Adding tie down points?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pontoon, Jun 4, 2020.
  1. Jun 4, 2020 at 3:28 PM
    pontoon
    pontoon [OP] Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    Hi all, has anyone added tie down points to a 1st gen? I’d like additional tie down points near the bottom of the bed near the tailgate so I can use a moto gate.
    I assume a drill would be needed, and maybe some body panels would have to come off? I’ve never taken panels off before.
  2. Jun 4, 2020 at 3:37 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I added some stainless steel D rings to the floor of my bed. They just bolt on, using two bolts each. I just made a steel backing plate for under the bed to reinforce it a bit. Figure where you want to place them, and drill some holes.
    I definitely don't hold motos with them, but they're plenty strong enough for securing cargo.
    The panels on the bed are welded on, so you're not really going to be able ot remove them.
    Take the spare tire out, and you'll be able to access a good chunk of the bed form underneath. You just want to make sure that where ever you drill, you won't hit any wiring or anything like that.
    You'll need 2 people to tighten the bolts.
    Fuergrissa and joe25rs like this.
  3. Jun 4, 2020 at 6:42 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    If you have a little money to spare, I recently bought one of these rivnut setters. Have used it on two tractor projects, but no Taco mods.
    Basically, you drill a whole and use the rivet tool to set a nut inside, say between two panels. Works like a pop rivet. Then you could thread a hook type bolt into the nut. That vertical at each end of the tailgate is a good spot to consider. Not thin body panel type metal.
    Some people run unistrut along the sides of the bed and insert tie downs there. You could likely use the rivnut to attach some unistrut to the floor of the bed and add tie downs to that.
    General Rivnut Offerings by Amazon:
    https://tinyurl.com/y7vsv8h6
    Specific one I bought:
    https://tinyurl.com/ycy78kc4
  4. Jun 4, 2020 at 7:38 PM
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    No need to remove anything except maybe the spare tire if it's under there. Go to harbor freight and search tie down. It'll come up with a few options. Pick one and install.
  5. Jun 4, 2020 at 9:44 PM
    pontoon
    So are you all suggesting that I add it to the floor of the bed, or on the wall of the bed, at a low height near the floor?
  6. Jun 4, 2020 at 9:52 PM
    Broke Okie Ty
    Ty
    I'd do the floor. There's more material there and less likely to rip out incase of evasive maneuvers.
  7. Jun 4, 2020 at 9:52 PM
    pontoon
    Thanks, I will do the floor.
  8. Jun 4, 2020 at 9:54 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    Did the same, keep it simple
  9. Jun 5, 2020 at 7:00 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    sonofdad likes this.
  10. Jun 5, 2020 at 7:14 AM
    Wsidr1
    Indiana
    I should have been a little more specific. The reason I'd use the rivnuts if you mount to the bed floor is so you can easily remove when not needed. Since the rivnuts are below the surface, you'd have nothing in the way of loading other materials.
  11. Jul 19, 2020 at 4:51 AM
    enil01
    enil01 I like Spam
    Kevin
    Washington
    '01 SR5 Xtra cab 4x4
    Stuff and such
    We used these a lot on the planes in my old squadron. Great stuff, I’ve been thinking about adding a couple. I always thought it would snag everything in the bed though. Thanks for bringing it up.
  12. Nov 24, 2021 at 6:33 AM
    tDaddy
    tDaddy Member
    21TRDOR
  13. Nov 24, 2021 at 9:57 AM
    Ritchie
    I up-graded the hardware and went with stainless screws and Ny-locks.
    The tracks were pre-drilled.
    tDaddy likes this.
  14. Nov 24, 2021 at 10:32 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Figure out just where added tie downs will work the best for you .
    Since I used weld on D rings to 1/4" plate I made sure to use a bigger plate as well on the bottom side
    tDaddy likes this.
  15. Nov 24, 2021 at 10:46 AM
    Novatoy1
    Novatoy1 Well-Known Member
    Jeff
    Pittsburgh
    2017 Tacoma CCOR
    This is how a guy drove to a flea market in Kentucy. No tie downs , no problem. Even had 2 boxes on the engine hood.
  16. Nov 24, 2021 at 12:33 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    I added four rings to the bottom corners of the bed. Big fender washers and careful placement makes them very sturdy. Holds my motorcycles pretty well so far. Carriage bolts make it a one person job
  17. Nov 24, 2021 at 2:38 PM
    jbrandt
    Justin
    Why wouldn't you just use the structural tie-downs already in the bed that are designed for such loads?
    I definitely would not trust a couple fender washers to the weight and stress of a motorcycle.
  18. Nov 24, 2021 at 3:18 PM
    OpeCity
    Long Beach, CA
    Because they’ve ripped out before hauling a transmission. I repaired the threads and put them back in and now use both factory and aux tiedowns. The bikes are very light so I’m not too worried. 1.5” grade 8 fender washers spread a lot of load. If I was carrying heavy street bikes I might reconsider.
