it doesn't flap around so much, and won't get sucked into the tire when reversing.
  10. Jul 31, 2017 at 7:22 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    or just hit up the Buy/Sell/Trade and see if one of the 200+ that removed them would sell/donate them to you :)
