Advice for a broken O2 sensor bolt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazytacoman, Mar 27, 2020.
  1. Mar 27, 2020 at 6:02 PM
    crazytacoman
    crazytacoman [OP] Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Was finishing up replacing my downstream sensor and thought I'd force the nut in.. ended up causing what's show in the picture
    Am I screwed?
    Black DOG Lila likes this.
  2. Mar 27, 2020 at 6:16 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    you might be able to cut it flush, and drill/tap it for a bolt.
    Or try and find a section of pipe with the sensor mount at a pick-n-pull and splice in that piece and weld it up, or just use some of those couplers.
  3. Mar 27, 2020 at 6:17 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Exhaust shop could burn another one on for you pretty quickly
    crazytacoman[OP] likes this.
  4. Mar 27, 2020 at 6:20 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Easy peasy for an exhaust guy...had that twice on my 99 4Runner, fore and aft cat. Rip replace bolt and put it back in
  5. Mar 27, 2020 at 6:23 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    I had the same thing happen and was able to get it out using mini vice grips after heating with torch, soaking in liquid wrench and a few good taps with a hammer. I ran a 8mm x 1.25 tap in to clean the threads before replacing with a new stud. Thought I was screwed too before that.
  6. Mar 27, 2020 at 6:25 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Aw man. That's so good to hear. I'll be doing this first. If all else fails.. I'll take it to a muffler shop like others have recommended
  7. Mar 27, 2020 at 6:26 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Good idea. I'm thinking it'll be a pain in the A doing so with the limited space there
  8. Mar 27, 2020 at 6:30 PM
    Black DOG Lila
    Virginia
    That's about the same lil bit of stud as I had left to work with. The longer you let penetrating oil soaked and reapply the better. I heated, let cool, soaked, hit it, heated it again and soaked more over a couple of days. Popped right out though.
  9. Mar 27, 2020 at 6:52 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Did you use a new bolt or did you find a screw that fit?
  10. Mar 27, 2020 at 6:56 PM
    Black DOG Lila
    Virginia
    I bought new nuts and bolts at Advance Auto. Had to put a nut on the bolt and cut the bolt head off then back the nut over the cut end to make sure it would thread ok. Couldn't find the exact stud replacement
  11. Mar 27, 2020 at 6:57 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Alright. I'm thinking if the bolt is able to screw out, I can maybe find a stand alone screw that fits, to use instead
  12. Mar 27, 2020 at 7:01 PM
    Black DOG Lila
    Virginia
    The size is 8mm x 1.25
    The O2 studs are available but were sold out at the time.
    Get some anti seize too.
    You'll have to lock two nuts on the new stud to wrench on when installing the new stud.
  13. Mar 27, 2020 at 7:19 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Thanks so much for the info! Will update this thread soon
  14. Mar 28, 2020 at 3:18 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I no longer mess with even trying to fix these.
    Cut the old bung off install new one new studs by far the fastest and easy way for me
    years ago I wasted the best part of 4 hours no more bungs and studs on the shelf.
  15. Mar 28, 2020 at 5:10 AM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    Like Wyoming above, I no longer mess with trying to fix this type of issue either. $35 for a new Walker intermediate pipe from Summitracing.com when I replaced my muffler worked just great. i will say that both my sensor mount bolts were much worse than the OP - there was no way I was getting either nut off due to rust on the threads.
  16. Mar 28, 2020 at 2:00 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
  17. Mar 28, 2020 at 6:50 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    sounds like a good idea, but I would have to have a welding machine already
  18. Mar 28, 2020 at 7:51 PM
    exminnesotaboy
    Maple Grove, MN
    For my 2001 3.4L, it was all bolt on - is your 2002 2.7 different? I’m genuinely curious...
  19. Mar 29, 2020 at 9:18 AM
    Currygoat
  20. Mar 29, 2020 at 3:30 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Wish the stud was longer so I could do this. I think only one nut is able to screw in. I soaked it in PB Blaster overnight, and tried to unscrew it with some pliers, but no luck..
    ___________
    Though, with the stud being broken off at a length so that it's flush with the O2 sensor & gasket (pic #1).. I then used one of the HVAC screw clamps I had lying around to tighten it (pic #2). Waiting until Monday to take it to a mufflershop, so they can get it out for me
    YotaBro and wilcam47 like this.
