Adding lighting to my topper....
Discussion in 'Lighting' started by CoTacoTy, Oct 17, 2022.
  1. Oct 17, 2022 at 3:45 PM
    CoTacoTy
    CoTacoTy [OP] Well-Known Member
    White 2017 sr5
    Hey TW, im going to add some of @mattgecko leds to my shell, and when I hooked my topper up I added this fuse holder, with a 10, 5, and 1 amp fuses already installed. I have an open port available to connect to this fuse box
    Id like to have interior lights hooked up to my dome light switch that is already connected to the shell. Then I would like my windoors and rear to have a separate switch.
    ....if anyone has some kick ass ideas, im all ears....
    How do I utilize this type of connector?
    I'm an electrician by day....so this sorta ashames me, but I need some help on the automotive side. Gimme a building and 120-480 volts and I know what im doing....dc current and 12 volts, I need a little help....
    Let's hear your thoughts on how you'd do this
  2. Oct 19, 2022 at 2:05 PM
    CoTacoTy
    White 2017 sr5
    Can anyone tell me how to utilize this set up in my bed? Thos is going to be the first of many electrical projects and I could use some guidance on what to look for.
  3. Oct 20, 2022 at 6:30 PM
    Aws123
    Aws123 Well-Known Member
    Adam
    Colorado
    2019 tacoma trd off road
    What kind of power draw are you looking at for the lights?
  4. Oct 21, 2022 at 6:34 AM
    CoTacoTy
    White 2017 sr5
    Thats a good question. Im planning on getting lights from @mattgecko, both his topper lights for the interior, and for the 3 doors
    https://mattgeckoleds.com/shop/ols/...-led-camper-light-kit-with-bed-mounted-switch
    https://mattgeckoleds.com/shop/ols/products/win-door-light-stirps
    There aren't any specs on what his leds draw, but maybe tagging him in this post will help find that out.
    I cant imagine it draws much. Currently I have a dome light and a 12v power port coming off of this little fuse box.
  5. Oct 21, 2022 at 4:28 PM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    1 - 2 amps for both sets of lights.
  6. Oct 21, 2022 at 6:42 PM
    Aws123
    Adam
    Colorado
    If you want one light triggered by your dome switch and its 1 amp or less, you could probably just use a t-tap. Personally i would probably try and solder a wire to the dome switch terminal or something like that. For the rest of the lights you could just trigger them with most switches off Amazon. No need for a relay if they are an amp or two. Check the switch rating to be sure.
  7. Oct 21, 2022 at 8:23 PM
    mattgecko
    South San Jose, CA
    Remove the dome bulb and wire the light strip to this:
    https://www.amazon.com/uxcell-Festoon-Adapter-Socket-Connector/dp/B01F39DDOM
  8. Oct 21, 2022 at 9:48 PM
    Aws123
    Adam
    Colorado
  9. Oct 25, 2022 at 8:10 AM
    CoTacoTy
    White 2017 sr5
  10. Oct 25, 2022 at 8:23 AM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    For your door and windoors you can hook them up to a plunger switch (aka limit switch). If you want to get real fancy you can also wire in a DPDT switch to give you the option of it coming on with the plunger switch or being on all the time. The panel for the switch here was kind of crude and I made improvements later but you can get as fancy or ugly as you want to get with it.
    CoTacoTy[OP] likes this.
  11. Oct 25, 2022 at 8:42 AM
    CoTacoTy
    White 2017 sr5
    I actually think I saw this post, or something really similar. I do want to leave the option open to do something like that. If you see my OP, I have this box with 3 fuses in it I wanna know how to utilize them appropriately. Cuz I've got a 1a, 5a and a 10a fuse in there that I had installed when I purchased my topper. So I've got power back there I just need to figure out how to utilize it and what kinda connectors to get. I haven't pulled it apart yet
  12. Oct 25, 2022 at 8:56 AM
    Enigma8246
    Lee
    Central Arkansas
    It looks like the box came with an SAE style plug so you know what you need to use there for connectors. Beyond that you can use 1/4" blade connectors which crimp on or SAE connectors which would need to be soldered on. Again, it all depends on how fancy or ugly you want to go.
    Your lights only use 2a and you don't want your fuse too far oversized. There may be 1a, 5a, and a 10a fuse in there now but the actual fuse box is likely rated for higher than that. I'd start by finding out what the actual fuse box is rated for. Typically it will be phrased in terms of amperage per fuse and total overall amperage for the box. If you have 4 lights you could probably put all of them on one fuse and use the 10a fuse.
  13. Oct 25, 2022 at 8:58 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I used LED strips from Amazon
  14. Oct 25, 2022 at 9:25 AM
    CoTacoTy
    White 2017 sr5
    How do they switch?
    geekhouse23[QUOTED] likes this.
  15. Oct 25, 2022 at 9:33 AM
    geekhouse23
    Cut up an, otherwise, useless spot for a second pair sunglasses:
    CoTacoTy[QUOTED][OP] likes this.
  16. Oct 25, 2022 at 9:59 AM
    CoTacoTy
    White 2017 sr5
    Dammit that's sick. So how do you route the wiring thru the roof?
    Can I use something like this and just tap into the red wire of the led strip, then bring the negative from the led to the black to my dome light?
    TICONN 240PCS T-Tap Wire Connectors, Self-Stripping Quick Splice Electrical Wire Terminals, Insulated Male Quick Disconnect Spade Terminals Assortment Kit with Storage Case (240) https://www.amazon.com/dp/B07MLPBPW5
  17. Oct 25, 2022 at 10:21 AM
    geekhouse23
    Fuse panel under the hood through the firewall, up the a-pillar and tucked behind the headliner near the top of the windshield.
  18. Oct 29, 2022 at 2:24 PM
    CoTacoTy
    White 2017 sr5
    Ok! I've got it figured out how I wanna do this! So I just hooked it up and connected it in series on the same circuit as my dome light, and it works! But its dim....I put in a higher fuse, still dim. I put it on its own switch, its bright and ready to go. Still tapped into the same circuit with a 5a fuse...so the difference is because I'm running it in parallel instead of series...any way to solve this? Thanks for the tips
  19. Oct 29, 2022 at 4:44 PM
    Enigma8246
    Lee
    Central Arkansas
    FYI definitely don't want to run lights in series in a 12v system. I learned that lesson the hard way.
  20. Oct 29, 2022 at 4:56 PM
    CoTacoTy
    White 2017 sr5
    Do tell! Not enough supply and too much resistance is my guess?
