Adding a Tachometer and different gauge cluster
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1943MB, Jul 14, 2021.
  1. Jul 14, 2021 at 7:56 AM
    1943MB
    1943MB [OP] Well-Known Member
    Louis
    1999 Tacoma Regular Cab 2.4 litre
    none
    Hi,
    Is it a big problem converting a non tach truck to one with a tach and changing out the gauge cluster to fit the same opening. Using the same year cluster but with the two gauges ( speedo and tach ) instead of just the speedo.
    Lou
  2. Jul 15, 2021 at 8:54 PM
    Tydeorum
    Tydeorum Well-Known Member
    Anderson S.C.
    4x4 SR5
    I thought about doing this also. I would want to get the milage adjusted to my milage so its correct. Ive earned every mile thats on her.
  3. Jul 15, 2021 at 9:12 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    It's a pretty easy swap. You need to use the same year or newer. 95.5 to 97 are cable driven and 99 to 04 are digital. (I hear some 98 and 99 base models were cable driven.) you also need to make sure you get one from a 4 cylinder, you can use one from a 2.4 or 2.7. A v6 cluster will not work on your truck.
    Wulf likes this.
  4. Jul 16, 2021 at 6:05 AM
    1943MB
    Louis
    none
    Hi,
    Thanks for that info. I need to pull the cluster in order to repair my temperature gauge and since I was going to all that trouble I thought about the upgrade. Now I need to determine if it's a cable. From what your saying if it's digital then the connector has a terminal for the Tach built into it ? Just plug it in and that's all there is to it ?
    Lou
  5. Jul 16, 2021 at 9:40 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    The tach signal wire is already included in the wiring that goes to your existing cluster.
    When you unplug the connections to your current cluster and plug in a new cluster with a tach it will work as expected. (As long as you get the right one for your truck)
  6. Jul 16, 2021 at 9:58 AM
    Tour991
    James
    South Reno/Tahoe
    The big thing you need to make sure is the cable for the speedometer. You can see the difference in the 2 from the front. If you have a cable driven spedo you will see a mechanical odometer like picture 1. Picture 2 is the digital.
    PacotheTacoFL, Tydeorum and Wulf like this.
  7. Jul 16, 2021 at 9:23 PM
    Tydeorum
    Anderson S.C.
    4x4 SR5
    So of i have a 99 that is cable driven, i need to find a speed/tach cluster that is also cable driven and from a v6 if mine is a v6 correct?
  8. Jul 17, 2021 at 12:25 AM
    Tour991
    James
    South Reno/Tahoe
    Correct.
