Adding Nav to a 2013 Tacoma
Discussion in 'Audio & Video' started by protivakid, Nov 20, 2017.
  1. Nov 20, 2017 at 9:19 AM
    protivakid
    protivakid [OP] Member
    Trying to help my father-in-law. He has a 2013 Tacoma with the below touch screen radio.
    Question 1: Is there a way he can add navigation to this unit and if so what is needed?
    Question 2: If he needs a whole new radio, what OEM radios with nav will work and what other harnesses are required?
    Thanks!
  2. Nov 20, 2017 at 9:22 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Can't add Nav to that one, and you would need a new 2014-2015 Navigation Ready receiver, GPS antenna. From people have said the Nav sucks you would be better off buying an aftermarket deck with GPS built in.
    RexsTaco likes this.
  3. Nov 20, 2017 at 9:24 AM
    protivakid
    That helps get me started. I'll see if he is open to aftermarket but I am guessing he wants to go OEM.
  4. Nov 20, 2017 at 9:26 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    There used to be a guy on here that sold them not sure he does anymore @FLTrucks
  5. Nov 20, 2017 at 9:26 AM
    ANDROOO
    ANDROOO Well-Known Member
    Andrew
    PHX to SOCAL to PHX
    2013 Tacoma Reg Cab
    does any one have a good after market radio with GPS they use would be nice to update mine as well.
  6. Nov 20, 2017 at 9:28 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    ANDROOO likes this.
  7. Nov 20, 2017 at 9:31 AM
    protivakid
    Just to be clear
    1) No 2013 Tacoma came with nav?
    2) For the 2014/15 radios what is the difference between the JBL & Non Nav radios? Harnesses the same?
    3) Is a 14/15 radio bezel needed as well? Are the bezels the same for the jbl and non?
  8. Nov 20, 2017 at 9:33 AM
    ANDROOO
    Andrew
    PHX to SOCAL to PHX
    2013 Tacoma Reg Cab
  9. Nov 20, 2017 at 9:34 AM
    ANDROOO
    Andrew
    PHX to SOCAL to PHX
    2013 Tacoma Reg Cab
    i have a 13, and no nav for me :(
  10. Nov 20, 2017 at 9:35 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Not sure on any of the JBL stuff as it was overpriced garbage to me. I ripped the Entune Unit out of my 15 3 weeks after I bought it. I don't think your Bezel is the same as the 2014-2015
  11. Nov 20, 2017 at 9:36 AM
    protivakid
    Loo
    Looking on AutoTrader I am seeing many '13 Tacomas with Nav... So there is a Nav radio for the 13?
    https://www.autotrader.com/cars-for...chRadius=0&makeCode1=TOYOTA&modelCode1=TACOMA
  12. Nov 20, 2017 at 9:37 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  13. Nov 20, 2017 at 9:38 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  14. Nov 20, 2017 at 9:41 AM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    I have an Alpine head unit with GPS..works good ,fits as if it came from the factory.
    Unchained 5150 likes this.
  15. Nov 20, 2017 at 9:51 AM
    protivakid
    So can I just get one of the 2013 Nav radios and put it right in possible needing an antenna?
  16. Nov 20, 2017 at 10:06 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    If you can find one
  17. Nov 20, 2017 at 10:11 AM
    protivakid
    Has anyone done a comparison of the 2012/13 nav system to the 2014/15 nav system?
  18. Nov 20, 2017 at 10:12 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    No idea but you can start a thread with that question
  19. Nov 20, 2017 at 2:51 PM
    RexsTaco
    RexsTaco Well-Known Member
    Vincent
    San Antonio
    Maxtrac spindles Bilstein 5100 adjustable OME 885 coil JBA UCA's Custom leaf pack and Maxtrac extended shocks in the rear. 35x12.5 Atturo Trail blade M/T Moto Metal 18x12 -44 offset wheels.
    Here are some links to help you out.. use the search to find more. lots of reading and stuff, get some drinks and relax it took me a while to read and finally pull the trigger.
    https://www.tacomaworld.com/threads/oem-2014-tacoma-navigation-radio.298745/
    https://www.tacomaworld.com/threads/2014-navigation-unit-in-2013.304014/
    https://www.tacomaworld.com/threads/question-about-2007-to-2014-steering-wheel-swap.358845/
    https://www.tacomaworld.com/threads/install-2015-entune-non-jbl-non-nav-in-2012.453127/
    https://www.tacomaworld.com/threads/2013-bluetooth-touchscreen-install-in-my-06.312741/
    locdan likes this.
  20. Nov 20, 2017 at 8:12 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    If you can put a Factory nav in for less that $500, its a decent route. I have a 15 with nav, and its a straight POS! Benefits of an aftermarket nav unit, warranty and firmware updates.
