Adding foam to door seals - Who posted?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChrisK7UND, Apr 13, 2017.
  1. Apr 13, 2017 at 10:19 AM
    ChrisK7UND
    ChrisK7UND [OP] Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    I have been searching and have come up dry. I believe I saw this on TW, but looking for the post where somebody had inserted some skinny foam roll tucked into the rubber door seals to help make more positive contact. I am looking to do the same thing by slipping some into the seals on the factory bed cover to maintain more pressure on these seals. Any help?
  2. Apr 13, 2017 at 10:23 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I am no help in finding the actual thread itself but also recall seeing one, I think they used rubber tubing instead of foam and I can see that helping you make a tighter seal doing that.
  3. Apr 13, 2017 at 10:41 AM
    LEXICON
    LEXICON born where the prairies meet the rockies
    Courtney
    Canada
    2016DCLBBLACKTACOMATRDSPORT4X4PREMIUM
    Nothing worthy
    BUMP!
    I too am looking. I told Toyota to forget replacing ANOTHER seal. I said ill just do this and they offered to pay for the parts.. lol
    BarcelonaTom67 likes this.
  4. Apr 13, 2017 at 11:20 AM
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    Search button? Just try using various key word combinations to find the thread.
    tcjacado likes this.
  5. Apr 13, 2017 at 11:23 AM
    Hoangde
    Hoangde Well-Known Member
  6. Apr 13, 2017 at 11:48 AM
    LEXICON
    Courtney
    Canada
    Nothing worthy
  7. Apr 13, 2017 at 12:26 PM
    ChrisK7UND
    Colorado
    SOLVED! Thanks for posting. I did search but did not try "Rubber" I was just fixated on foam I guess. :)
    LEXICON and shakerhood like this.
  8. Apr 13, 2017 at 1:26 PM
    Hoangde
    This is what i purchased at HomeDepot and used
  9. Apr 13, 2017 at 2:37 PM
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    helped a buddy do this years ago on his leaky bed cover, that said in the brochure "Water resistant" but fine print, said "not waterproof". I forget who made the thing. His was a f150 (8 foot bed maybe?) with smooth plastic cap, with wider/longer/heavier cover. The weatherstripping we used didn't work. it was too thin and just got flat under the weight of the cover.
    I THINK (memory is SOOOO bad). We ended up using door weather stripping. It was cheaper than the weatherstripping at pepboys/autozone for car doors.
    https://www.lowes.com/pd/M-D-20-ft-Black-Door-Seal-Silicone-Door-Weatherstrip/1099657
    We tried a lot of different things with this because we we couldn't get it perfect the first time.
    I believe the end result was to use RTV adhesive and stick the thing TO the bed plastic cap, tapered edge in. the glue on the doorstrip just wasn't robust enough. We sealed the ends to keep air pressure in the door strip so it didn't collapse flat (because it did that). I had gasket sealant so we used that but I guess you could use anything.
    It worked GREAT but the air in the strip was TOO much, like an overinflated balloon. So then we put little holes along the weatherstripping to vent the air (not too different than the holes on the inside you see in the door weatherstripping)
    That worked real well. Ugly as hell without the cover but it worked well.
