Advice for cutting out a siezed LCA cam bolt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Sep 20, 2018.
  1. Sep 20, 2018 at 1:21 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    I know there are a bunch of threads about this but i didnt see a lot about how guys did it. I got 3 of the 4 bolts out but the last one, the front passenger cam bolt sleeve is siezed.
    For a week prior to this job, every day i heated these bolts then after they cooled soaked them in Liquid Wrench. I did that again with this sleeve and doused it in 50/50 ATF and acetone then wailed on it with a sledge hammer but this baby a'int movin'
    Got the new sleeve from Toyota but i have to get this out. Does a sawzall really cut through the bushing and sleeve? What about a metal cut wheel on an angle grinder?
    For those who have gone before me, what method worked best?
  2. Sep 20, 2018 at 1:27 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I've used an air chisel to punch out the sleeve before. Another time, we did use a short sawz-all blade and it did cut through. Just be mindful not to damage the LCA (if you're saving it) or the frame.
  3. Sep 20, 2018 at 1:30 PM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    if you are replacing the control arms, grab a torch and heat that thing up, and by heat it up i mean make it glow red and use either a chisel or a air chisel to punch it out. i highly recommend using a face mask because there will be serious smoke, which most definitely give you cancer
    JDAM and TreeFortRichard like this.
  4. Sep 20, 2018 at 1:31 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I use “Carbide Grit” Sawzall blades for hardened steel. Never tried to cut out a LCA. Home Depot and other home stores carry them. The one I have currently is a Lenox 800RG.
  5. Sep 20, 2018 at 1:36 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    :sawzall:
    TireFire and slomoe like this.
  6. Sep 20, 2018 at 1:40 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Sawzall
    slomoe likes this.
  7. Sep 20, 2018 at 2:08 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Sawzall is enough to get through that bushing and sleeve?
    But yes im replacing the whole LCA so i could care less about the bushing
  8. Sep 20, 2018 at 2:12 PM
    motionridr8
    motionridr8 Well-Known Member
    Drew
    Greenville, SC
    2012 Tacoma 4x4 DCSB
    5100's/886's/JBA UCAs, ICON RXT Rears, US Offroad Winch Front Bumper, BAMF Rear Bumper, 235/85r16 Skinnies
    yes, I got through all 4 of mine with a Milwaukee Fuel M12 Sawzall and 3 Lenox blades. Total time to cut all of them out was maybe 45 min, and that includes me moving around and getting set up.
  9. Sep 20, 2018 at 2:13 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I would go sawzall before I tried an angle grinder. You'll have a bit more control that way and won't chew up the truck.
    Mac4Willy and Skootter14 like this.
  10. Sep 20, 2018 at 2:52 PM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    this, i had a seized lower bolt on my coilover and torched for as long as it took me to sip a beer. Then hit it with hammer and it came out. When I reinstalled I put anti-seize on the bolt.
  11. Sep 20, 2018 at 3:51 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I tried this but it didn't work. I can try putting heat on it longer, though. Even a sledge wouldn't losen it the first time
  12. Sep 20, 2018 at 5:44 PM
    JDAM
    J
    Worshington
    12 DCSB TRD OR
    ya it can be tough. I torched it 5 times before I just held there for what seemed like an impossible amount of time and then beat the shit out of it. I was almost about to give up.
  13. Sep 20, 2018 at 5:51 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm a pro at this. Every, fucking Toyota truck I've owned in the last 20 years has had a froze cam bolts.
    A saw all works but takes forever.
    The angle grinder with a cut off disc is the fasted way bar none.
    Most corded angle grinders have too high of RPM for a novice to use on these cam bolts. The cordless models of angle grinders work great! The RPM is much less and they stall quicker when you start to bind the cut off wheel as it goes deeper into the bolt/bushing.
    Honestly, I wish there was a "stickie" for new Tacoma owners to have the dealer pull these cam bolts and anti seize them.
  14. Sep 20, 2018 at 6:13 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    Sawzall - I used 3 blades on 4 bolts, took less than 5 min each. Don’t waste time on a used blade, just throw a new one on each time.
    motionridr8 likes this.
  15. Sep 20, 2018 at 6:25 PM
    ColoTacoPrerunner06
    ColoTacoPrerunner06 Truck of my dreams
    Speedway Blue 06 Prerunner built like I like it.
    5.5 lift front 4 rear on 33s with an endless amount more work to do
    I've ran shops for years. You either cut them out with a sawsall or you punch them out with an air hammer. Best is the sawsall.
  16. Sep 20, 2018 at 7:08 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I dont have pneumatics so sawzall it is. Any particular metal blade needed? Are the Lenox the best?
  17. Sep 20, 2018 at 7:36 PM
    TacoMoose
    2017 Tacoma OR
    Lenox makes good blades, buy multiple blades because u will go through them. And if u try the chisel method, u can use a regular hand chisel, just takes more effort. U can even use a big bolt if u have one laying around, if the heat didn't work that means ur not heating it enough. I remember many times where i ended up putting holes in control arms with a torch from all the heat. Those bolts will not give up, they put up one hell of a right.
  18. Sep 20, 2018 at 7:38 PM
    TacoMoose
    2017 Tacoma OR
    Anti seize works wonders, i put it every bolt i ever take out. I thank myself later when the bolts come out with ease
  19. Sep 20, 2018 at 8:03 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I had to cut three out of my old T-100 a couple of years ago. I used the sawzall.
    After you smoke the end of the blade, use your cut-off wheel to cut off the bad part of the blade and keep going. If you can, keep it wet with some WD-40 while you're cutting, it will keep the blade cooler and make it last longer.
    Mine were tough as hell. Good luck!
  20. Sep 20, 2018 at 8:11 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    One expensive carbide blade made for cutting thick metal did the job for me. Don't remember brand but it was red and like $22
