Adding an auxillary fuel tank, how to advice needed.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bodhi armor, Jun 7, 2016.
  1. Jun 7, 2016 at 3:13 PM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    I want to increase my trucks fuel capacityby 10 gallons.
    I going to bolt an aftermarket fuel cell into my truck bed and mount an auxiliary switch into my dash. When one tank gets low, flip the toggle to aux to run off my secondary tank.
    My superduty F250 had this setup and i loved it.
    What parts would i need, and how would i set it up?
  2. Jun 7, 2016 at 4:09 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    @colinb17 has a tank in his bed, something i wanna do someday, check out his setup
    Large and colinb17 like this.
  3. Jun 8, 2016 at 5:11 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    I've got essentially what you are talking about. only difference is that it is a lot easier to dump the fuel from the 2nd tank into the factory tank, vs running directly off of the 2nd tank.
    I have a 15 gallon tank in the bed. when I flip the switch in the cab, the fuel gets pumped into the factory tank.
    dual pumps to speed up the transfer, as well as act as backup should one pump fail.
    the two small pump lines tee into a single larger line
    that large line then splices into the filler neck of the factory tank.
    installed
    tank fits right between the wheel wells, under my toolbox
    link to the tank
    https://www.amazon.com/Moeller-Boat...fuel+tank&qid=1452279578&ref_=sr_1_37&sr=8-37
    overall:
    -no fuel leaks
    -roughly 25 minutes to transfer all 15 gallons to the factory tank
    -unless you install a ball valve between the two tanks, and close it when not in use, you risk throwing a code. because the tank introduces do much more volume to the system, the truck thinks that there is a vapor leak "loose gas cap". a hand valve will solve this. I personally don't care about the light on my dash, and have left it alone.
    -on road trips, your bladder will be your limiting factor for stops, not your fuel capacity.
    Hope this helps
  4. Jun 8, 2016 at 5:26 AM
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Dublin, OH (but still a Pittsburgh guy)
    2013 Black Baja Access Cab
    I looked into doing this in a hot rod that I was planning to use for cross country road trips. I spoke to Aeromotive and basically you need a second fuel system - tank, pump, return line, etc. There are valves and relays available for marine applications for this. The second tank would need to hold a pump with a similar flow rate and pressure rating as the factory unit. It would need it's own return line and could tee into the factory feed line. a 2-way back flow valve would serve as this tee - when pump one was one, no fuel could back flow into tank two, and visa versa. There would also need to be a valve to determine which return line was in use to avoid overflowing a tank. It was doable, and not conceptually too difficult, but all the valves and lines got expensive, and the complexity added failure points. Of course, this was for a 1960's car, not a computer controlled modern truck. I imagine you would need a second fuel level gauge that could talk to the computer, and I bet you would end up with codes being thrown. A better solution for our Taco's would be a larger replacement tank that uses the factory pump and sending unit, but I haven't been able to find one that isn't a one-off custom job for big bucks. I think the reserve tank being used to fill the factory tank is a better option at this point.
  5. Jun 8, 2016 at 5:44 AM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I would love to use something like this, but basically have it for emergencies. I want it to be simple and basically act as a large Jerry can. Could you use a hand pump or siphon to pump directly into the tank instead?
  6. Jun 8, 2016 at 5:47 AM
    PaulK
    Paul
    ChadsPride likes this.
  7. Jun 8, 2016 at 5:54 AM
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Oh yeah, I've seen those. I'm trying to keep the price low though.
  8. Jun 8, 2016 at 5:57 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    colinb17 likes this.
  9. Jun 8, 2016 at 6:10 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  10. Jun 8, 2016 at 7:04 AM
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    It seems for the price of Jerry cans you could get that 12 gallon tank for $77.
  11. Jun 8, 2016 at 7:04 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you could certainly siphon it into the factory tank, if you have the aux tank in the bed. all you would have to do is have a way to prime it
  12. Jun 8, 2016 at 7:05 AM
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I've seen a few different kits on Amazon for fairly cheap.
  13. Jun 8, 2016 at 9:11 AM
    bodhi armor
    Joshua
    East TX
    That is an excellent solution, thank you!
    I embrace the "KISS" concept with enthusiasm!
    colinb17[QUOTED] likes this.
  14. Jun 30, 2016 at 6:04 PM
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Thats a lot of weight and a lot of range especially for a 4cyl PreRunner. What's your goal? Are you trying to do tha Elcan Highway?
  15. Jun 30, 2016 at 6:15 PM
    IronPeak
    AuggieX
    Back to Back
    Considering doimg this myself, the setup above would add 168lbs ( 144# gas, 22# tank) , not unlike having a passenger riding along
    stvhwrd likes this.
  16. Jun 30, 2016 at 9:34 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Really cool set up. I bet if you threw a one-way check valve in there, just before the T into the filler neck you wouldn't throw any codes, and wouldn't have to manually close a valve
    Calion and 2015trdpete like this.
  17. Jul 1, 2016 at 3:21 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    that would probably work. the other option is an electric globe valve, that's wired into the fuel pumps. when you turn on the fuel pumps, the same switch opens the globe. turn the bumps off, and the globe closes.
  18. Jul 1, 2016 at 3:58 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    any valve needs to be able to handle a vacuum draw, this is how the vehicle ECM checks for "leaks"
    sit and listen to your truck after it shuts down, it is never truly OFF, there are pressure sensors in the evaporative emissions that watch the fuel system for leaks, there is a vacuum pump that runs at prescribed intervals that keeps the system under vacuum. this happens constantly, or until the battery dies.
    the point is to keep vapors from exiting the vehicles fuel system.
  19. Jul 1, 2016 at 4:00 AM
    Axion
    Axion Well-Known Member
    Adam
    Midwest
    daily driver with extra flexibility
    various odds and ends
  20. Jul 1, 2016 at 9:02 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    This is how I did in a different truck I had some years back.
