Adjusting caster on Total Chaos UCA's
Discussion in 'Suspension' started by BraskaTaco, Jul 11, 2019.
  1. Jul 11, 2019 at 7:15 PM
    BraskaTaco
    BraskaTaco [OP] Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Seeing at they aren't adjustable, is there any way to actually push the wheel forward while running their UCA's? My wheels seem to sit far back in the wheel well and I'd like to go with 295's next. I already have a CMC and the clearance is tight.
    Past alignment specs:
    At the end of the day, I'm not opposed to swapping for something else as I can only seem to make it a year on a set of uniballs and bushings before they get loud as hell, even with lubrication every 5k miles. I suspect road salt is the culprit.
    uurx likes this.
  2. Jul 13, 2019 at 12:59 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Set the caster between 3-4*
  3. Jul 13, 2019 at 1:01 PM
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Ya, that's my question though, how does the caster get set on a non adjustable uca?
  4. Jul 13, 2019 at 1:05 PM
    gotoman1969
    There is a caster adjustment cam on the lca. One adjusts camber the other caster. If there is no prebuilt caster in the uca you made need to get some they do have it or that are adjustable. My jba uca’s have 2* of caster built in. So getting 4* was easy.
    uurx likes this.
  5. Jul 13, 2019 at 1:13 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    as far as the TC uniballs getting loud, really you must lube them on the regular (weekly), every 5k miles will simply not cut it...
    as far as really pushing for positive caster, you might want to consider the jba upper control arms if not perhaps the spc light racing arms. either of these options will solve the maintenance issues of running uniballs...
    how much CMC did you actually trim out? maybe some more grinding and trimming should be done if your current clearance is not enough for you...
  6. Jul 13, 2019 at 1:44 PM
    dead.fm13
    dead.fm13 Well-Known Member
    Chesapeake, VA
    2017 Tacoma TRD Sport
    5100/888's front, JBA UCA's, 5160's/Dakar's rear, Ray 10 MDB 17", 285/70/17 Ridge Grapplers, Hondo Garage Radio Knobs, MESOJDM Ultimate Turn Signals, MESOJDM Ultimate Combo Maps/Dome, MESO Total Tail Stage II, MESO Puddles
    I’ve got the JBA’s and I’m thinking of switching over to the SPC’s. I still rub and hear crunchy pops on the pass side when it flexes even a little bit. I have to go slow into my driveway or it’ll be loud as hell.
    71tattooguy and BraskaTaco[OP] like this.
  7. Jul 13, 2019 at 9:44 PM
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Do you use the PTFE spray?
    Regarding the CMC, it's actually a pretty deep cut and into the circular opening around the body mount bolt/bushing.
  8. Jul 13, 2019 at 10:08 PM
    MYKOSPRO
    MYKOSPRO Well-Known Member
    Houston, Tx
    15’ TRD Pro
    The above alignment sheet doesn't show your caster specs. Any experience alignment tech can lower your caster to move the wheel forward more to prevent contact with the body mount. I suggest try a different alignment shop.
  9. Jul 13, 2019 at 10:19 PM
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Even with a non adjustable UCA?
  10. Jul 13, 2019 at 10:31 PM
    MYKOSPRO
    Houston, Tx
    15’ TRD Pro
    Correct. I currently have SPC UCAs and i installed them with the default setting "D" which gave me +2° caster. When I first got my alignment, the tech put my alignment within the factory specs which had my caster at 1.5-2.0°.I was aiming for caster to be above 3°, which i was able to get 3.5° and 4.0° by just adjusting the LCA eccentrics.
  11. Jul 13, 2019 at 10:34 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have 3.6 caster with tc uppers. Needed the extra caster for 35s
    Taco-Obsessed and BraskaTaco[OP] like this.
  12. Jul 14, 2019 at 7:55 AM
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    So 3.6 was just built in or you were able to adjust the caster through the lower control arms?
  13. Jul 14, 2019 at 8:38 AM
    anthony250f
    Anthony
    San Diego, CA
    The caster is adjustable from the lower arm. I can go anywhere from 1* up to 3.6
  14. Jul 14, 2019 at 8:39 AM
    anthony250f
    Anthony
    San Diego, CA
    Rear cam all the way out and front cam all the way in is max caster
  15. Jul 14, 2019 at 9:18 AM
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Perfect, thank you!
    anthony250f likes this.
  16. Jul 31, 2019 at 6:57 PM
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Gonna go to an offroad alignment shop soon. Although I’ve been reading threads on here about the LCA tabs busting, so that’s promising lol.
  17. May 2, 2020 at 6:12 AM
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    So a castor of 3.5 degrees, how far forward does it actually move the tire? New to uca info, but just got 33s, planning a cmc and ucasnext, its such a tight fit now.
  18. May 2, 2020 at 10:03 AM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    OP, all after market UCAs that have built in caster is positive caster. Positive caster on UCA pushes the tire toward the rear fender.
    This is to improve steering and alignment specs after a lift, it’s intentional.
    The only way to move the tire forward with a UCA is an adjustable UCA, like SPC. Many people, including myself for a while assume or think that built in caster on a UCA places the tire forward. This is absolutely incorrect.
    I didn’t start to rub my CM until after I installed Icon UCAs that had built in 2* of caster. The stock UCAs didn’t rub.
    There are so many people on this forum that get it wrong and think their built in caster on aftermarket UCAs moves the tire forward. It actually moves it further back than stock.
    I recently went through this extensively. I had to buy SPCs and sell my Icons because my oversized tires had a slight rub on the CM after setting caster to 4* via the LCA.
    After the SPCs were installed my tire is now about 2” from my CM at its closest position when turning the wheel. All of this is with 33” tires and NO CMC or any trimming. I did have to trim a small amount of the front part due to the tire being so far forward now.
    My lift is also just under 2.5”
    Do a search for SPC UCAs and you’ll see plenty of people explaining this.
    Good luck!!!
    EDIT for clarification:
    Positive caster on the UCA moves the tire back.
    Positive caster on the LCA moves the tire forward.
    When doing a normal alignment without an adjustable UCA the only place to move caster is at the LCA. The more positive caster adjusted on the LCA, the more forward the tires moves.
  19. May 2, 2020 at 12:11 PM
    Jasonstacoma
    Stock
    Would you say spc is the best choice?
  20. May 2, 2020 at 12:55 PM
    TacoTime850
    2019 DCSB 4x4
    They are the most adjustable. I am biased because I have them, but I got them after doing a lot of research and determined that they are the best adjustable UCAs. I love mine and they are great.
    From my research, almost everyone said SPC are the best adjustable UCAs.
    I also called them a couple of times for help on how I should adjust them and they were very familiar with the Tacoma and set me up. Their customer service is awesome. They have a couple of technicians at the office that will go in great detail with you if needed.
