Adding rake to a leveled truck
Discussion in 'Suspension' started by ABrownD18, Nov 1, 2022.
  1. Nov 1, 2022 at 3:49 PM
    ABrownD18
    ABrownD18 [OP] Member
    Adam
    Parts Unknown
    2022 TDR OR DCSB
    I’ve got a 2022 Off Road that came with the TRD leveling kit, I’d like to return the truck to factory rake and am wondering if anyone has experience with this. Is it as simple as adding a 1” block in the back. Are there any major downsides to this that I should consider? Thanks for any input
  2. Nov 1, 2022 at 8:46 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  3. Nov 2, 2022 at 4:16 AM
    ABrownD18
    Adam
    Parts Unknown
    2022 TDR OR DCSB
    Thanks, and I’ve looked over that post and searched for my specific question but haven’t found anything about adding rear height to an already leveled truck, I just wasn’t sure if the context was different enough to put the question out there. Sounds like I can treat it as any other rear lift
  4. Nov 2, 2022 at 7:08 AM
    gudujarlson
    Minnesota
    The front and rear suspension are independent from each other.
  5. Nov 3, 2022 at 11:57 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  6. Nov 3, 2022 at 2:20 PM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Can you confirm there is no spacer or anything up front that can be removed?
